Question about Lenovo ThinkPad T400 PC Notebook
Reformat my taskbar keep bli nking
Electric range lights keep nking
Here is a link. On the right side of that page is a link to contact Kenmore for assistance with their products. Good luck.
Mar 29, 2014 | Kenmore 30" Slide-In Electric Range...
My compaq presario wont let me see my tabs, it will not show if i bring thre mouse to the bottome
By tabs, I assume you mean "taskbar". On your keyboard is the windows flag....between Ctrl & Alt. Hitting that should make the taskbar pop up.
You can then change your settings to keep the taskbar always visible.
If you taskbar is not longer on the bottom (on the side), click & drag it to the bottom.
Oct 11, 2013 | Compaq Computers & Internet
Need to move start button
You should be able to click anywhere on the taskbar (that is unoccupied by icons or links) and drag it back to the bottom.
To keep it from moving, you can right click on the taskbar and hit 'Lock Taskbar'
Jan 15, 2013 | Computers & Internet
When the security light keeps bli.nking,it will not start. I have had a computer and instrument panel circuit board installed,still nojoy!
this car has what we call a VAT's key security system. the most common problem with this system is that the resistor that is in the key looses it's resistance value and the security system no longer accepts it. as a locksmith I run into this very often and the fix is very simple but needs to be done by a locksmith or a mechanic that knows what they are doing.
the fix requires the teardown of the steering column and fitting ( hard wire ) of a resistor with the correct value directly to the ignition switch itself,, this basically bypasses the key security part of the system and from that point on you will be able to use just a regular ignition key ( flat key NONE VAT's key ) which will save you a lot of money in time when getting copies made, ( regular keys cost about $2.75 -- VAT's keys cost around $29.95 per key ).
seek out a local automotive locksmith or mechanic and tell him what you would like to have done and for about 85 dollars this fix can be done ( the cost of the resistor is about 5 dollars ).
this will solve your problem.
c...
Jan 04, 2011 | 1998 Oldsmobile Achieva
Windows Vista Taskbar gone
Do you have an antivirus installed. if not, install it and scan your machine. also try starting your machine in safe mode and see if task bar will come. if it comes, then just repair your windows installation using Cd. no need to format.
Regards
Dec 08, 2009 | Computers & Internet
My whole taskbar is not visible
If you move the mouse pointer to the very bottom of the screen, the taskbar should pop up as it does when you press the Windows Button, but without Start. If you want to keep it up, right click on the taskbar and select "Properties" In the new window, "Unselect" "Autohide" and the taskbar will stay up.
Jun 11, 2009 | Microsoft Windows XP Home Edition
Taskbar keeps flickering in windows vista
Possible vga driver fault, update graphics driver.
May 27, 2009 | HP Pavilion a705w PC Desktop
Clunking in front end when rocking side to side
Go to an alignment shop. Sounds like tierod ends or ball joints. They will yank on them before an alignment to check play. Do not wait too long.
Apr 26, 2009 | 2004 Ford F150
Lenovo ThinkPad T400  PC Notebook Logo
52 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
