Pyleaudio monitor not switching on when on and off button it beeps
    Top Expert:
  • 12,223 Answers
Test using the software diagnostic coming with the factory. or dwonload from your manufacturer supplier.
God bless you
Posted on Jul 20, 2013
My monitor has a steady beep every min or so and the menu buttons are not working, ive checked wiring and voltage all is good. any ideas on how to repair?
Check to make certain that the the "12V is not intermittent", another possibility is that the "soft switch" circuitry may be malfunctioning which if there's an intermittent "make /break" contact could cause the symptom you described; in that case a repair would be needed to rectify such a condition in the circuitry.
Jul 03, 2015 | Pyle PLCM7200 Car Monitor
PYLE 1600 AMP Hookup Diagram
Hello
Get into this link. You can download the manual for your Pyle amp. You can see all the details about its connections there.
www.pyleaudio.com/manuals/PT24-28.pdf
www.pyleaudio.com/manuals/PZR600.pdf
Dec 18, 2011 | Pyle Car Audio & Video
Monitor and base are plugged in but the monitor continues to beep. We have tried to change channels but it still beeps. Please advise.
I realize this original post is old, but just incase someone is looking for solutions, I will put what worked for me. I have the T4841, and had the same problem. No matter how close or how charged the battery, it kept beeping saying out of range even though it was only a week old. I got it to work by pushing the reset buttons on the monitor and receiver at the same time. The reset button on the receiver is on the back (tiny hole with black button - a pen tip fits nicely). The reset on the monitor is on the left side just about halfway up - right below the light button. Hope this helps!
Jun 27, 2011 | Fisher Price Dual Private Connection...
I have a Graco baby monitor, it started making a noise for the last 2 days, could it be a battery problem (even with power connected)? The monitor is about 1.5 years old.
Annoying! happens to us too frequently, but this works. We ended up buying a new one and returning our broken one after owning for three months From Manual:) 5. Turn on the Nursery Unit using the On/Off switch on the side. The green power light should come on. 6. Within a few seconds, the Parent Unit will lock on to the Nursery Unit and the top four (4) green LEDs will shut off. A second later, you will hear a series of beeps and the connection LED should change from red to green. Your monitor is now ready for use. 7. If the top four (4) LEDs do not shut off, power off the Parent Unit and the Nursery Unit and repeat steps 4 and 5 above. 8. If the connection LED on the Parent Unit does not change from red to green and the unit begins to beep, press the channel "ch" button on the Nursery Unit. Within a few seconds, the Parent Unit should lock in on the Nursery Unit and the connection LED should change from red to green. You may hear an audible beep during this process. 9. If the Parent Unit is still unable to lock in on the Nursery Unit (connection LED will be red and the unit will beep), power down both the Parent Unit and the Nursery Unit. Wait for 10 seconds then hold the volume down button on the Parent Unit while pressing the On/Off switch. When the unit powers up, you will hear a single beep and all of the soundlights will illuminate. Release the volume down switch and within 2 seconds you will hear two beeps and all of the Sound Light LEDs will stay lit and the bottom LED will be red. 10. Repeat steps 5
Oct 12, 2010 | Graco Baby Care
Why does the monitor continuously beep? It has a
May 16, 2010 | Fisher Price Long Distance 900mhz Baby...
No monitor display just blinks every 2 sec.
Check if you have several connectors for monitors, and if the cable is plugged in properly.
In case the monitor has a cable with removeable connector, check if that side is plugged in properly as well.
If you use onboard and graphic card together, try to switch from what you try to use now, to the other one (ex. using GFX card now, switch to onboard connector if available, and see what happens). In case your pc/laptop is in standby, push the power button for a second.
If your pc beeps on startup (that's called post signal), consider the mainboard manufactur for the beep code (a few short and/or long beeps). For example, a common but not obvious reason for this problem can be not properly installed RAM. If all that doesn't help, check if the monitor works on another computer. If not, then it might be broken or might need a new cable.
Dec 28, 2009 | Microsoft Windows 7 Ultimate for PC
Computer won't boot , constant PWR problem (
i am also using same motherboard dg31pr intel but it does not reboot .......
because this is the problem with you monitor , just you change the monitor and try again .
this is only the solution to solve this as the tecnition said me.
Mar 20, 2009 | ASUS A7V400-MX Motherboard
PC keeps beeping when plugged in and wont start.
mite b your prossesor chip. also make sure that u have nothing pluged in to any of the usb sockets.
Jun 23, 2008 | Packard Bell iMedia SL 9553 (P660401806)...
Computers & Internet Logo
David Payne
David Payne
