Question about Asko Dryers
Fuse on ASKO dryer Model 7305 is stucked. Do you have a solution on hoe to get fuse out?
  • Asko Master
  • 15,628 Answers
What fuse? There are more than one.
Posted on Jul 24, 2013
SOURCE: how to change dryer belt on Asko 7305 dryer
You have to pull the back off the dryer.Then you,ll be able to see how it comes off.Ussally its on two pulleys similar to a car.There may be a tensioner on it to to keep it from slipping.If there is one you,ll have to losen it to remove the belt & replace it,then tighten the tensioner back up.Ussally you keep about a 1/4" to 1/2" free play on the belt.You use a sraight edge on the two pulleys to measure it with the belt on,tighten belt tensioner till you have the recommended tighteness.
Posted on Feb 19, 2008
  • 530 Answers
SOURCE: asko 7305 dryer keeps tripping
make sure that the heating element is not shorted to the cabinet. Usually when you replace the hi limit you should replace the thermastate along with it. What is the brand of the dryer?
Posted on Jan 04, 2009
heatman101
  • 43501 Answers
SOURCE: Asko Dryer Mod# 7305 Will not come
When that happens the problem is usually with the timer/control unit...
That is usually very easy to replace and can be done by most people.
You can look for the part online and install it yourself...just be careful to mark all wires so that you get them back in the right spots on the new part...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 18, 2010
heatman101
  • 43501 Answers
SOURCE: How do I change the power cord on my asko 7305
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Posted on Jan 03, 2011
  • 2468 Answers
SOURCE: I have an Asko 7305
either the motors overloaded from clothes load size,the motor bearings are getting tight from lack of lubrication, or the dryer heating element is beginning to short out to the case and grounding itself and tripping the fuse
Posted on Jul 05, 2011
I have a Asko 7305 dryer,can I have a regular 240volt dryer cord put on it, so I can use existing wall receptacle ?
I think you are asking if you can change the cord from 220 amp to 110 amp so you can use a 110 wall receptacle...NO you cannot not.It would also probably start a fire
May 13, 2015 | Asko Dryers
Fuse on asko dryer 7305 blows after a few minutes on
I assume you are talking about the reset under the little rubber plug on the back of the dryer? The most common cause for this is the very fine lint filter on these Asko's getting dirty and restricting airflow. It may LOOK clean, but unfold it, scrub the screen with a soft brush and dish soap, on all 4 surfaces then let it dry before using it. If this doesn't solve the problem, unhook the dryer vent and try running the dryer with the vent hose removed from the wall. If it doesn't trip then, you need to have your house vent cleaned out because it is restricting airflow. if THAT doesn't fix it, try removing the lower panel at the bottom, then remove the fan cover (kinda round and all the way to the left behind the panel) and checking to see if the blower wheel is clogged with lint, or if it has come loose and is not spinning at all. One of these is almost certainly your problem, unless this is a condensing style dryer. If that's the case then you probably just need to pull the condenser out and clean it.
Nov 14, 2012 | Asko Dryers
I have an Asko 7305 Dryer that keeps tripping the fuse. When I put a load in to dry, it will run for a few minutes, then stop. I push the black button in the back and it will come back on for a few, then...
Jul 04, 2011 | Dryers
I need a power plug for my asko 7305 dryer and can not find one anywhere
Assuming that you need a 220V connector, they can be purchased at home Depot. They are generally made with about three feet of cable attached. you will have to take the back plate off of the dryer and attach the three leads to the proper termination.
Jan 23, 2011 | Asko Dryers
How do I change the power cord on my asko 7305 dryer?
heatman101
Dec 29, 2010 | Hotpoint NBXR463EBWW Electric Dryer
When drying a load of clothes the dryer (Asko 7305) simply quit and when I came back to the unit the clothes were dry, but the digital panel was dark and no power available to the unit. I have pushed the...
Hello Susan, Welcome to FixYa. Have you checked to see if perhaps one or both of the fuses may have blown at the back of the unit...I don't mean the hi-limit that you already referred to...I mean the in-line fuses the Asko machines are equipped with. Let me know and we can move forward from here. Regards, Macmarkus :)
Sep 12, 2010 | Asko T761 Electric Dryer
Model 7305 - power light comes on when switch is pushed but none of the cycle lights or Start button come on when buttons are pushed
Problem was solved by pushing the very hard to find black reset button in the center of the back of the dryer.
Feb 22, 2010 | Asko Dryers
Installing heating element on Asko 7305
this video might help you with fitting an element
You-Tube video "h_WMwQ-M33A" placeholder (do not delete)
Aug 29, 2008 | Hotpoint NBXR463EBWW Electric Dryer
How to change dryer belt on Asko 7305 dryer
Nov 05, 2007 | Hotpoint NBXR463EBWW Electric Dryer
Dryers Logo
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
