Hello, I have a problem with my PC. I'll be
    Brigadier General:
  • 3,400 Answers
Connor,no input you write it can be a easy thing as the monitor-cabel is not tight enough fasten.check that first .if the problem don't go away you have open the computer and remove the videocard clean the cards slot with caned air short poffs never shacke the can.now reseat the card and hope at that did the trick.let me now if ok
Posted on Jul 20, 2013
PcExpert
  • 293 Answers
SOURCE: Loud CPU fan
check your cables. it may be in the way of the fan's fins. also clean your fan for dust.
Posted on Sep 16, 2007
Tirzo
  • 94 Answers
SOURCE: No input signal
Hi, there is a posibility that the issue is caused by your system unit. NO INPUT SIGNAL occurs when system unit fails to start properly. One possible reason is the power good signal was not sent back by power supply to mother board. You can check for any shorts or grounded device in your system unit. If you can reseat all the cables (power cable, IDE cable), expansion cards, memory cards even microprocessor that will be good. Another thing you can try is to power cycle your computer. If you are not confident enough to do those stuff you can call your computer vendor and ask for assistance.
Tirzo
Posted on Jun 13, 2008
  • 18 Answers
SOURCE: computer monitor won't tur on
An orange light would indicate there is not signal from the computer. Make sure the computer is on and you see lights on the front of it. Check the cable that runs from the monitor to the computer to see if it has worked loose.
Regards
John
Posted on Dec 02, 2008
SOURCE: Loud Fan, Three Beeps, Black Monitor and No Keyboard response
I have the same model after youlet it sit for a long enough period to cool down it will come back on and work normal, it is a cooling problem called gateway and they confirmed this theproblem I ran in to was what fan this computer has 3. temp fix I used was to remove the tower cover to allow better air flow try this till you can figure out what fan is messing up
Posted on Jan 10, 2009
fixyathing
  • 341 Answers
SOURCE: monitor gets scrambled and computer will not respond
bad video card memory. try to change the video card. if it's built-in to the motherboard then it's a shared memory, disable it in the bios and put in a new video card. check if PCI, AGP or PCIexpress type of card. if problem persists, check also the memory card. hope this helps.
Posted on May 12, 2009
When playing games on laptop hebirnating or shoting dawn
Graphics might be over heated. So it will shutdown.. go for advance version graphics chipset motherboad,. for better game xperience.,
solution: use heat sink., and check cpu fan., monitor cpu temperature..
System Shutdown During Gameplay
Jun 06, 2015 | Computers & Internet
Tip
Laptop or desktop computer overheating? Follow these tips to solve the problem
If you think your computer or laptop is overheating, follow these tips to solve the problem:
1) To confirm that overheating is the problem, install CPUID's Hardware Monitor (free download here):
http://www.cpuid.com/hwmonitor.php
Install Hardware Monitor and run it. The temperature of your CPU should be lower than 70 C for a laptop (lower than 60 C for a desktop PC). The temperature of your video card should be lower than 60, even if you're running a complex 3D game. The temperature of your HD depends on your manufacturer, but it should never be higher than 45 C (55 C for a 10,000 rpm driver)
2) To keep computer heat as low as possible, clean up your laptop or desktop regularly, removing dust and dirt. Remove the computer cover and use a compressed air can to blow the dirt out. Also, take care of verifying that the fan(s) move easily.
3) If you have a desktop computer, avoid placing it directly on the floor, since they will collect more dust thsi way. Place it on your desk. Also, avoid putting it inside any enclosure. Allow at least 3 inches between the sides of the case and a wall to allow plenty of air circulation.
4) If you have a laptop, avoid using it on top of any fabric (blanket, bed, pillow, etc). This blocks most of the airflow, causing overheating.
5) Laptops are not optimally designed for heavy gaming, which stresses your CPU and video card, producing very large amounts of heat. In other words, if your laptop overheats while playing 3d games, accept that this may be just normal for your machine... or play your games on a desktop PC.
6) Overclocking your CPU, GPU and/or FSB will produce much more heat than normal. To avoid the extra heat, do not overclock.
Read my other tips to keep your desktop or laptop computer running at top efficiency, including some tips about speeding up a slow computer.
on Mar 23, 2010 | Computers & Internet
Microsoft free repair
couple of things
how old is your pc? because if its over 10 years old it will struggle.
how demanding is the game? if the minimum requirements for the game are higher than you laptop/pc then it will struggle and ultimately crash, but this can happen even on the high performance gaming machines.
the best thing I can suggest is to download "speccy" this is a very useful utility to provide you with more information than you need. but what it does show is the temperature monitor these whilst playing games and whilst idle.
once you have a rough figure of the temperature have a look at the max operating temperature of you CPU (will have to look online)
if this is close to the danger mark then you will just have to come up with a coolling solution
Dec 22, 2013 | Computers & Internet
I have the msi gtx 570 twin frozr 2. when i play games like bfbc2 or bulletstorm, my display freezes.sometines even when im not playin.. ill then restart my pc to solve it.. i have the latest drivers nd...
My guess is that your system is getting too hot. That GPU outputs a bunch of heat and so does the rest of your system. You need to bring down those temperatures. Install as many fans as your chassis will allow. 120mm high RPM fans as exhausts say 2000RPM and slightly slower ones for the intake say 1200RPM.
Check the Nvidia website for the latest drivers, check everyday.
Use a program called Hardware Monitor to check the temperatures.
Also install MSI Afterburner, don't change the clock speeds.
Are you sure that the CPU Cooler is making proper contact with the CPU, check this by using the Temperature monitor software.
Update your version of Windows to the latest service pack and security updates.
Check that the PCI-Express cables are making good contact.
Take care!
damnor01
May 31, 2011 | MSI N570GTX Twin Frozr II OC GeForce GTX...
New Graphic card gives me a blue screen (or shuts pc down) when I go to play a game after 5 minutes or so and then recovers to reboot. Hello, I have a 2.8 gb CPU/1.5 gb mem/IBM ThinkCentre a50p...
Try reinstalling the drivers from AMD. If that doesn't help the problem, use a program like GPU-Z to monitor the temperature of the graphics card. If a graphics card overheats, it will shut the computer down giving a blue screen.
If it ends up it is overheating, try taking the side of the computer while you're playing a game or installing another fan.
Apr 05, 2011 | Computers & Internet
I recently bought a XFX HD 5770 GPU Card. After placing it on my motherboard, I casually played games and monitored the temperature of my CPU and GPU. When playing games like GTA IV, the temperature of CPU...
I suggest that you get an additional cooling fan, just for your video card, as San Andreas is a highly complex game that utilizes the video gpu very hard. Oblivion is another game which does the same thing. Also, I would look at getting a seperate case cooler, the more fresh air you can get into the case, the cooler things will be.
Jan 18, 2011 | Pine Technology XFX RADEON HD 5770, (1 GB)...
My HP Pavilion dv4 Notebook drops its FPS drastically when hot
Hello,if this is the first time that happens its OK but if every time you play or you stressed the CPU shutdowns or restarts the you should take it to a repair shop.You can download a program to monitor the temperatures to see if its a CPU or graphic cards overheating.As i can see your graphic card is low-mid range and on-board so don't stress it, putting high resolutions or high details and make it overheating and stress more your CPU.
Jan 31, 2010 | HP NB199UA Pavilion Notebook
Hello i just wanted to ask you guys something: i have a e8400 stock @ 3ghz and when i play games like crysis it seas that it's heated up to 45-48 degrees celsius and when i'm not playing any games i have...
the better the cooling you can add to the processor the cooler and better your cpu will be. the 140mm fan is a case fan, yes?
you will need to upgrade your cpu fan and heatsink.
CPUs on 45nm core are overall cooler than their predecessors on Core micro-architecture. However, the temperature different under 100% workload makes only 4-5 degrees. The thing is that Wolfdale processor core is smaller and features higher transistor density within a semiconductor die, which makes it a little harder for the heat flow to dissipate properly. That is why Wolfdale and Conroe heat up almost identically in idle mode. As for the relatively low temperature of AMD Athlon 64 X2 6400+, with twice as high TDP as that of Core 2 Duo actually, it can be explained by the not very best location of the on-die thermal sensor that is situated quite far from the hottest spots of the processor’s semiconductor die.
Mar 01, 2009 | FMI CPU Sensor Alarm Temperature...
There is an alarm/siren noise coming out of my alienware computer when i play a game.
Check the BIOS for temperature alarm and also check the temperatures that your CPU is reaching during a game by using a program like Hardware Monitor
Dec 23, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
