Question about Air Tools & Compressors
A huge crack in the ceiling how do I repair - Air Tools & Compressors
    Sergeant:
  • 213 Answers
If it is a flat smooth ceiling slightly v-grove the crack and apply Fiberglass drywall tape apply 3 coats of drywall compound making the mud feather out sand prime and paint
Posted on Aug 05, 2013
Can I tape between a popcorn ceiling and a smooth drywall wall?
By beading, are you referring to drywall tape? If this is cracked and you want to repair the tape, I suggest you use a nice cove mold to cover up the lose tape. Otherwise you'll need to remove the old tape, smooth out the popcorn ceiling area, re-tape the corning then feather it in, then texture the ceiling again. The trip is much easier to do. It's cleaner, quicker and really would look nice.
Will it stick? yes but unless you want to keep the same look, I opt for the cove mold.
Nov 14, 2014 | Drywall
Plaster board
Selley's make a product called Spakfilla. It is used for patching cracks and cavities in wall and ceilings.
It is easy to apply - just follw the instructions.
Mar 05, 2012 | Computers & Internet
I just need to know how to install this in an old house to replace a ceiling fixture and install a ceiling fan without having to make a huge hole in my ceiling. I can't find any instructions on the model...
If you're trying to replace a light fixture with a ceiling fan. The most important thing is to make sure that the electrical box in the ceiling can support the weight and momentum of a ceiling fan. If it's an old house, as you say, I suspect it's not. However, there are support kit, that you can but from most home centers, that will install without having to make a "huge hole" in your ceiling. If you have an attic above this room, accessing and beefing up the support of the electrical box would not be difficult. If you don't have that luxury, then the support kit is your best solution, as you don't need to have access to an attic above.
As far as the Model # 22200 is concerned ... Since you didn't mention what it was, I don't have a clue.
In any event, I hope this helps you in installing the ceiling fan. Please let me know and if you would please rate my response to you. Thank you!
Mar 25, 2011 | Heating & Cooling
I dropped my green egg, it now has a huge crack on the side and the bottom broke in three places. how can I fix this?
I hate to give you bad news but repair is near hopeless, I would try a heavy duty epoxy JB weld or JB industro weld. notch out all cracked areas then fill notch and crack with epoxy. Allow to dry fully. JB weld is safe in high temp of engine compartments. Good Luck
Sep 13, 2010 | Big Green Egg Large All-in-One Grill /...
My lg-vu has a huge crack on the inside of the screen. it still has sound but on the screen all you see is the crack. can that be fixed?
yes, it can be fixed, its a matter of replacing the screen.
Take the phone to a local repairer within your vicinity, so that the screen can be replaced.
Good luck.
Apr 16, 2010 | LG Vu CU920 Cellular Phone
Can I use same remote for more then one of the same type ceiling
If they are all the same make/model they will only have a few frquencies they work from. If there is a slide switch or something that is numbered 1 to 4 or whatever, set them all to the same and 1 remote will work them all.(or should).
Jun 13, 2009 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Need website to register hampton bay ceiling fan? Please help.
You can change the entire appearance of your fan by simply changing the ceiling fan shades. If your ceiling fan is outdated, you can change its look with new shades and even new blades, no need to take it down.
Replacing the ceiling fan shades is an affordable and practical alternative to purchasing a new ceiling fan. The amount of work in removing the old fan and installing the new one is enough to have you considering replacements of shades and blades as the best answer.
The Many Styles of Ceiling Fan Shades
Ceiling fan shades come in a variety of shape and size. With the huge selection, you are sure to find one that is right for you and your décor. In addition to the different sizes and styles, the materials can come in various styles, such as:
• Smoked Glass
• Etched Glass
• Beveled Cut
• Smooth Surfaced
• Ridged or Bumped Glass
There are an endless combination to the ceiling fan shades styles and materials.
Apr 10, 2009 | Garden
Jeep Liberty-02 crack in timing cover broke clamp on hose
It is within your rights to have the dealer show you the "crack" and give a reasonable explanation of why it cracked, BEFORE you permit them to do repair. There is a huge price difference between a hose and a cover. (for that matter, just about anyone with a scredriver & pliers can change a hose)!!!!
Feb 16, 2009 | 2002 Jeep Liberty
Leak in the shower is leaking water through the ceiling
Hi lorenzotwalk,
I'm Harvey the Master Plumber.
Your problem is: When you use the shower, water leaks through the ceiling.
First, since it only leaks when you're using it you can ignore the water lines. Now comes the detective work. Look very closely at any place the water can squeeze thru, i.e. cracks in grout or caulk, etc. Don't forget to look on the floor imediately outside the shower and around the shower door if any. If found it must be scraped out, cleaned and dryed to get good adhesion, then caulked with a high quality silicone caulk (color of your choise). Any other caulk will crack no mater what they say.
Let dry for 24 hrs.
If you havent found this kind of problem it's time to look at the drain line connection. You may have to open the ceiling to do this, that's why I'm always carefull in the first step. Turn the water on and watch the drain connection. If it leaks there, it must be repaired. In this case you might cunsider checking the Repair Directory for a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 18, 2008 | Home
HTC Touch Repair
www.htclcd.com has instructions and the lcds
Apr 08, 2008 | HTC Touch P3450 Smartphone
Air Tools & Compressors Logo
137 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
