Question about Mercury Impeller, Water Pump - MerCruiser engines with engine mounted sea water pumps 1999 and older
Location of water pump in a 2002 5.7 mercruiser in my boat
    Sergeant:
  • 288 Answers
In the lower unit there is on and on the front of the engine block is another.
Posted on Sep 11, 2013
I have a 1998 sea ray boat
If Mercruiser its corrosion at pump/relays.
Jun 17, 2017 | Boating
1995 115 hp mercury water pump installation
the water pump is at the bottom end of the leg just above the gear box
it requires the bottom of the leg to be removed to get to the pump housing and impeller
May 27, 2017 | Mercruiser Mercury Mariner Boating
Location of sea water pump in a 2002 5.7 mercruiser
if its not on the engine driven by the fanbelt then its in gearbox ! P...
Jul 20, 2013 | Boating
HAVE A 1996 LEWIS XL1850 SKI BOAT WITH A 5.7 LTR MERCRUISER ENGINE. AT THE MOEMENT IT HAS A 4 BARREL EDELBROCK CARBURETTOR FITTED TO IT {WHICH IS GIVING A LOT OF FLOODING ISSUES AFTER PROLONGED IDLING, THE...
With faults like that you need to take the boat to a Mercruiser agent. These people will have seen the same problem before and they also have all the electronic test equipment that will pinpoint where the fault is. You have done everything you can do. A Mercruiser is a marinised GMC engine, so you could also go to a GMC dealer if you know one.
Oct 14, 2017 | Boating
Hi trying to find out the correct way the water hoses run on a 302 windsor with a mercruiser leg in a sea ray boat
i m search Compaq presario c700 driver but his not find. pls u check it.
thanks
chandra ketu rai
09955129198
Mar 12, 2010 | Boating
Mercruiser 5.7 litre inboard engine Impeller fault
You could be right. Check your idle rpm to see if the motor DIESELS after shutdown. See if linkage and carb setting can be reduced for RPM. Last, check your timing. If it has springs in the distributor you should not see rust powder on pivot points. Binding would keep engine overadvanced at shutdown. Then basic timing could be off too.
Sep 21, 2009 | Boating
Mercury Impeller, Water Pump - MerCruiser engines with engine mounted sea water pumps 1999 and older Logo
183 people viewed this question
Top Mercury Boating Experts
Colin Stickland
Colin Stickland
Mike
Joseph Hoffmann
Are you a Mercury Boating Expert? Answer questions, earn points and help others
