Question about Troy Bilt 175HP Manual 42" Riding Mower
Belt diagram my idler spring is broken on model #13an77kg011 , where does it go ?
    Problem Solver:
  • 17 Answers
One end hooks to the idler pulley arm, the other hooks in a slot in the deck.
Posted on Jul 20, 2013
Need diagram installation. A drive belt.
If you have a Craftsman, under the seat is the model number. Go Here to get the operators manual. The manual will have all the belt diagrams. Water Filters Lawn Garden Appliance Parts
Oct 14, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Wheel that turns the drum has come off. How do I fix it and where does it go?
Every dryer I ever worked on had a belt that turned the drum. There is a motor with a pulley, a spring loaded idler pulley, and a belt. Look around for a broken belt and replace it, if it is broken. It might have just slipped off the idler pulley. If it has slipped off, re-install it the way it goes. Look in your owners manual for a belt diagram for your dryer. Sometimes, they are pasted on the inside of the dryer case. I hope this helps. Garcuda
Sep 04, 2014 | Dryers
A diagram of deck belt on deck 46 inch cub cadet
Look here then when you put in your Model number look under ATTACHMENTS for a parts diagram showing the Belt layout
http://www.cubcadet.com/webapp/wcs/stores/servlet/ARIPartFinderView?storeId=10051&catalogId=14101&langId=-1#/s/CUT/782/
Jul 27, 2014 | Cub Cadet Garden
How to replace belt
SWISHER 44 Finish Cut Trailmower Tension assembly belt bra Parts Model...
If you look at the diagram ( zoom in) part #94 , idler spring, is what puts tension on the belt.
Jun 07, 2014 | Swisher 44 Iinch 11.5 Hp Trailmower...
Husqvarna power belt loose how to tighten
Parts and Diagrams for Husqvarna 2042 LS 96043006200 2008 11 This link will provide diagrams of the drive belt and associated parts. The diagram shows the idler pulleys and tension springs. Inspect your mower to compare all drive parts to the diagram. Hope this helps....
Mar 23, 2014 | Husqvarna Garden
I'm attempting to replace the primary belt on a John Deere x500 w/ 54'' deck. Is there a pully adjustment or do I just ''force'' the belt onto the pulleys?
There is an idler pulley that puts tension on the belt. You unhook the spring from the idler arm, put the new belt on (it will be loose, not tight) then hook the spring back onto the idler by pulling hard on the spring with a pair of visegrip or channellock pliers. Here's a parts diagram. Good luck! Please rate my solution if helpful, thanks.
Aug 02, 2010 | John Deere Garden
Ineed to replace the serpintine belt, mine shreded, went and purchased replacement from lordco auto parts, could not seem to get belt to tighten up could you please advise the correct belt part # as well...
There is a idler wheel that has a bolt that when loosened will cause it to spring back. As you lay under the car with your feet first inward ( looking straight up from under vehicle snake the belt through and over the pulleys then pry back with a long pry bar the idler pulley lever after loosening bolt on wheel or lever as you put the belt over the pulleys. I have done this belt on a 1999 528 i it is a unpleasant job without a diagram showing the serpentine pulley arrangement, there is a second idler pulley located slightly higher than the release locking idler pulley don't confuse the two, I would advise aquiring a serpentine belt diagram (cd repair manual on ebay motors) unless you are confident you can figure it out through trial and error.
Aug 02, 2009 | BMW 528 Cars & Trucks
Not sure how to replace the belt in my MTD, Wards snowblower
Remove the housing with the machine off
The idler pulley is designed to push up against the outside of the belt between the drive and motor pulleys when disegaged the belt should look like a loop like a race track
engage the blade clutch and watch to see if it presses up against the drive pully and the motor pulley
their should be a spring attached to the idler arm and i believe the new belt is dragging a little
you should be able to move the belt with your hands ( it should slip freely) rod is engaged or it pulls the idler away
Either a spring causes tension when the rod is engaged or it pulls the idler away
Keep working with it until it is free you may have an adjustment on the spring tension or the linkage rod has an adjustment
I am sure you can do this without an diagram good luck
Nov 18, 2008 | Sport & Outdoor - Others
New dryer belt is rubbing top of idler arm spring
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the next page look for "Dryer Belt Diagrams" under the Special Features section. There is an extensive list of dryer belt diagram illustrations available that you can print out. Maytag is listed. Hope this helps you.
Nov 11, 2008 | Dryers
Troy Bilt 175HP Manual 42" Riding Mower Logo
69 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
