Question about Yamaha 4500 Watt Electric Start Generator - EF5200DE
Oil sae can I use 5w50 synthetic on this generator
  • Yamaha Master
  • 17,093 Answers
I can not see why you want to use that oil. That would be a good oil to use if you have a lot of hours on that engine. Otherwise it is a little high on upper viscosity number unless it is running really hot and I doubt that is the case.
Posted on Jul 22, 2013
I have a gen power gx400i generator 4.0kvaor 3.0kw, 4stoke single cylinder air cooled.I'm not sure what type of oil is needed?
Hi and welcome to FixYa, I am Kelly. Oil changes are supposed to be every 100 hours. You should use SAE 30 WT (non detergent) oil for at least 3 oil changes / 300 hours then 1 cycle of HD-30 WT oil as it does a bang up job of cleaning things out of the crank case and prevention of the oil rings from sticking on the piston skirt. I have made this recommendation for at least 30 years and never had to rebuild a home owner or RV type engine in a unit where it was known the owner did this cycle of oil changes in a generator. (Vavle work yes.. engine bearing and piston rings no!) .. The brand does NOT matter as long as it is SAE 30 WT oil. Lubricants can not get the SAE rating if they do not meet the standards. Just do NOT use a synthetic oil in it.
Thanks for choosing FixYa,
Kelly
Nov 29, 2010 | Coleman Powermate Premium Plus 6250W...
Whats th best oil to use in my gas welder
use a multi-viscosity sae sj grade or better oil. recommended motor oil is 10w-30. if you work in cold environments use a 5w-30 oil . it's thinner and will flow easier during cold starts. synthetic oil is better, just more expensive. do regular oil changes at least every one hundred hours. good luck!
Oct 28, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
What type oil does the Hitachi EC 12 use? Ray
SAE 5W50 and if available use full synthetic.
This link will take you to the EC12 owners manual if you would like.
http://www.hitachipowertools.com/product/files/pneumatics/compressors/EC12__OM.pdf
Oct 28, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Ineed to know what grade oil i need for my 2005 tdi 90 horsepower passat
hi here is a list with the type of engine oil you need also gearbox type as well in case you need that to
Engine
cold climate sae 5w/40 synthetic
moderate climate sae 5w/40 synthetic
hot climate sae 5w/40 synthetic
GearBox Manual
sae 75w/90
gearbox Auto
none stated
hope this helps
Feb 22, 2010 | Volkswagen Passat Cars & Trucks
Oil type for Onan 4000 generator
SAE 15W-40 is what i used to use
synthetic? not sure about that one there may be oil pres switch that could give you a problem.
Apr 04, 2009 | Watts Onan Portable Generator - 4000 ,...
What transmission fluid can I use in my 1993 Mercedes Benz 190E
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......SL
SAE 0W-30 Synthetic Signature Series Oil
Synthetic 5W-40 European Engine Oil
SAE 10W-40 Synthetic High Performance Motor Oil
SAE 5W-30 XL Synthetic Motor Oil
Above 5°F......15W-40, 15W-50
Above -4°F......10W-30, 10W-40, 10W-50, 10W-60
Above 23°F......20W-40, 20W-50
Please don't forget to rate!!!!
Mar 14, 2009 | 1993 Mercedes-Benz E-Class
Lost manual 6250 watt coleman generator what oil to use and were
If it has the Tecumseh engine..
Above 40°F Straight SAE 30W
Below 40°F down to -20°F Straight SAE 10W or SAE 5W30 or
Below 40°F down to -40° SAE 0W30 Synthetic
Using multigrade oils above 32°F will increase your oil consumption. SAE 10W40 is not recommended.
Per the manual, all the oils should be marked A.P.I. Service SL/SJ, but you may have to use something to a newer standard. E.G.: Service SM.
The oil sump capacity is 1-5/8 U.S. Pints or 0.76 Liters.
Hope this helps.
Dec 27, 2008 | Coleman Powermate Premium Plus 6250W...
Yamaha 4500 Watt Electric Start Generator - EF5200DE Logo
57 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
jmt
Level 1 Expert
Craig Butler
Craig Butler
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
