Question about Garmin nuvi GPS
3579lmt How do I reset home on this device
How do I reset my nook
This is how to do a HARD RESET - Means Factory fresh.
Turn the NOOK off completely.
Hold the Power button and Home (n) buttons. The device will turn on. Continue to hold both buttons until the device shuts off once again (~15-20 seconds).
Turn the device on normally. It will prompt for a factory reset. Press the Home button twice to confirm.
Sep 16, 2014 | Barnes & Noble Nook Tablet
I cant opn any apps with my cobykyros mid7022, help!
Try Reset your Tablet lol, this works with devices having physical home button:- 1. Press the power button and the home button together for a while, long enough until the screen appears with Android bot and a progress bar which shows that it's formatting the internal memory.
With NO physical HOME button:-
2. In case your device does not have a physical home button, press the power button and both the volume keys together for few seconds.
3. Press gently the "reset pin-hole" present generally on a side of Tablet. Use a clip-pin or similarly fine thing to gently push inside to reset your device to factory settings.
NOTE: You'll not only lose the apps on your internal memory and the data associated with it. All the device updates will also be lost and you'll have the version of Android your tablet came with.
you can visit my blog to see video how to reset your tablet
http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
Feb 26, 2013 | Tablets & eReaders
My lenovo tab has no sound and the keyboard is on japanese characters
Try reset your tablet lol,
visit my blog to see video tutorial how to reset your tablet
Feb 22, 2013 | Tablets & eReaders
Reset vigo android
This works with devices having physical home button:-
or you can Check my blog how to reset your tablet lol,
Feb 18, 2013 | Android Flytouch 3 8gb 10.1 Inch Super Pad...
I have moved, how do I reset my home address and
Either: While outside your home mark that spot your new home address.
Or: Write the address in the 'home'.
Nov 08, 2009 | Tomtom ONE GPS Receiver
How do you hard reset g1?
If your T-Mobile G1 Google smartphone is not responding or is frozen, you may have to opt for a hard reset. Here’s how:
1. Turn the G1 off. If it’s frozen on, take the battery out and put it back in the unit.
2. Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle.
Now to wipe the device clean:
3. Press Alt+L.
4. Press Alt+W for a factory reset.
5. Press the Home and Back keys again for about 25 seconds.
The device should then reset again and the hard reset is complete.
Sep 24, 2009 | HTC G1
My go 720 gps keeps freezing up
try resetting it, if that doesnt work, connect your unit to tomtom home. if you dont have tomtom home, follow the link at the bottom.
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
Aug 20, 2009 | Tomtom GO 720 GPS Receiver
I reset my iphone and now it is on black screen with apple
Hi Your iphone is having a software problem try to restore it whit itunes to the highest iphone firmware version, if your are still having problem send it to 1 iphone repair centre like www.E-Repairs.co.uk
Jul 04, 2009 | Apple iPhone Smartphone
When i turn it on it freezes.
Hello, I own a TomTom also. I have listed the procedures from TomTom Home and hope this will work. First try a soft reset (Reset button is located at the bottom of the TomTom device next to where the DC plug plugs in). Make sure your batteries are fully charged up or the USB cord is plugged in.
If your device is not starting up properly, follow the steps below:
  1. Soft reset your device. *
  2. If your device still does not start up, then reinstall the TomTom application using HOME
If you have backed up your TomTom to your computer, then you can reinstall the TomTom application from your backed up data. *    In rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. A reset does not delete any data.
Jan 16, 2009 | Tomtom ONE 3rd Edition GPS
I upgraded the tomtom via tomtom home and it will not start
Jan 10, 2009 | Tomtom ONE 3rd Edition GPS
GPS Logo
24 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
