Question about Vehicle Parts & Accessories
My 2001 Jeep Grand Cherokee Limited 8 cyl. 4X4 door remote lock/unlock/Panic stopped working. I took both remotes & had both remote batteries replaced in each, took both remotes to Autozone & the test
    Top Expert:
  • Vehicle Part... Master
  • 12,223 Answers
See the diagram attached and fix it. God bless you
My 2001 Jeep Grand Cherokee Limited 8 cyl. 4X4 doo - 81424874-8850-49c3-a8ac-ed567e315221.gif
Posted on Jul 21, 2013
1999 jeep grand cherokee the door locks stopped working
Possible master switch or busted wire in door boot.
Nov 28, 2012 | 1999 Jeep Grand Cherokee
Keyless entry wont unlock
TThere is probably a problem with the door unlock relay or the passenger door module. The passenger door modules on Jeep Cherokee have had a lot of problems and there are a couple of Technical Service bulletins published by the manufacturer as a result of these failures.
Jun 02, 2012 | 2001 Jeep Cherokee
I replaced the battery on a 2001 Jeep grand Cherokee and security is on so it wont start how do I reset computer to get it to start
Directly from the owners manual...
1.- Enter your car wth your ignition key and your theft remote, and press the Lock button on your remote five times in 10 seconds.
2.- Insert your key into the Jeep's ignition cylinder, and then turn the key to the "Run" position. Wait for the car's automatic chiming sound to stop before proceeding.
3.- Press and hold the Unlock button on your remote for around five seconds, and then press and hold the Panic button at the same time.
4.- Hold both buttons together for one second and then release. Wait for the car's chimes to sound again and then press and release the Lock and Unlock buttons on your remote.
5.- Press and release just the Unlock button on the remote next and wait for a chime again to indicate successful programming. You can then remove your ignition key to complete the resetting process.
Hope this helps; keep us updated.
Sep 28, 2011 | 2001 Jeep Grand Cherokee
1996 jeep grand cherokee laredo: I had just bought this jeep from an owner and i locked the doors yesterday. When i went to unlock the door it set off the alarm. I have tried everything possible to...
put the key in the drivers door lock it with the key still in the lock unlock it and then pull the key out do this three times that is the factory built in security programing shut off system for jeeps and chrysler
Mar 11, 2011 | 1996 Jeep Grand Cherokee
Bought a 1995 jeep grand cherokee orvis . it has no keeless remote, just keys.installed new battery and the security must be on.all lights inside and out are blinking.on and off. how do i reset security.
Try turning the key..unlock-lock-unlock in the rear tailgate lock. That should turn off the factory security system.
If it's an aftermarket alarm system, you will need an alarm installer's help in determining what type and model alarm it is, before you can figure out how to shut it off.
Feb 05, 2011 | 1995 Jeep Grand Cherokee
I have a 2004 Jeep Grand Ckerokee Limited, and I can't get any of the windows to roll up. The keyless remote will lock and unlock the doors, and the memory system for keyless # 1 & 2 settings work when...
same thing happened to me. I was told this is common in jeeps and 90% of the time this is the solutuion. There is a rubber housing inbetween the drivers side door hinge and fuse panel with wires in it. Unhook your battery first then roll the rubber back and there will be broken wires in there. Strip the wires and reconnect them with connectors and you will be good to go. If tthe wires are broke on the drivers side panel no other windows in the jeep will work. these wires also control the mirrors.
Aug 23, 2010 | 2004 Jeep Grand Cherokee
Flasher lights stayed flashing, no gages would work.
Try Re-Activating the Remote System to Lock, Unlock and back to Lock again several times. Does the original problem re-occur? If so there is a problem with the Remote System, and possibly with the Remote itself sticking. Try Lock and Unlock and disconnect the battery. Wait at least 5 to 30-minutes before reconnecting. The remote itself you can take apart and check to see if the depress button is sticking causing the signal to be constantly sent over and over again.
Jan 10, 2010 | 2000 Jeep Grand Cherokee
2001 Jeep Grand Cherokee Laredo. Alarm sets off when unlocking doors with remote and will not shut off with remote, or by pressing the reset button behind blinking alarm light under dash,or by using key in...
I found a solution on another site showing if i turn the ignition on and hold the reset button on behind the alarm light untill it turns to solid blue light then turn off the ignition , it will disable the alarm.
Dec 12, 2009 | 2001 Jeep Grand Cherokee
My keyless remote for my 2000 jeep grand cherokee wont unlock the
go to autozone and use the remote tester on the counter to make sure that the remote itself is functioning or not, could be a dead battery. On some vehicles it is possible to reset the keyless entry by turning the ignition switch from off to run (right before the starter activates) 3 times or so, if you try this and the door locks activate then press the lock button on your remotes. good luck
Jun 03, 2009 | 2001 Chevrolet Blazer
2000 Jeep grand cherokee limited remote start
higher end starters will have the lock/unlock/panic buttons built onto their fob. as for the seats... I dont know why it would interfere with your settings, but who knows... better to ask the seller of the remote start system.
Mar 18, 2009 | 2000 Jeep Grand Cherokee
Vehicle Parts & Accessories Logo
363 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
