Question about Electrolux Refrigerators
Reset control board
How to reset if there's nothing on the display board..?
  • Official Brand Answer
  • 4,342 Answers
Hello Christopher, thank you for your question. Let's try resetting the refrigerator by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn the unit back on. If the issue persists, then more than likely the unit could be experiencing a communication error with the control board or a potential wiring failure.
Posted on Jul 22, 2013
Treadmill (Nordictrack T9si) stopped suddenly... Power still being received by controller unit, but display doesn't stay lit so nothing functions
open up the control console and look for loose wires... if no loose wires are found, call CoreCentric Solutions and ask if they refurbish that control board... CoreCentric Solutions Reverse Logistics Core Collection and Recovery...
Jul 06, 2016 | Exercise & Fitness
AEG model T56840L appears to have no power. There are no lights, no display, just nothing. I have checked power is getting to the machine end of the power cord.
Sounds like a fuse on the control board is bad or the control board has failed, the control board can sometimes be reset by leaving the power unplugged for a few hours, then plugging back in, (this will not work if the fuse or control board is bad) if either are bad, they will need to be replaced
Oct 17, 2013 | AEG Dryers
I have a discovery 415 treadmill. When I plug it in, I get a clicking in the chest high display. The noise is not coming from the motor but from the control panel.
see the block diagram attached. Unplugeed the machine, and tight every connector going to the display panel. Starting by ribbon cable inside from display board.
2) Reset the machine see your instr. manual for to see where is located the r. button.
3) Test the fuse inside the machine and replace if necessary.
4) Test the REED switch, see the diagram attached, test if for open or defective, clean it, and tight very well the connector, and Try again.
God bless you
Dec 11, 2012 | Exercise & Fitness
Whirlpool gas range f5 code
F5 is a fulty display control board. Unfortunately there is nothing you can do to fix this problem but to order and replace the display control board.
Here is the board to order.
Dec 02, 2012 | Whirlpool GS563LXSS - stainless Steel Gas...
AKAI LCT37Z6TA TV Issues
Sounds like the main board as it has all control and signal processing on it.
May 16, 2012 | Akai Televison & Video
No lights on whirlpool quiet partner ii -- is it dead?
The main board sends power to the display lights. Check with a multimeter for voltage coming out of the main board to the display board. If no voltage the main board is bad or the fuse is bad.
Nov 25, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
While installing a driver for windows 7 the printers display was showing init and while it was doing this we had a power failure. now the printer display comes up with nothing. I dont get any power light...
Mean engine test is OK, so no problem with DC controller, reset display cable remain same? replace formatter assm.. Its not related with drivers issue.
Sep 08, 2011 | HP Color LaserJet 2600n Printer
Can't reset the control panel- keeps blinking on the heated dry setting, and hitting the "start/cancel" button does nothing!
It sounds like your heating element or the control board is out. You can ohm check your heating element to find out if it is bad, but without test equipment, you can't on the control board.
Jul 14, 2011 | Dishwashers
My customer explains that water got poured into her HP LaserJet 4200, now it won't power on, no display, no engine noise, nothing. I have replaced the large power supply on bottom, and the fuser,...
I have had this problem before and replacing the high voltage board ( that is the large board situated under the printer ) fixed it. However if you have replaced this board then I would agree that the water also took out the DC Controller Board.
The fuser probably did not need to be replaced.
May 26, 2011 | HP LaserJet 4200 Printer
665.68601890 Acts as though it is not receiving power but breaker is not thrown. Is there an internal reset. Nothing responds - no lights, fan or microwave. Panel is black and non responsive
ther is on most microwaves a fuse inside usually located behind display panel located in a fuse block or will be on the control board itself.. normally a 20 amp fuse...try that first if not then make sure you have power to control and if so and no display most likely the display control board...
may luck out and be just the fuse though....good luck
Jan 08, 2011 | Kenmore Microwave Ovens
Refrigerators Logo
188 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
