When I press the button to change the speed of the fan it does nothing, and continues to blow at one speed and it is just about equivalent to the speed of the slow option...any ideas why? Also it will run for about 10 minutes and then stop blowing out cold air and it is just the fan blowing.Everstar portable air conditioner,model MPK-10CR
    New Friend:
Is it new? There may something wrong with the electronic circuit board not allowing other fan speeds. Try unplugging it for a while and try again. There is a temp sensing bulb somewhere on unit most likely on front where hot/warm air from space enters unit. Make sure you are not recycling cold conditioned air back onto sensing bulb.
Posted on Jul 25, 2013
  • 1 more comment
  • terry pezzola Jul 25, 2013
Malibu heating and ac
does the car have automatic climate control?
Apr 05, 2014 | 2005 Chevrolet Malibu
Casablanca fan intelli touch
there is a starter solenoid inside it works the speed setting. controls speed 1-2-3. 4 it bypasses it. in side the fan you will see a black box with c66 somthing that will need to be changed as that is the part that controls the speed.
Oct 17, 2013 | Dryers
I have a 2003 Envoy XL, 116K miles. Yesterday as I was driving I noticed that the AC blower speed was not changing as I pressed the buttons to change speed. If you shut the entire climate control unit off,...
You need to replace the BLOWER MOTOR CONTROL MODULE. its up under the dash, near the blower motor. Your dealer or a AC DELCO parts house will have it in stock, very common problem.
Sep 02, 2011 | 2003 GMC Envoy Xl
I have a 1991 Buick Park avenue with 44,000 miles that is not blowing air through the vents. I just put a brand new resistor in and that changed nothing. The fan spins at a low speed when the car is turned...
Switch the relay with one of the other relays to make sure that this relay is good then go to the HVAC control programer which is behind the floor vent (middle). The Blk/gray wire is the one that supports the relay coming out of the HVAC programmer, but there is a chance that this programmer is bad. If that proves to be the case, I may even have one...let me know.
Aug 06, 2010 | 1991 Buick Park Avenue
My Cadillac is making a "knocking" sound underneath (by the muffler). What causes that and is it expensive to repair. Also, the Caddy has "climate control" a/c. It doesnt blow air like other cars a/c. Is...
I'm not sure about the knocking sound, unless there is a piece inside the exhaust that has become dislodged and is bouncing around when the car is running.
As far as the A/C a common problem is to have a low charge on the A/C system of refrigerant which causes the air to seem less cold when blowing. There is no way to change the fan except by pushing the buttons to increase the speed electronically on the climate control fan. It can go as high as 'hi' fan if you press the button for that.
Jul 01, 2010 | 1992 Cadillac DeVille
Ceiling fan stuck on high
The Inteli-Touch system does have a slight learning curve.
How the system works is. You turn the power switch on, and leave it on, all the time. To set fan speed, you press and HOLD the fan button and it will go. . beeeep. beeeeeeeeep. beeeeeeeeeeeeeep. beeeeeeeeeeeeeeeeeeeeep beeeeeeeeeeeeeeeeeeeeeeeeeeeeep beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeep (higher pitched) when you reach your desired speed you let go of the fan button and it stays on that speed. So if you want to go to speed 4 you wait for the fourth beep and let the button go. To turn off the fan, press and release the fan button, to turn it back on to speed 4, press and release again. It has a memory. If you want to go to a higher speed while on speed 4 (or any other speed) just press and hold. To slow down the fan, you must turn the fan off by pressing and releasing the fan button, then pressing and holding until you get to the speed your desire.
The instructions which came with the fan should explain the rest. After you get used to using the IT control system, you will love it. I do. I have two Casablanca IT Victorian II fans in my living room. They are featured in this video. http://www.youtube.com/watch?v=2pv55wZqohs
May 20, 2010 | Casablanca Fan 6672G Panama® Ceiling Fan
1999 lexus rx300. fan won't blow. ac light is on
Possibly the connector to the blower unit has been diconnected or is loose.
Apr 13, 2010 | 1999 Lexus RX 300
How do i change language on canon pixma mp130
1. Press the [Copy] button
2. Press the [Menu] button seven times ("USER DATA" or the equivalent will appear on the LCD)
3. Press the [+] button five times
4. Press the [OK] button
5. Press the [+] or [-] until "ENGLISH" or the equivalent (e.g., "ANGLAIS") appears on the LCD
6. Press the [OK] button
7. Press [Stop/Reset] to complete
Mar 03, 2010 | Canon PIXMA MP130 All-In-One InkJet...
I have a sunbeam 12000 btu window unit air conditioner. I can't seem to change the fan speed when it is in cool mode. When I put it on fan only it blows extremely cold air and i can change the fan speed. ...
Sounds like the switch is wired wrong.
When you put the switch on fan only the compressor should not run at all, therefore their shouldn't be any cold air.
Check the switch to see if it's wired right.
Jul 29, 2009 | GE Profile ASM10AA Air Conditioner
Heating & Cooling Logo
131 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
