Question about Lexmark E350d Laser Printer
I have a e350d that when I turn on, just displays a single row of grey boxes and will do nothing. HELP!!!!!!!!!
Fitted new drum and cartridge, but still nothing
    Sergeant:
  • 396 Answers
The printer may have been the target of an electrical event such as a voltage spike or surge, and has been lost. You can try to unplug it from the power, unplug it from the computer, and wait 2 minutes. I usually push the power button on a printer with issues while it is unplugged to make sure it has lost all stored power. Plug it back into the wall and see if it responds to the power button. If the same thing happens, or if there is no response at all, then you may need to replace the printer. Or contact the company that supports it, If it is under warranty, or a service contract.
Posted on Jul 21, 2013
3 Suggested Answers
  • 217 Answers
SOURCE: Lexmark E350d printer - replacement cartridge will not work
Seen/heard this before on Lexmark E350.
First place to look is the cartridge.
One side has a plastic gear which is a push-fit onto the end of the Developer Roller.
The D shape (hole with a 'flat') can lose the flat, or the gear can fracture (usually from one or the corners of the 'flat').
If this is it, the cartridge is faulty.
Posted on Aug 30, 2009
  • 217 Answers
SOURCE: error 31 lexmark e350d
Possible causes here are;
Most likely, the contacts in the printer not touching the chip properly (hence why it works in another printer). A simple gentle 'tweak' would work in this case.
The other possibility is the firmware version of the (offendig) printer being incompatible with the version of the after-market chip you are using. No solution here, other than trying a DIFFERENT MAKE of chip.
Posted on Apr 05, 2010
Where is the drum on the MFC-8860DN and how do I remove it?
The drum is part of the laser toner cartridge
Open the front door
Press the square button in the center of the paper receiving are, it is marked with a small triangle
Press and pull, it will open a door showing the toner cartridge
Pull out the toner cartridge
The top part is black and the bottom assembly is grey
There is a blue little latch in the right side of the cartridge
Press the latch and the toner cartridge will be release
Remove the toner cartridge.
You need to replace the grey bottom assembly with a new one
A compatible assembly, which will have a new drum, will cost around
$30 at amazon an oem around $70
Reassembly and reinstall in reverse of the disassembly
I hope this was helpful
Mar 17, 2015 | Brother MFC-8860DN Printer
LaserJet 2700n New HP Original Black Cartridge fitted. Install black cartridge message still on display.
make sure you have the cartridge fully in. pull it out and put it back in make sure you remove the tape on the cartridge box itself as well. Turn off unplug and reset the printer.
Oct 24, 2013 | HP LaserJet 2700n Printer
A Lexmark printer E350d has a message "photocon". What does it need?
Photoconductor unit (drum unit).
These are available new and remanufactured on internet auction sites.
Note that the photoconductor unit is EXACTLY THE SAME (other than the label and part number) as the one for DELL 1720.
Dec 28, 2009 | Lexmark E350d Laser Printer
Error 31 lexmark e350d
Mar 18, 2009 | Lexmark E350d Laser Printer
Mar 08, 2009 | Lexmark E350d Laser Printer
My Brother 5040 laser printer is printing a bit faint in parts of the page. I have cleaned the rollers, shaken the toner cartridge and replaced the drum unit. The quality is better, but I am still missing...
number one are you using brother oem drum and toner? generic toner will give you all kinds of problems,.. if the the paper is damp or has moisture in it it will give you weird printing , ghosting parts missing etc. good luck brother sr tech
Jan 24, 2009 | Brother HL 5040 Laser Printer
Our xerox M118 showing an error"replace drum cartridge'can any one help me?Plizzz
Hello, Your Xerox has two cartridges - one is the drum cartridge and the other is a toner cartridge. Please check the following I've researched from your user guide:
Replacing the Drum Cartridge
The drum cartridge is a customer replaceable unit. After approximately 55,000 copies/
prints, the machine will display a warning message before the drum reaches the end of
life. Order a replacement cartridge now to insure continuous operation.
Country Part Number for the drum cartridge replacement
All countries 13R589
Removing the Old Drum Cartridge
1. Pull the front cover towards you to open it.
2. Open Tray 5 (bypass tray) if necessary, and then open Cover A while lifting up
the release lever.
3. Lift up the colored lever, and slide the drum cartridge out until you can lift the
handle on top of the cartridge.
4. Hold the handle and remove the cartridge from the machine.
NOTE: When replacing the drum cartridge, make sure that the new cartridge is the
correct one specified for the machine.
Recycling the Drum Cartridge
The drum cartridge is designed to be re-manufactured. To recycle used drum
cartridges, return them to Xerox in the original packaging. Return labels are included
with each new cartridge.
Inserting the New Drum Cartridge
1. Remove the new drum cartridge from the box.
2. Undo the sealing tape and carefully pull out in the direction of the arrow to
remove the black protective sheet from the cartridge.
3. Place the cartridge in position and, using the handle, slide it into the
machine until it clicks.
4. Pull out the cartridge tape completely without breaking it.
5. Push the cartridge again so that it is correctly placed.
6. Close Cover A until it latches and then close Tray 5 (bypass tray).
7. Close the front cover.
Hope this helps. Good luck.
Dec 11, 2008 | Xerox WorkCentre M118 Black and White...
Standard black printing has faded to grey.
Could just be a faulty cartridge?
My hp printer developed a similar fault, and despite all my attempts to clean, realign, whatever, the problem wasn't solved till I fitted a new ink cartridge. It's worth a try.
Nov 15, 2008 | HP Officejet Pro L7680 All-In-One Printer
Eror 31 in lexmark e350d
Error code 31 is displayed when the top front cover is closed and a defective print cartridge is detected. It may take the printer 10-20 seconds to determine if the print cartridge is defective.
Replace and reinstall the defective toner cartridge.
Oct 28, 2008 | Lexmark E350d Laser Printer
Flaws at top of each page when printing
Replace toner cartridge drum is scratched
(Possibly by staple going threw machine if that what each of the five marks look like, all those removed staples always seem to end up in printers)
You can pull it out (I think right top cover opens and cartridge pulls up and to the right)  then .. turn it over and gently pull back cover see drum has same marks as you see on paper, you can gently rotate drum by using gear on edge do not force it only turns easy one way, Do not touch drum surface very delicate and sensitive. Normal disposable item buy a New cartridge here is HP part number for your model  HP C8543X (HP 43X) Toner Cart.
Oct 19, 2007 | HP LaserJet 9040n Printer
Lexmark E350d Laser Printer Logo
23 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
