The error code TR is on my lg washing machine what does this mean?
SOURCE: LG washing machine error codes
I have today the same error code on model WD-11155FB. This code means that the speed of the electrical motor can no longer be controlled. The velocity sensor placed just behind the motor is probably damaged but it can be also the electronic board where is connected this sensor, or the wiring between these two items.
Posted on Aug 16, 2008
Brussels
  • 16 Answers
SOURCE: Error code SE on LG washing machine means what?
SE is a sensor problem as per LG support. I will post a follow up after I have recieved the technician in 2 days
Posted on Nov 03, 2008
SOURCE: LG WM 14316FD washing machine
An UE Error Code is indicative of a “Unbalanced Error”. This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum. I found this answer on the lg web site.
Posted on Dec 14, 2008
  • 6 Answers
SOURCE: code f23 for whirlpool washing machine
It means that there is a fault in the heating circuit and the heater is not working
The listed site deals with this problem so take a look and if you are fully capable of testing, follow the troubleshooting instructions but always double check that the unit is unplugged or disconnected from the electrical supply.
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
And remember kindergarten rule #1 "If in doubt, don't" with everything that is potentially dangerous. Electricity kills so a service repair bill may be a better solution.
Hope this helps.
jenni.
Posted on Sep 09, 2009
DirtyOldGit
  • 5 Answers
SOURCE: what is the AE error code on LG steam direct drive washing machin
the AE code means that there is water in the base I found that the steam heater element in mine was leaking so after a quick repair using silicon and a good clean after drying the water out of the base it now works again
PS I used to be a washing machine repair engineer! I wouldn't suggest that you start opening up your washing machine!!!!
Posted on Mar 31, 2010
LG washing machine error codes I got TCL error code on LG my washing machine What does it mean?
that means you need to clean the tub. use your search engine on the net to learn how. then the error code should go off.
Jul 26, 2017 | LG Washing Machines
Washing machine LG TR9103AEP IE error what does it mean ?
LG Top Load Washer-Understanding Error Codes - YouTube
? 2:17
www.youtube.com/watch?v=ZdoJVqFKye4
Sep 17, 2013 - Uploaded by ExperienceLG I have LG Washing machine and I tried to start it and came up with PE Error code and I ... I Can see IE OE and other error codes But Not PE.
Aug 04, 2015 | LG Washing Machines
What does error code 000000 -0000 means
How do you reset the error codes for an LG washer? - ImFee
www.imfee.com/how-do-you-reset-the-error-codes-for-an-lg-washer.html
Reset error codes on an LG washing machine by unplugging the machine, pressing ...locked 3G phones can be unlocked with the codes "123456" or "000000.
Jul 28, 2015 | Washing Machines
OE error on washing machine LG WM2233HW
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out.
A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code.. CLICK HERE
Thanks
Oct 12, 2011 | LG WM2233H Front Load Stacked Washer /...
We are getting an LE error on a LG WT R852 washing machine
Here is a tip that explains what the LE error code means.....
LG Washing Machine LE Error Code or Fault Code
heatman101
Aug 13, 2011 | Washing Machines
LG washing machine loud and error code LE
heatman101
Jul 02, 2011 | LG WM2301HW Front Load Washer
What does error code LE mean?
heatman101
Sep 20, 2010 | LG Washing Machines
Error codes
Here are the common error codes for the LG machines.
LG Washing Machine Error or Fault Codes
If you have a LG Washing Machine you may see an error code come up and wonder what it is. Here are the common error or fault codes that will be displayed on the LG machine.
OE
This means that the washer has tried for ten minutes to drain the water out of your machine and the water did not drain out.
UE
This means that the load in the drum is out of balance causing excessive vibration when spinning.
IE
This means that the washer has not filled with water in 8 minutes.
LE
This means that the motor and the control panel are not talking to each other properly
PF
Power Failure – The power has gone out to the machine and then has come back on
FE
This means that there is too much water in the machine
PE
This means that the water level sensor is not working properly
CE
The washer motor has received and over current condition
TE
This means that your heating sensor is not working properly
SE
This means that you had a temporary sensor error
HE
This means that you had a temporary heater problem
DHE
This means that you had a temporary dry heater problem
This will give you a basic idea of what has caused your error code.
Heatman101
Mar 15, 2010 | LG WM2277H Front Load Washer
My washing machine
Clean the drain filter out. Then while the filter is out, take a flashlight and look into the filter hole. We had this problem and discovered a metal bottle top lodged in the hole which goes to the pump. Removed the bottle top easily and the machine works fine.
Nov 14, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM1285 WASHING MACHINE
hi Hills659.
this is all i could find out.
What does CL mean on LG washing machine?
LG Washer CL Code Definition (What does it mean?) = The CL Code on front loading LG washing machines simply means the CHILD LOCK feature is turned ON.
The CHILD LOCK feature on your LG washer is meant as a safety precaution so children are not able to change wash settings. CL is not an error code. It is indicating that the CL or CHILD LOCK feature has been turned ON and is active.
LG Washer Error Code CL How To Turn CHILD LOCK Off
Dec 17, 2017 | LG Washing Machines
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
