Question about Coaster Furniture Modern Pendulum Grandfather Clock In Silver Accents And Solid Matte All Black Wood Finish. 900726
Trying to synchronize the time with the chimes on my Coaster 900726 grandfather clock.
2 Suggested Answers
dennis_w47427
  • 232 Answers
SOURCE: I have a Coaster Grandfather Clock. I lost the manual. I need to find out how to reset the chimes.
Hi Wanda....call Coaster Furniture national call center -
1 877 221 9666. They can tell you how to reset the
chimes. Ask them for a manual.
Regards,
Dennis
Posted on Oct 21, 2014
How do I fix the westminster chimes on my grandfather clock
Grandfather Clocks Manual - theclockdepot
www.theclockdepot.com/grandfather_clocks_manual.html
Howard Miller Grandfather Clock Manual by The Clock Depot offering discountGrandfather Clocks. ... The movement controls the hour strike, time keeping, andchime. ..... the hour without the Westminster melody if the other Westminster melody lever is turned to Silent. .... My Grandfather Clock has Stopped, Can I Fix It?
Owner's Manual - Master Clock Repair
www.masterclockrepair.com/ownersmanual.html
Note: The following information will apply to almost all grandfather clocks made after ...(See my article on Clock Myths) It is best if the chains are not pulled so far that the top of .... Some play the Westminster chime only and cannot be changed.
Nov 23, 2015 | RIDGEWAY GRANDFATHER CLOCKS Ridgeway...
How do I synchronize a Grandfather Clock to chime correctly on the right hour?
Count the number of times the clock strikes, while leaving the minute hand pointing at the twelve, move the hour hand ( short hand) to the number it struck. ( this is the only time you should ever move the hour hand yourself). Tighten the hour hand by pressing the hour hand in towards the dial just a little. This can be done by placing a thumb nail on each side of the base of the hour hand at the center shaft. You do not want the hand to touch the dial. Now run your clock up to a quarter after, and let it chime. Now the half hour, the third quarter, and finally the hour. It should strike the correct hour if done correctly. Short version, move minute hand(long hand) to twelve so that it's pointing straight up. 2 move hour hand(short hand) back one hour. 3 tighten hour hand by pushing in toward dial. 4 check the function by advancing the clock one quarter hour at a time letting it chime in between quarters, then counting the strike on the hour. Hope this helps, and not confuses. Good Luck
Mar 02, 2015 | Home
How do I synchronize the chimes on a George Woltz, Hagerstown clock -- circa 1810
Slide the top off (if it slides off) so that you can see the movement inside. The clocks striking mechanism is on your left side of the movement. There may be a steel lever that raises, and drops between each tooth on whats called a count wheel. The count wheel looks like the other gears only it has deep recessions spaced accordingly to represent each hour. If you raise, or trip the lever, it will advance to the next hour. Do this until you've corrected the strike to the desired hour. Hope this helps. This is just one of several different ways to sync your strike with the time. If I saw your movement, I could give a better answer. Good Luck
Dec 24, 2014 | Home
Gazo Rancho Santa Fe Grandfather Clock won't chim
Check the wires in the back.some times the get corrodes.
Dec 17, 2014 | Home
Halo Grandfather Clock won't chime hour
In my eyes there are two kinds, ones that are a real grandfather clock that runs on gravity using a series of weights and gears with different counterweights for chimes and running the clock itself, and there are the show pieces that look like a grandfather clock but run on newer tech and electronics. If a real one then would try first pulling the weights to the top. They are usually shaped into a pinecone or something. If weight is at bottom them have to pull corresponding chain with weight till the weight is at the top of case. As "time" goes by the weights lower. You should have different counterweights for the clock, chimes, dancing figures and whatever else it may have. All the weights move at different "speeds" so you have to keep an eye on them to make sure it keeps correct time. I would recommend consulting the manufacturer if possible. There are so many kinds out there is really hard to tell by such a short video.
Dec 16, 2014 | Home
Regards,
Dennis
Oct 21, 2014 | Coaster Furniture Large Traditional...
How to adjust Grandfather clock that chimes one chime less ?
Move the hour hand counter clock wise to 10 o'clock. Then turn the minute hand clock wise to set the correct time.
Main Page
Oct 04, 2014 | Home
Edward Meyer 31 Day Grandfather Clock manual
I recently bought an Edward Meyer clock from Grandfather clocks for less. The clock is beautiful, but it never chimed. I even took it apart and repaired the chimes, the hammers were too far away from the chiming rods, but now that it does chime, it sounds like someone banging pots and pans together, it's horrible. I've been looking online to find replacement chime and hammer parts so I can fix it myself.
Jan 23, 2012 | Watches
Coaster Furniture Modern Pendulum Grandfather Clock In Silver Accents And Solid Matte All Black Wood Finish. 900726 Logo
18 people viewed this question
Top Coaster Furniture Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Coaster Furniture Audio Player and Recorder Expert? Answer questions, earn points and help others
