Question about Onan Cummins 7.0 HGJAB-900 RV QG 7000 7000k Gasoline Generator Marquis
Why is my generator just shutting down randomly?
Just shutting off randomly?? I do not know why sometimes it works all day, other times it turns off and wont turn back on.
  • Onan Master
  • 16,231 Answers
It is not the stalling that is the big clue it is the fact that it wont restart after it stalls that is worrisome. The things that you can check are the temperature of the unit. This could be vapor lock due to poor ventilation by the housing around the generator. IT could also be from overheating of the ignition parts for the same reason.
Posted on Jul 22, 2013
Stops generating and just idles
Check if there any alarm on monitor by pressing button several times. It has code like E-number. Replace spark plug, fuel filter. Clean carburator, spark arrester. Check wiring of thermosensor.
Mar 28, 2017 | Honda EU6500iS Inverter Generator
I have a 1994 jeep grand cherokee and it always starts up, but sometimes it just shuts off randomly while I'm driving and after a few minutes of rest turns back on, the battery will still be worki
Install a new crank shaft sensor. I had the same problem with my wife's Jeep. It would run fine fore days at a time then quit. When the crank sensor goes out their is no spark or injection of fuel into the engine. This is a Hall Sensor. They can be intermittent, and affected bu heat. If your Jeep will not start, try freeing the sensor and see if it starts. Cold Freeze is used in electronics to test
Apr 17, 2013 | 1999 Jeep Grand Cherokee
1990 dakota engine shutting down randomly
I had a 1988 dodge Dakota ,and it did the same thing. I fould that the o2 sensor was bad. I am a self employed mechanic
Oct 28, 2012 | Dodge Dakota Cars & Trucks
Kholer power systems generators 18RESL auto shut down code UU
UU is generator under voltage. Check to see if it does it without laod also. if it does you will need a pro to check and ohm the rotor and stator for shorts
Jul 11, 2012 | Kohler Electrical Supplies
Basically runs great...randomly shuts down while
With what you say,get the fuel filter checked.Cheapest and easiest place to start.Its on the chassis rail,back near the fuel tank.Hope this helps
Nov 06, 2009 | 1996 Jeep Grand Cherokee
Hot water shuts off at random times.
yep, got the same problem, try unpluging the unit for five minutes and the reset the temp.
Jun 08, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Ipod touch randomly shuts down
Hello. This is actually a very common problem with the 1st Generation 16GB Touch. It is recommended you do a system restore before these steps, but not necessary.
Step 1.
Go into Settings, and click on the General Tab
Step 2.
Set Auto-Lock to Never
This should keep it from shutting down randomly. If this does not help the problem then it is an issue with hardware.
Mar 24, 2009 | Apple iPod touch
Zenith dlp projection t.v. model#z52sz80 t.v. turns off randomly
This solution is for the zenith 56" DLP. Unplug the tv, either from the wall socket or the TV. While the TV is unplugged hold the power button on the TV for 40 seconds. This lets the excessive power drain from the TV. If this does not work call 1-800-243-0000. This is the number for their help line. This is the fix the tech gave me and it worked right away. Hope this helps and have a great day.
Feb 16, 2009 | Zenith Z52SZ80 TV
Shutting off
i have the same problem...laptop randomly shuts down, but its even done it within a minute of turning it on so i don't think its a heat issue. Sometimes it'll run for over an hour with no problem and never shut down, but other times it randomly shuts down sometimes within a minute, sometimes maybe 10 mins, sometimes 30 mins or more ...its maddening! i'd love to find a solution if anyone's found one. Thanks.
Apr 22, 2008 | HP Pavilion dv1000 Notebook
Onan Cummins 7.0 HGJAB-900 RV QG 7000 7000k Gasoline Generator Marquis Logo
338 people viewed this question
Top Onan Electrical Supplies Experts
Lawrence Oravetz
Jeff Hogancamp
Jeff Hogancamp
Are you an Onan Electrical Supply Expert? Answer questions, earn points and help others
