Question about Boss Audio BV10.4BA Flip-down Overhead Monitor with Built-in DVD Player, 10.4 TFT-LCD Active Matrix Display, Resolution 1152 x 234 pixels, Brightness 500 NITS, DVD Playback as well as DVD-R, CD, MP3, VCD and MPEG-4 Compatible, Anti-skip mechanism, Last po
Overhead DVD player draining my truck battery
Overhead DVD power source comes from the dome light. It is in "constant on" position meaning the lights are always red even when the unit is off. When the unit is on, the lights are blue. How can I get my system to stay off completely until I want it on so that it does not drain my truck battery?
Why my interior light want come on!!??
Check the dome light switch. I believe its between the map lights in the front overhead console. You can set it to Always Off, On with Doors, or Always On.
The Dome light and the cargo area light should come on when the door is open and the switch is set to door position, or when set to the always on position.
If only one of the lights come on change the bulb of that light. If neither light comes on change the fuse.
I believe the instrument panel fuse block is located on the passenger side of the center console, to the left of the glove box near the floor. The cover usual lists where and what each fuse does. Look for Interior Lighting, I believe #23. Pull the fuse and check if its broken. If it is replace it. If not you may have electrical issues.
Oct 17, 2014 | 2008 Chevrolet Equinox
Interior lights dont come on when door is opened
check for a dome light on and off switch by the headlight switch or check to see if the dash light dimmer is not turned down the whole way. if those are good then check to see if the door switch by the hinge is not stuck
Jul 04, 2012 | 2002 Mitsubishi Montero Sport
How to wire domelight in rosen overhead dvd player
put dvd purple wire to the car gray wire your traverse has positive trigger. Hope that works , switch has to go to positive on dome switch . Please post back if that works.
Jun 27, 2012 | Rosen G10 Car DVD Player
Dome lights don't come on when you open the doors but light works when you push button on dome.
The dome lamp has a switch that can be put into several positions. "Door" "Off" and "On" If you want the light to come on when you open the door then you must have the switch in the "Door" position.
The "Off" position will only let the dome lamp work when you override it with the dash control and the "On" position will leave the light on at all times - door open or not.
Dec 18, 2010 | Hyundai Santa Fe Cars & Trucks
Blaupunkt GmbH 12,1" lcd monitor in bus have 4 wires; one is black and it's ground but yellow, red and blue, wher is go?
black usually is ground the red is positive and the yellow is a constint power source that always stays on for memory and the other is blue and that is for remote. meaning a wire that is positive and only turns on with a stereo switch or a switch power now the red is a constant power to really coming from the battery and this is if these wires are power wires if not. if they are video then email me back and ill get back at you thanks nothing in wirs i cant figure or learn to. jokerstats
Apr 27, 2010 | Blaupunkt IVMR-1042 10.4" TFT Roof Mount...
Need brake circuit diagram for 1991 chrysler new yorker
1991 Chrysler New Yorker Auto Security Wiring Diagram
Battery Constant 12v+ Positive Wire (+): Red and Pink
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Yellow
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Dark Blue
Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Black/Orange
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Black/Yellow
Parking Light Positive Wire Location: In Drivers Kick Panel
Power Door Lock Positive Wire (+): Orange/White Or Orange/Violet
Power Door Lock Positive Wire Location: In Drivers Kick Panel
Power Door Unlock Positive Wire (+): Pink/Violet
Power Door Unlock Positive Wire Location: In Drivers Kick Panel
Door Trigger Negative Wire (-): Yellow
Door Trigger Negative Wire Location: In Drivers Kick Panel
Dome light Supervision Wire: Use Door Trigger (Requires Relay)
Dome light Supervision Wire Location: N/A
Trunk Release Positive Wire (+): Black/White (Requires Relay)
Trunk Release Positive Wire Location: At Trunk Release Switch
Horn Negative Wire (-): Black/Red
Horn Negative Wire Location: At Relay In Fuse box
Tachometer Wire Negative Wire (-): Black/Gray
Tachometer Wire Negative Wire Location: At Ignition Coil
Brake Light Positive Wire (+): White
Brake Light Positive Wire Location: At Switch above Brake Pedal
Factory Alarm Disarm Wire (-): Light Green/Orange
Factory Alarm Disarm Wire Location: In Drivers Kick Panel
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
Thank You for contacting Fixya.com
Aug 03, 2009 | 1991 Chrysler New Yorker
Trouble shooting radio wiring cant find positive and ground wire for radio hook up
Most always will either be a red or ornage wire for power and black or brown for ground. Use a test light to check those wires with the key off. If it lights up...main power/constant feed/memory feed. the ground wires will not light unless the clip end of the test light is attached to a power source
Jul 17, 2009 | Pontiac Catalina Cars & Trucks
Pyle dvd player dome light
You need a third wire
The 12V Red need to go to a constant positive (battery) the yelly needs to go to the positive from the two wires, and the ground should go to the ground for the two wires
Feb 05, 2009 | Pyle Car Audio & Video
Pyle Audio PLRD92 overhead monitor w/dvd
i have a pldr92 i have tried wiring in a 2004 hyundai santa fe as directed by manaul. the unit is not powering on at all any suggestings
Aug 21, 2008 | Car Audio & Video
Boss Audio BV10.4BA Flip-down Overhead Monitor with Built-in DVD Player, 10.4 TFT-LCD Active Matrix Display, Resolution 1152 x 234 pixels, Brightness 500 NITS, DVD Playback as well as DVD-R, CD, MP3, VCD and MPEG-4 Compatible, Anti-skip mechanism, Last po Logo
Top Boss Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
