Question about Coleman Heating & Cooling
Need some answers for a Coleman Evcon central air unit, Model number BPCH0361BA.
Just acquired a Coleman Evcon central air unit, Model number BPCH0361BA. Could you please tell me the BTU's and type of refrigerant used for this model?
    Guru:
  • 587 Answers
It is 36,000 BTUs and it is R-22.
Posted on Apr 05, 2016
chillmaster
  • 104 Answers
SOURCE: i have a coleman evcon
R-22
Posted on Jun 23, 2008
SOURCE: coleman evcon central unit outside
compressor shuts off when outside tempature drops.
Posted on Jun 30, 2008
SOURCE: Coleman Evcon whole house central
How do you replace the webbing around the coil's
Posted on Aug 14, 2009
  • 146 Answers
SOURCE: My Coleman Evcon heating and air unit will not blow air
bad blower motor. recommend a new blower motor and capacitor.
Posted on May 28, 2010
  • 5096 Answers
SOURCE: What does the "dry mode" mean in a Hampton Bay air
The "dry mode" dehumidifies the air. This is useful when you do not need to cool the air but the relative humidity is higher than you want to have inside. You get the advantage of bringing in the fresh air without increasing the indoor humidity.
I hope this helps.
(this applies to all air conditioners with a dry mode)
Posted on Jun 19, 2011
Hello. I would like to know how many ton my Coleman Central Air Unit is. The model number is 'ERCS0241BBB". The serial number is "WOD7699360". Thank you.
This is a 2 ton A/C I got that from the 24 in model number it means 24,000 btu which equals 2 tons cooling. If this helps please rate me and do a testimonial.
May 23, 2011 | Coleman Heating & Cooling
I have a coleman evcon system model BRHQ0301BC. The fan on the outside unit will not always kick on. When the fan does not kick on the AC does work. Need a manual for unit and help repairing the proiblem.
I don't have a manual but you need to check the fan capacitor and the fan motor windings with a multimeter. If the capacitor looks swollen then it is probably bad. Replace it with one of the same rating.
Jun 07, 2010 | Coleman Heating & Cooling
May 28, 2010 | Coleman Heating & Cooling
Need to know how to fill my central air
don't you really need to be trained. You need to evacuate the system pressure test possible install filters and finally weigh in the charge. The ref. on most systems is 22 or now 410a. get help
Aug 13, 2009 | Kenmore 72187 Air Conditioner
There is not an air filter in the unit and we have just purchased the home with the unit in it. I need to know where the filter goes, Tjis a coleman evcon central air unit
You should be able to open the lower panel on the Central Furnance unit and the filter would go against the side where the main cold air return plenum is located. There is usually either a slot/edge for the filter to slide into, or a set of clips or a wire spring that holds the filter in place, preventing it from getting sucked into the squirel cage blower.
If you want to give Coleman a call at 1-877-726-5362, I'm sure they'd send you a owners manual for your unit so you can see what periodic cleaning and such is needed to keep it working properly.
Hope you found this info helpful. Best Regards!
Aug 05, 2009 | Coleman Heating & Cooling
Coleman evcon blower not working properly
My Coleman Evcon ac unit,heater and blower does not work.not even the outside condenser comes on.Any ideas on what is the problem?
Jun 22, 2009 | Coleman Heating & Cooling
Coleman Evcon..... Inducer Adjustment
Just wanted to make sure you knew this model is on a recall list:
http://www.dgatprogram.com/
Dec 10, 2008 | Coleman Propane Forced Air Heater...
Coleman evcon central unit outside fan wont come on is very hot
Jun 05, 2008 | Heating & Cooling
Coleman Evcon model DGATO70BDC Starts to run then stops?
What you have is an ignition problem and your unit is shutting down on safety.
May 01, 2008 | Heating & Cooling
Heating & Cooling Logo
258 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
