Question about Audiovox Richmond 6G40-36F 6-Year Tall Gas Water Heater
How do I reset the FVD?
7 blinking blue flashes, then 3 second delay and starts flash ing again.
  • Greg hill Jul 20, 2013
    NOT THE UNIT LISTED ABOVE! It is a Richmond PowerVent short model 6GR40PVE2-40.
  • Audiovox Master
  • 5,089 Answers
Copy following links for Richmond/Rheem FV to identify gas control valve and options for replacimg TRD glass vial:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add comment as needed
Gene
Posted on Jul 20, 2013
My rheem 40 gallon gas residential water heater turn off n i smelled gas i relite the heater n its red light is flashing 7 times slowly but it is on now
Seven (7) blinks every three (3) seconds
Combination Gas Control failure Contact a qualified service technician.
Nov 21, 2016 | Rheem Water Heaters
How to fix my Worcester green star ri boiler?
The gurgling sound sounds like you have gotten air into the system. Try purging the air out at the bleeder valves. Also check and make sure that your water inlet is working.
May 29, 2016 | Water Water Heaters
Reset lock out due to fvd
You can reset some models.... depending on gas control valve and FVIR design.
Some newer models you replace the sensor located on outside of tank.
http://waterheatertimer.org/How-flammable-vapor-sensor-works-Therm-O-Disc-25VS.pdf
Gene
Jun 04, 2014 | Rheem 40 Gallon FVR NATGAS Low WATER...
How do i reset the lockout
Push and hold the button for 60 seconds. It is in customer lockout because it was pressed more then 3 times.
Apr 25, 2014 | Honeywell R7184A1026 Electric Oil Primary...
Rheem 42VP50FW flashes 2-3 (FVD Interface/miswiring) wont ignite
Your safety device is probably sensing humidity as vapor. That's what ours seems to do. The replacement FVD is Rheem AP13447-3 Flammable Vapor Detection Sensor. It's down near the floor, can be pried off with a screwdriver, and unplugged. It needs to be replaced, since the heater will not ignite if its unplugged or too high resistance (detecting gas, or, if broken, moisture after a rain).
http://www.amazon.com/gp/product/B007IB22NM
Jan 02, 2012 | Water Heaters
FVD interface failure is flashing. How do I reset the water heater?
Is it flashing 2-3? Try this: You can reset the control by unplugging the blower during start up, leave unplugged for at least 5 seconds, plug back in and within 30 seconds cycle temp control from hot to low 6 times.
Nov 06, 2010 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Whirlpool Energy Smart Water heater - light is solid green then every now and then blink a couple of times then go solid again.What does this mean?
2 flashes = high water temperature (the water heater comes set at 120, and you can set it lower or higher)
3 flashes = sensor failure (temperature sensor similar to a thermostat on regular water heater)
4 flashes = upper element
5 flashes = lower element
Links below are for Whirlpool manuals
http://www.whirlpoolwaterheaters.com/support/Manuals.aspx
http://waterheatertimer.org/pdf/Whirlpool-energy-smart-electric-manual.pdf
The water heater is working right now.
If the elements go out, they are available at any hardware store.
The temperature sensor is easily replaced and can be ordered from Whirlpool.
You might want an extra temperature sensor on-hand so repairs are not delayed.
Link below shows the product in detail.
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
Let the water heater do its job until it fails.
Oct 22, 2010 | Water Heaters
Whirlpool energy smart water heater
Two flashes means that the high limit temperature has been reached. Once this happens, the temperature control system will shut off. Make sure that all element access doors are in place. Push the "Push to Reset" button to restart the temperature control system. The water heater will self test for ten minutes before it will start to heat. If you get the 2 flashes again then you may need to replace one or both elements. Each element should measure 5-25 ohms.
The "thermostat" is the knob marked "Temperature Control". Make sure that the operating mode is set to 1,2 or 3.
Dec 02, 2008 | Water Heaters
Audiovox Richmond 6G40-36F 6-Year Tall Gas Water Heater Logo
301 people viewed this question
Top Audiovox Water Heaters Experts
paulcarew
jdthefixer
Richard Lindsey ...
Are you an Audiovox Water Heater Expert? Answer questions, earn points and help others
