Epson Stylus C43SX InkJet Printer
Problem for Epson Stylus C43SX InkJet Printer
Printer service is over
By dukemiq on Mar 30, 2009
an error occurred while printing saying ''end of service encountered.please contact the manufacturer for replacement''.what does it mean and how can i resolve it? my printer model is epson stylus c43sx.
Solution #1
posted on Mar 31, 2009
Not Rated)
gwbm
Rank: Guru  Epson Expert
Rating: 89%, 158 votes
This usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C4x), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. Check the current count value - if it is greater than the limit shown it will confirm this is your problem. Then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
If this solution helps you, please rate it; if it doesn't, please provide further information by posting a new comment.
Was this helpful?
Yes
No
Popular Solutions for Epson Stylus C43SX InkJet
Questions and Unsolved Problems for Epson Stylus C43SX InkJet
Do you recommend Epson Stylus C43SX InkJet Printer?
Answer
Answer
The printer c43sx cartridge aren't moving properly bothside tell me how can i slove this problem
Answer
Hi, I have Epson C43SX printer; I did not use the printer fro sometime. I changed the Cartridge; but... (More)
Answer
Epson Styus color 440 i just replaced black ink cartridge, printer goes thru all the motions but... (More)
Answer
is there possible solution to reste without software?
Answer
hi! I was printing happily with my C43SX printer at 3 pages of draft output printed successfully,... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Epson Stylus C43SX InkJet...:
Top Printer Experts
Rank: Guru Guru
Solutions: 790
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
