Grundig gu19wdvd10 Can't get TV or DVD to operate. Blue led light continuously flashing
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Flashing of power light indicates a n internal circuit fault. A continuous flash might have due to the block of it SCL-SDA bus, and is related to its main digital board. If you wish to get some more details about the blinking codes, check the site linked here. It has details about blinking codes to many brand TVs, including Grundig. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Mosaic /Timeslide option.
Posted on Jul 21, 2013
The sky remote will not operate the volume on my grundig gu22dvd have tried all the usual things codes etc but still doesnt work
Try an auto search with the remote, you might have already tried it :
1. press tv
2. press select and the red button simultaneously untill the LED light flashes twice
3. Then keep pressing the TV and Standby buttons one after the other (not at same time) until the tv swithches off, then press select to store the code, the LED should flash twice to confirm this.
Once you have the remote working the TV, you can get the remote blink back the TV code so you can write it down for future reference.
  • Press the TV button on the Sky remote
  • Hold down Select and the Red buttons together for approximately two seconds until the LED blinks twice
  • Key in 9, 9, 0
  • Key in 1 on the numeric keypad and count the number of times the Red LED blinks. This is the 1st digit.
  • Repeat for 2 and 3
  • Note: no Blink = 0 (zero)
Sep 09, 2014 | Grundig GU22DVDPX 22 in. LCD TV
Have grundig gu22dvd tv and can not get volume on the sky remote have tried the normal things and have code but still doesn't work
1. press tv
  • Key in 9, 9, 0
GRUNDIG TV
Could be an open internal fuse or power supply failure
Aug 03, 2017 | Televison & Video
Grundig Xephia 42 in.stuck on stand by
Probably the internal power supply has failed.
Nov 22, 2013 | Grundig Xephia 42 in. EDTV-Ready Plasma TV
The TV doesn't start, the RED led flashes a click sound is heard and then LED switches off. This goes on and on and on
The problems starts from the power unit, on this board, the voltages needed to operated TV normally dropped down very low.And one of the power resistor/ Integrated Circuit burned.
To fix this,you need to find someone who capable to repair this board or took it to service center.
Aug 23, 2011 | Grundig Xephia 42 in. EDTV-Ready Plasma TV
Why does the Grundig GUD1500 not switch on. The
Mines has started doing the same mate, piece of junk that it is.
Feb 10, 2010 | Televison & Video
When I turn on the TV the blue indicator light comes on but there is no display, then the blue light starts blinking.
The following steps should be able to correct the problem:
1) Unplug the TV or remove AC power from the TV
2) Count to ten and then plug in the TV
3) Locate the [Menu], [VOL-] and [Power] button on the TV’s side panel
4) Using the buttons on the TV’s Side Panel, press and hold both the [Menu] and [VOL-] buttons.
5) While holding those buttons, press and release the [Power] button one time and count to 3 before releasing the [Menu] and [VOL-] buttons.
6) The TV’s lower left Blue Power LED will come ON.
7) Wait 30 seconds. Confirm that the blue LED on the Lower Left of the TV (not the iPod dock for iPod models) has remained ON during this time.
8) Press the [Mute] button on the TV remote twice
9) Unplug the TV or remove AC power
10) Count to ten and plug the TV in
11) The TV power should automatically come ON and the blue power LED with be ON
12) Wait 40 seconds and the TV picture should appear
13) You can now continue using your TV.
14) If the picture does not appear, power on the TV manually:
· If the LED begins flashing, unplug and power ON a second time.
· If the LED begins flashing again, power ON the TV without unplugging
If the LED begins flashing again, contact us directly by phone to obtain a local authorized service center for you.
If the TV does power on, please reply back with the software version number for us to research this issue. Please follow these steps to obtain the software version number:
1) Press the [Menu] button on the remote control.
2) Using the arrow keys in the center of the remote, scroll over to the "settings" menu and select the [OK] button on the remote
3) Scroll down to "system info" and select [OK] button on the remote
Dec 19, 2009 | JVC Televison & Video
I turn on the T.V. and the blue light is blinking and the T.V. doesn't turn on
1. simultaneoulsy press and hold [menu] and [vol-] on TV side panel
2. press and release [power] on TV side panel
3. count to 5 and release[menu] and [vol-]
4. TV should have turned on
5. if not, unplug TV and press[power]
6. repeat from step 1 if the TV does not power on the 2nd time
Jul 10, 2009 | JVC LT42P789 42 in. LCD TV
Blinking green light on front of ws55909 projection tv. have reset it by both unplugging and pushing reset button. light continues to flash. has for 2 days. can't operate tv
do this press and hold device and menu button on the front of set.. this is to retrieve a to digit error code flashed by the leds. also this set neds to "boot" let the led flash for at least 70 seconds. if it continues to blink the tv failed to boot. There is service bulliteens that states capacitors in power supply can be bad. this capacitors are kinda hard to get to and rather invovled to replace
Jan 15, 2009 | Mitsubishi WS-55909 55" Rear Projection...
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
Electro Med Services...
