Question about Bissell 1720-5 Little Green Turbobrush Canister Vacuum
Bissel little green 14005
Attachment stuck
  • Official Brand Answer
  • 315 Answers
Hi Victoria. There's a a little button on the top side of the hose area you depress to remove the attachment.
If you're still having difficulty, you may want to contact us for additional assistance.
Here's a quick link to contact us: http://www.bissell.com/contact-us/?cid=ccsocial
Posted on Jul 22, 2013
2 Suggested Answers
  • 3 Answers
SOURCE: Cleaning the bissell little green
Bissell 1425 works great, but today will not ****! Spray is fine....just no suction, even without any attatchments.
Posted on Oct 19, 2009
How can I download Bissell Little Green Clean Machine manual?
direct
https://canada.bissell.com/support
or the first link has it, also videos
  • BISSELL LITTLE GREEN 1400 SERIES USER MANUAL Pdf ...
    www.manualslib.com > ... > Vacuum Cleaner > Little Green 1400 SERIES
    Bissell LITTLE GREEN 1400 SERIES User Manual. ... Vacuum Cleaner Bissell Little Green 1400 SERIES User ... Rcvd a used bissell little green machine w stagnant ...
  • Bissell Little Green Machine ' Walmart.ca
    www.walmart.ca > Walmart.ca > Appliances > Vacuums > Steamers
    • 4.1/5
    • 185 REVIEWS
    • $99.96
    Bissell Little Green Machine for sale at Walmart Canada. ... Powerful suction lifts stains and spots with water or any of the Bissell cleaning solutions.
  • Little Green® Portable Carpet Cleaner ' BISSELL®
    www.bissell.com > ... > Browse By Type > Carpet Cleaners > Portable
    The Little Green® portable carpet cleaner is produced with a minimum of 50 ... Coupon code for purchases on bissell.com: ... (including all accessories and manuals) ...
  • BISSELL LITTLE GREEN CLEAN MACHINE PDF - fenbook.me
    fenbook.me/get-it-free/b/bissell-little-green-clean-machine-manual.pdf · PDF file
    Get Free Read Online Ebook PDF Bissell Little Green Clean Machine at our Ebook Library. Get Bissell Little Green Clean Machine PDF file for free from our online library
  • Bissell Little Green Owners Manual ; Bissell Little Green ...
    www.youtube.com/watch?v=PpQji8obNz4
    • BY BOTHSHOOP
    • 4 MIN
    • 11K VIEWS
    2012-11-07 · Video embedded · Bissell Little Green Owners Manual ; ... Bissell Little Green Owners Manual ; Bissell Little Green Machine ... How to fix a Bissell Carpet
  • Bissell LITTLE GREEN 1400 SERIES User Manual
    May 24, 2016 | Bissell Vacuums
    Cleaning The Brush Head
    I got pretty good results this way (and mine was trashed): Hot water first. Dry the exterior enough to tape the suction end with duct or electrical tape to get a good seal. fill from the other end with bleach. Shake it around and then let it sit in the sink full of bleach for a few minutes. Then remove tape and flush with hot water. The sides of the window may still have debris, hair, or mildew left over. With hot water running, I would alternately add water, and tap the whole attachment against the side of the sink to loosen it up. I kept doing that until i was happy with the results. 37c10874-0738-4aca-8ef6-36cc7428a263.jpg
    Jan 19, 2013 | Bissell THE BISSELL LITTLE GREEN MACHINE...
    Will not spray
    There are a handful of places that the mechanism can get blocked. The easiest test is to remove the brush attachment and pull the trigger. If it sprays fine, then the blockage is in the small length of tubing in the brush attachment. The most likely place is in the small plastic piece at the very end of the attachment. You should be able to see the small plastic piece where the tubing ends, this is a common place for a blockage. You can usually use a piece of thin wire to clear the blockage.
    Nov 28, 2010 | Bissell 1425 Little Green ProHeat Handheld...
    Won't spray, only dribbles
    There are a handful of places that the mechanism can get blocked. The easiest test is to remove the brush attachment and pull the trigger. If it sprays fine, then the blockage is in the small length of tubing in the brush attachment. The most likely place is in the small plastic piece at the very end of the attachment. You should be able to see a small plastic piece where the tubing ends, this is a common place for a blockage. You can usually use a piece of thin wire to clear the blockage.
    Nov 12, 2010 | Bissell 1425 Little Green ProHeat Handheld...
    Bissell Little Green w Broken Hose
    you can just cut it off I did the exact same thing with mine but be careful and make sure the hose goes back on all the way
    Feb 24, 2018 | Bissell 1425 Little Green ProHeat Handheld...
    Help with steam cleaner
    DId you push the little button located at the rear of the attachment on the top? It is gray and part of the hose peice. It is what holds it the attachment to the tube
    Jan 31, 2009 | Bissell 1699 ProHeat Clear View Upright...
    Help
    Sorry, but Bissell has this model and its parts on their obsolete list. So maybe ebay.com or you can call around to see if some one may have one in stock still.
    Jun 16, 2008 | Bissell 1720-5 Little Green Turbobrush...
    Bissell 1720-5 Little Green Turbobrush Canister Vacuum Logo
    98 people viewed this question
    Top Bissell Vacuums Experts
    Jim Parker
    Jim Parker
    Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
