Repair Sears Utility Pump
How to remove the diffuser from the pump body on a 1/2 HP Sears Utility Pump-Model No. 390.26000 No. 12 through No. 15 on the repair parts page of figure 7
3 Suggested Answers
  • 990 Answers
SOURCE: How do you remove the motor from a Flotec FPS5172, 1-1/2 HP.
The impeller screws on the motor shaft. First replace the through bolts in the motor. These are the long bolts, they will just cause headachs. On the back of the motor their will be a place to hold the shaft from turning, If you hold the shaft the impeller just unscrews. If you look in the center of the impeller it may have a set screw holding it to the shaft. If you have one of these it will be a left hand screw. Then you will need to break the impeller free as the brass that holds the impeller on will stick to the stainless steel of the shaft. Don't let how tight this is fool you when you put this back together it just goes on hand tight. Good luck
Posted on Nov 28, 2009
omendata330
  • 258 Answers
SOURCE: Where can I get parts for my old mid 1980s Sears 1/6 HP utility pump model 563.2693? Sears no longer has major Parts. Thank you
ebay
Posted on May 02, 2015
How do I fix the seal?
please follow this steps . God bless you
  1. Turn off the pump motor and close the input and output valves.
  2. Loosen the fasteners that secure the tube connecting the pump and motor.
  3. Move the motor away from the pump housing.
  4. Remove fasteners holding the diffuser to the backplate.
  5. Inspect the diffuser and O-ring for wear, replacing as needed.
  6. As needed, remove fasteners attaching the impeller to the shaft. Alternately, the impeller may be screwed on to the end of the shaft.
  7. Remove the impeller and seal from the shaft.
  8. Inspect and replace the impeller and seal.
  9. Reassemble the pump.
Nov 23, 2013 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
How do I take it apart
follow this steps and fix it. God bless you
How to separate pump from motor
take screws off around housing that separates motor from wet end remove diffuser then remove screw from impeller backwards thread and hold back shaft of motor after removing still hold shaft and turn impeller off regular threads make sure to replace seals
Apr 16, 2013 | Pentair 1 hp WhisperFlo InGround Pool Pump...
Working but no water pressure
my favorite pump ! remove stainless steel band this will allow you to split the pump, pull back from plumbing portion remove diffuser 5 small screws inspect impeller for trash or if it's broke.
if it has trash in it the hair basket or it's pot may be broke. these in my opinion are the best pump! and are easy to service.
option # 2
search your area for your local pool pump motor repair guy with free testing, bring it in and let him have a look-see at it.
never ever never touch the 4- 9/16 bolts, tightening them will destroy the seal plate (not stop the drip !)
would you like to know how to make the pump last longer ??
shhhhh don't tell no one, it's our little secret. DON'T STARVE THE PUMP FOR WATER !
J the pool pump doctor longwood Florida 32750
Feb 22, 2013 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
I want to replace all the o rings, i have seperated the moter from the body, but i only see 2 orings that i can replace, there are 4 other bolts i removed but i can not seperate the pump from the impeller...
THERE IS THE TANK GASKET THE DIFFUSER O-RING,LID O-RING AND THE SHAFT SEAL.. ITS A 1000.. ASK YOUR LOCAL POOL SUPPLY FOR A PAC-SEAL 1000 .. CLICK HERE TO SEE HOW 2 REMOVE YOUR PUMP .. PRIME THAT PUMP AFTER A REPAIR ... HOPE I WAS OF HELP.. IF SO .. VOTE .. Jay
Jan 29, 2011 | Pentair 2 hp WhisperFlo InGround Pool Pump...
MAGNUM POOL PUMP 1-1/2 HP MAGNUM PUMP BY: how do i replace the shaft seal...
You should be able to remove the diffuser and then the impeller to gain access to the shaft seal on these pool pumps. Your users manual should have a diagram.
May 16, 2010 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
Changing motor hayward 1.5 HP
Super pumps are very easy. If it is a northstar it is more difficult. Super pump. You will need 1 motor, 1 pump seal, 1 diffuser gasket, 1 housing gasket. turn off breaker, disconnect wires -noting whether it is 110 or 220 volts- , unscrew four bolts on back of pump housing (shaft side of motor), pull out motor with rear housing and diffuser (sometimes diffuser sticks inside), on wire side of motor hold shaft with wrench (flathead in some cases, but it is harder), unscrew impeller counter clockwise (like normal screw - you will nee a big pair of channel locks or a strap wrench), there are two pieces of the back housing and once the impailer is off you can remove the half that is closest to the end of the shaft to reveal four more screws, unscrew those four screws. screw back part of rear housing onto new motor. Install new pump seal to front part of rear housing and impeller, slide on front part of rear housing and then screw on impeller while holding shaft on wire side with wrench (only hand tight), replace housing gasket, replace diffuser gasket, slide into front housing and screw in four bolts. If electrical was 110 you will need to move the jumper on the wire end..if it was 220 then just hook kup wires...doesnt matter which is which as long as green or bare goes to the ground screw.
Mar 14, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
Removal and installation of diffuser and impeller kit
All jucuzzi pumps are some of the most difficult to repair.Pump front should seperate from body(volute) of pump by means of screws, or some kind of band. Diffuser should have ss screws, or
be held in plsce by notches or both. Impellor spins counter clockwise to come off. Can only remove impellor with impellor wrench, or very strong hand. Rear of motor must be held in place with normally a 7-16 wrench, allen head wrench or screwdriver. Depends on manufacturer of motor. Then impellor can be removed!
Should replace shaft seal under impellor. Can seperate body of pump from motor by turning four outer bolts on back of motor. Must mark rear cover of motor so lines up exact for reassebly. Ussually 1/4 inch socket wrench.Seal can be pushed out from back to front with the corrrect size socket and a very light hammer.
Try to factory Jacuzzi seal, they are better than aftermarket.
Coat rubber on seal with light silicone, and press back into place without touching or marring seal face. Best way is use other half of seal (spring piece) to gently but firmly reseat seal. Examine body from rear to make sure seal seats. Reassemble as taken apart, or just take to a qualified service tech at a well established pool/spa place. Kirk
Feb 13, 2009 | Jacuzzi Diffuser, 1 1/2 - 3 Hp...
Computers & Internet Logo
David Payne
David Payne
