Question about Sony CDP-CX400 400-Disc CD Changer
Help with operation/maybe service
Bought used on ebay and when arrived, plugged in and the player goes into a mode of searching from one position to another and not necessarily is sequential order. There are no discs installed and I erased all the data from the previous owner manually. I also tried toe erase any program play that may have been stored. It seems like there needs to be a master reset to the player, but I don't know how to accomplish it. This is only a guess on my part. It will play a CD if I put one in and select the cd position, then hit play. Pause and stop works too. Any ideas for me?
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: player will not recognize that there is a cd in it.
Yeppers. the first thing to do would be to use a lens cleaning disc to see if that will help. if not take the top off the unit and clean the lens manually with a damped cotton swab and slowly with little pressure move the cotton swab in a circular motion then turen around to the dry side of the swab and do the same as before and try thge unit. if that doesnt work, then the laser, tracking/focus offsets/gains could need alighnment or the slider is not working or the spindle motor circuit is not working. Im afrad these repairs would not be for the untrained peron, as you need special test equipment to troubleshoot these problems and also may not be worth taking into a repair shop. Good Luck
Posted on Oct 09, 2006
SOURCE: Moved CD changer with discs inside - won't "reset" / work
CD PLAYER WILL RESET BY ITS SELF WHEN MAINS SWITCH IS PUT ON, SOUNDS LIKE YOUR MECH IS JAMMED TRY TO FIGURE OUT WHICH GEAR UNLOADS THE PLAYER DRIVE AND ALSO UNLOAD MANUALLY
Posted on May 18, 2007
smarthome2
  • 1114 Answers
SOURCE: My Sony 400 cd player will not play any cd's.
Your optics are either Really Dirty, or out of line and you would need a replacement optic pickup. If you are mechanically inclined, it's not a difficult repair and parts can be purchased thru lots of sites. First things first, pop the top and use "Dust-OFF" in the main chasis, it gets bad! Next, if you have a good CD/DVD player cleaner that uses fluid, run it thru a couple times then test any disc. If you don't have one, just about any convenience store has them. Just make sure it uses fluid!. If you still have an issue. post a comment and I can pdf you the schematic of the unit. it's pretty easy to read and follow if your a little more than a novice with electronics. Hope this helps
Posted on Jun 01, 2011
My palomar 225amp online it arrived w/ a 250 black faceplate.Amp lks new & pills and board look new. Running a galaxy959 it wrks grt. SWR 1.1 on wilson1000. Lights work, preamp wrks. No transmit?
there is your problem . You bought it on ebay ,paid twice as much as it is actually worth and you got screwed . Now you have to get it fixed because you bought a broken piece of equipment. If you have another radio hook it up to the amp and see if it works . Maybe the amp don't like your radio? If it doesn't work then we know its the amp so now treat it like another radio and look inside to see if anything is out of place or maybe burnt , from ebay . You might need a multi meter to do this . check all your voltages and make sure the amp has continuity going from pl to pl set your meter to ohms and insert the probes into the hole on each pl . that will tell you if there is contact . Now you should get a schematic to check out all the voltages of the components inside . It just might be that the amp is drawing to much or not enough amps to run it . I am confident you will find the problem and get it fixed .
Dec 07, 2015 | Astatic Radio Communications
I need a replacement for a defective board of a portablen coby dvd player. where can i buy such replacement in manila? thanks.
1) Search eBay for replacement parts: http://shop.ebay.com/i.html?_nkw=coby+dvd+player&_sacat=0&_sop=15&_dmpt=DVD_Players_Recorders&_odkw=coby+dvd+player&_osacat=0&_trksid=p3286.c0.m270.l1313 (sort by lowest price, because "boards" must be somewhere on the cheapest end of list). I couldn't find anything using terms: coby dvd player board, maybe there is other name for the "board"?!
2) If you can't find anything on eBay find all computer service centers in Manila via Google and send e-mail inquiries whether they have the coby dvd player board you need, sometimes they do. Even if they don't have it - they will certainly know where to get one.
Mar 06, 2011 | Computers & Internet
I have a Sony Blue Ray player BDP-S560 I bought in AUstralia which I thought was multi region but I find it will not play Blue Ray discs from the US. Is there an update for the player which makes it...
im not sure if there are updates... because i dont think sony players have the ability to have internet connection...
but, i found myself in near enough the same problem...
i brought my panasonic Blu Ray player from the UK, (i live in the UK) (not knowing at the time what multi region was) and brought a few of my DVD's of ebay which were from canada and america...
so i did a search for any adaptable hardware i can plug into maybe a USB slot and i found a MULTI REGION REMOTE from ebay around
Sep 19, 2010 | Sony BDP-S560 Blu-Ray Player
Hi! Plugged in VSX 04 (newly arrived from Ebay),
No, but is is possible it is not designed to work without speakers connected. Some amps will not last long if the outputs are run "open circuit".
Apr 20, 2010 | Pioneer VSX-04 Receiver
Below is the ad from which I purchased hockey
If you paid through eBay with PayPal, follow the "Help", and start an eBay "Dispute Resolution" process, and follow-up with PayPal -- PayPal can "reverse" the payment that you made.
Did the seller give you a US Postal Service "tracking-number"? Have you "tracked" the shipment?
Apr 07, 2010 | eBay Auctions
What adapter can we buy to plug the venturer portable dvd player into a household mains plug. It only come with the 12v lighter car adapter
What I did with mine is check eBay for a 12 volt, DC LCD monitor adapter. These normally have sufficient amperage to handle these players.
I did a search on eBay today using search phrase:
"new power supply ac adapter for LCD monitor 12v 5a"
and came up with one for about $14.00 with shipping. You will need to check the plug when you get it and, if it does not fit, get one from Radio shack or, as I did, cut one from an old adapter I had laying around.
Most of these units require that the positive side goes to the center conductor of the plug (check the diagram on the player case over the plug to be sure) so make sure you set it up the way the diagram shows or very bad things will happen to your player.
You may be able to find a 12 volt adapter at Radio shack or somewhere else but these units need (according to the specs) about 1 amp from the supply to work and charge correctly. You "may" be able to get by with an 800 milliamp supply but I have not tested this.
Good luck
Dec 28, 2009 | Venturer PVS177W Portable DVD Player
NO AVAILABLE PLAYER DETECTED!
Try going into settings, usb mode change that it should be either mtp or msc.
May 09, 2009 | SanDisk Sansa e200 MP3 Player
DVD player
You need to buy a channel 3 modulator. They're all over ebay, and I'm pretty sure Radio Shack or maybe Circuit City would have them.
Geno
Feb 26, 2008 | Televison & Video
Sony CDP-CX400 400-Disc CD Changer Logo
26 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
