U verse says to press ok on the remote to watch tv. I did and still no tv. I can't access the menu help button either.
    Top Expert:
  • Televison & ... Master
  • 74,106 Answers
Check the remote control set for an other set-up codes to your brand TV. some codes might give you prefect results. Choose a code that gives you maximum functionality. Never expect all buttons will work as they should intended to; with a universal remote control. Choose one that give you maximum functionality. That's all. If you wish to get more details about the set-up codes and set-up procedure, check the sites linked here. http://electrohelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Mosaic / Timeslide option. Try this link too. http://remotesearch.blogspot.com/
Posted on Jul 21, 2013
snakehead
  • 1074 Answers
SOURCE: Is there a way to access the T.V. menu without a remote?
YES YOU HAVE TO PRESS THE CHANNEL UP AND VOLUME UP TOGETHER OR THE CHANNEL DOWN AND VOLUME TOGETHER.THEN THE MENU WILL APPEAR AND DO WHAT YOU WANT TO AFTER,GOOD LUCK
Posted on Mar 26, 2007
  • 13 Answers
SOURCE: jvc remote control
"i already paid for the tv so why pay for something that should be readely available to me in the first place I should have access to all the features on the tv ".. WRONG!!!!!!!!!You should have a warranty for this TV but it's old , anyway. First,receive a reference image (let's say CNN).Second:press "Sleep Timer" key and set the value to "0". Then press "Display" and "Video Status" keys at the same time. Third: use "Vol +/-" and " Channel +/-" to select "2.DEF(D)".Go to "D03: V.SIZE" and modify step by step the value for best fitting. There is also switch " SW401" on the main board for centering the image . Finally, press "EXIT" key till you exit the "Service Menu". Don't try to modify anything else!!!!!!!!!!!!!!!!!
Posted on Nov 20, 2007
  • 1694 Answers
1) Check for add / erase recessed buttons on set
2) Or consider buying a Sony universal remote for ten bucks
For further help,please supply model number from back of set
........................T.
Posted on Dec 08, 2007
SOURCE: LG RU-27FB30C. It's blocked.
http://www.newtvremotes.com/Mfrs/Zenith/ZenithTV/LP702.htm
VISIT THE ABOVE LINK AND ALSO SEARCH
RU-27FB30C on internet and you will get the manual
Posted on Mar 12, 2009
SOURCE: Phillips PC7225 Menu
Found it!
I have a Philips universal remote. After trying half of the codes for Philips TVs, I came up with one which allowed access to the SETUP menu. It was 0621. This allowed me to run the auto channel setup, as well as fix some of the other functions. I don't know if this works with all remotes, but if you try different codes, you should get lucky. I'm sure it helps if you have a SETUP button on your remote.
Posted on Mar 22, 2009
How to Program an At&T Uverse Remote Control?
Turn on your U-verse TV, press Menu on your U-verse remote ,
select Help, Information, and then Remote Control Setup. Next,
select your remote control from the TV onscreen list. Refer to
your specific remote for TV/device setup options. Select Top Ten
Brand Setup, Automatic Code , Learning Mode, or Manual Setup.
Oct 19, 2016 | Televison & Video
I can't access setup mode on my LG 50PQ60D I have unlocked it the icon is ther but it won't let me get to it so I can't program any tv all I can do is watch DVDs help plz
hi you could try a factory reset, press menu on the remote and menu on the tv and the same time, this should bring you into the service mode select option click onto reset, if the menu on the remote and menu on the tv doesn't not work, press ok on the remote and ok on the tv hope it works
regards
shaun
Apr 03, 2014 | Televison & Video
How to reset a password on vizio p42hdtv10a tv i forgot the passwored
Hello
To change password use the number pad and type '0000' or whatever password you have changed it to previously, then press OK.
Actual proceedings are:
[1] Press the MENU button to open the main
On Screen Display (OSD) menu.
[2] Press the [
three times until the Parental Control
menu opens.
[3] Press the [Down] button on the remote control
to highlight Parental Lock Enable. The
"Key-In Access Code" window opens.
[4] Use the number pad to type the default
password (0000) or whatever password
press OK.
[5] Press the [Down] button on the remote control
to highlight Access Code Edit.
[6] Press the [=>] button on the remote control
to enter the submenu. You will need to
use the number pad to type default (or
what you changed to previously) password
first
[7] Use the number pad to type the new
password.
[8] Confirm the new password by retyping it.
[9] Press EXIT button on the remote control immediately to exit the OSD menu
Jul 29, 2011 | Televison & Video
Can't find a code for my ATT Uverse remote. Bought the set in China and brought it back to the US.
Hi! Welcome to FixYa!
You can program your AT&T U-Verse remote control using the Automatic Code Finder. This step cycles through all possible codes for the type of TV you are programming until the correct code has been found. Please follow the steps bellow.
  1. Make sure that the TV you want the AT&T U-verse remote control to control is ON.
  2. With your TV on, PRESS AND HOLD DOWN, the TV Mode Key on the remote control. The mode keys are located at the top of the U-verse remote control. While holding down the TV Mode Key, press and release the OK button. If done correctly the Mode Keys will blink twice. The remote is now ready to be programmed.
  • The next step is to enter the code for the automatic code finder feature. That code is 922. Enter the code 922 using the Remote Control's keypad. You have 10 seconds to enter this code before the remote times out. When 10 seconds have elapsed the Mode Keys will flash once. If this happens just start over.
  • Next steps is start the automatic code finder search. Make sure you aim your remote control at your TV. Then press and release the play button on the remote control. Now press the Fast Forward key multiple times until the TV turns off. Then press Enter to save the code. Your remote now has the correct code. If done successfully the Mode buttons will flash three times. Press the Power button again to turn on your TV.
  • When the code has been entered correctly, the appropriate Mode Key will flash three times. To check to see if this code works, press the Power button. If the TV or DVD does not turn off, then we need the correct 4-digit code of your TV.
Please refer to the image bellow.
Thank you for using FixYa! Keep me posted. :)
Mar 12, 2011 | Televison & Video
How do you set up the Soya TV. Is it cable ready?
Yes, your TV is cable ready. To set up, you will need to use the original remote and complete the following steps.
1. Connect your cable box to your TV using either antenna (RF) cable or component A/V
2. Press the "MENU" button on your remote
3. Select "CHANNELS" using the up/down arrow buttons on your remote and press "OK"
4. Select "SCAN CHANNEL" and press"OK".
5. Select "CABLE" as the source and press "OK" to tune
The TV should now automatically tune the cable stations and exit the menu. If you need to exit the menu and/or start again just press "MENU" on the remote again.
If you have no picture, press the "INPUT" button on your remote repeatedly until the input is on "TUNER" if you are using an RF cable or "COMPONENT" if you are using component A/V cable.
Your TV should now be setup for watching cable.
Please post back if you need further assistance.
Regards,
BElectric
Dec 05, 2010 | Soyo MT-SYTPT3218AB 32 in. LCD Television
I'm not able to put the tv in video mode to watch dvd's and I do not have a remote control for the tv.
Hi, well ALL TV's can be controlled from the Buttons ON the actual TV itself, look carefully on the TV, you will find a set of buttons, usually about 7. They should be marked, ON/OFF, CH UP, DOWN, MENU, ENTER/OK/SELECT, VOL UP/DOWN. Now Multiple presses will access differing features on the set, usually after pressing the ON/OFF button, you press the menu button and select your Input, Tuner, external, etc, once set, you Change the channel with the UP/DOWN key, and the Volume with the -,+ Key.
It's all in the user manual in the download link below.
http://www.devicemanuals.com/guide/Television/Sylvania/Sylvania-6420FB-20-TV-User-Guide-TmpJek9UZz.html
Sep 09, 2010 | Sylvania 6420FB 20" TV
I have ATT u-verse remote, but I don't have code to control new Hannspree 32inch lcd tv. Can you help?
I also had this problem. I talked to an AT&T technical support guy over the phone yesterday, and he told me some weird instructions. The TV was responsive to the controller but we couldn't get it to work. About an hour ago I called Hannspree technical support and they told me codes to control my AT&T receiver with their remote. I just tried the codes for my AT&T U-verse remote, just to see if they would work anyhow, AND THEY DID! Unfortunately, the codes will control the TV entirely, except turning it on.... (it does turn it off though) If these codes are of any use to you, they are: 1004 and 1018 try the first one, and if doesn't work, try the second one. If you are new to the AT&T U-verse world, these are the instructions: *Turn on your TV first 1)Hold the TV button on the AT&T remote 2)While holding, hold the OK button 3)Now release both of them 4)All the mode buttons while now flash twice (You will now have 6 seconds to do step 5, if not they will do a long flash, indicating to start over) 5)Now, quickly, type in the combination (in this case, 1004, or 1018) 6)The TV button will flash 3 times if it works, or a long flash if it doesn't 7)Now point the remote to the TV and press Power. If it turns off, IT WORKED! *Remember, these codes are the only codes I know of and they took forever to find, and they aren't supposed to work with the AT&T U-verse remote, but they did. The only defect is you can't turn ON the TV with the AT&T U-verse remote, but you can do everything else (YOU CAN TURN IT OFF)
Hope this helps!!!!
May 10, 2010 | Televison & Video
Can the service menu for the LG 52sz8d dlp tv be accessed from the orig remote not the service remote just installed new lamp and tv was working fine for 1 week now the lamp indicator light comes on and...
One possible solution to access the service menu on LG tv's is as follows with steps 1 - 4:
1. With the TV on, press and hold the MENU button on the TV front panel.
2. While holding that button, press and hold the MENU button on your remote.
3. Hold both buttons for ~5 seconds until the service menu comes up on the TV.
4. Release the remote MENU button first, then the TV MENU button.
If you are looking to reset the lamp indicator then continue with the following steps 5 - 11:
5. Press and hold the ENTER (or OK) button on the TV front panel.
6. While holding that button, press and hold the MUTE button on the remote.
7. Hold both buttons until the Lamp Life Hours show up on your TV screen.
8. Release the MUTE button first, then the ENTER button on the TV front panel.
9. Make a note of the lamp hours if you want.
10. To reset the lamp hours, press the SELECT button (the one between the four arrow keys with two concentric circles on it) on your remote.
11. It will ask you to confirm the reset--press SELECT again to confirm.
To verify you've reset the hours, you can repeat steps 1-9 above and then just press the EXIT button on your remote.
Hope this helps. Regards, James.
Apr 22, 2010 | LG 52SX4D 52" HDTV
TV only works on HD stations
Your TV has an SD/ED component input and an HD component input. You are using the HD input. It can only accept HD signals. You need to correct the settings in you cable box. You need to "fix" the video output so that it converts everything to HD. If you have a motorola box, you can usually turn the box off and press the menu button to access the cable box setup menu. Set the 4:3 override to Stretch or Full. If you need more help with this, post back with more information: cable provider, cable box used. I hope this was of some assistance.
Mar 28, 2010 | Samsung DLP HL-P5663W 56" TV
TV service menu
press OK on the remote and OK on the TV panel at the same time, after 5 to 10 seconds, the service menu EZ adjust should appear.
another step is to press menu on remote and menu on tv at the same time..
Feb 01, 2010 | Televison & Video
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
