Grip pen zp 501e 00a
Tip sensor stuck
  • Joe Statuto Jul 22, 2013
    How can I fix the tip pressure sensor for my grip pen? It is stuck.
Wacom CTE-440 Graphire4 tablet is drawing when I don't want it to
Ok so I called costumer service because mine was doing the same thing. Apparently the pressure sensor in the pen is stuck down. What you do is remove the pen tip with tweezers, blow in the open end of pen, then tap the pen (open end down) in a table to get any debris out of there. Then just put the tip back in and give it a try. That did the trick for me. Hope this helps.
Feb 23, 2010 | Computers & Internet
Grip pen not working correctly
clean and clear the side pannels sensors
Dec 14, 2009 | Wacom Cintiq 15X Graphic Tablet
Pen keeps drawing when I lift it off tablet
This problem commonly occurs due to a stuck "nib" sensor (the sensor that detects pen pressure).
Take out the "nib" (important, so the sensor isn't damaged further) and whack the pen on your desk (or drop it on the floor from 3 feet up). It re-seats the "nib" sensor when it's stuck. If this doesn't work after multiple attempts, then the sensor may be too damaged.
Nov 28, 2009 | Wacom (EP130EPE) Digital Pen
How do you take off the Wecom pen tip?
You take it out...........yeah thats basically it. you just take like a pair of tweezers, plyers or something that can grip the tip and pull it out. dont squeeze too hard if you want to use the tip again since you might pinch the end and ruin it. this is for a bamboo pen like the one in the picture right?
Oct 31, 2009 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
My Tablet pen wont release, it acts like im clicking and holding
I'm just gonna pass on a email from Tech Support I recieved.
"It sounds as though your pen has pressure in proximity. This is present when the tip sensor of your pen is stuck down causing the pen to think that it’s clicking before it’s even touching anything. What you may want to try would be to remove the nib from the tip end of the pen, it pulls straight out with a pair or tweezers or your teeth, and leave that out overnight with the pen left on its side. Place the nib back in the morning and if the issue persists then you may have a defective pen tip."
The rest consists of personal info and warranty advice so I'll leave it there.
Sep 07, 2009 | Wacom (PTZ930AC) Graphic Tablet
Wavy lines when I try to draw straight lines.
same too me.on my old pc.that center thing was working fine.there wasnt any vibrtion at mouse pointer.i cant explain but i know same problem here..mouse pointer slips
Aug 12, 2009 | Wacom Intuos2 Grip Pen (XP-501E) Digital...
Pen sticking
In settings, turn Tip Feel all the way to maximum Firm.
Does this help?
Jul 16, 2009 | Wacom (EP130EPE) Digital Pen
How to take apart Intuos pen
Ok, after my wife washed mine in my jeans, i really desperate and decided that I had nothing to lose. I searched all over the web for ways to do this and nothing!!!! So today I grew a pair and tried something and low and behold... so anyway.
*!*!*!* Remove the rubber grip and button first (untwist tip cap and remove threaded section, slip fingernail under top edge of button and pop it straight up and off, slide rubber grip off towards point *just in case*) Grasp your pen in both hands with the tip facing to the left left hand should be grasped covering  the tip and ONLY the section that has the recessed barrel with the raised button ridge. Right hand should be grasped just off of the first diameter reduction from the right (ie. where the just before the pen gets thinner) and covering the eraser (unless you have really small hands) CAREFULLY but firmly pull the two halves of the pen apart from each other !**!*!DO NOT TWIST THE PEN!!!! the pen should come apart without a problem and now you have access to the inner goodness of the Wacom Intuos Pen
Note: when putting the pen back together, be gentle and place the board in the eraser side first, if it doesn't push the eraser tip up, twist it slowly till it slides all the way in (be sure to try to leave a tiny space for eraser play.) Twist the pen (board and eraser cap end) until you can see the two receptors for the buttons, slide the tip end cap on and press firmly until the caps seat together and the holes line up for the switch. slip the rubber cover back on, twist on the threaded tip and clip the button back on, that should do it, Hope this helps!
Malice
Jan 18, 2009 | Wacom (EP130EPE) Digital Pen
Pen dragging and skipping around the point where I press
Sometimes the grip pen get stucked because of dust or dirt, or the tip needs to be replaced. Clean the tip chamber or use a new one.
Oct 29, 2007 | Wacom (PTZ930AC) Graphic Tablet
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
