Question about Kitchen Ranges
GE Range Model GRCR3630ZWW-1 DOOR error code on range display
After the stove is turned off, it starts to heat up and then shuts off and the display says DOOR. It does not turn on until a short while later, then does it again. this is something that just started to occur. Any suggestions on the fix?
SOURCE: GE Range Model GRCR3825ZWW-1 DOOR error code on range display
The door latched Micro-switch is not working or is dirty.
Remove the back panel, in the middle of the back there will be a metal arm that moves in and out when self cleaning latch is closed and opened. This arm pushes two or more Micro-Switches in the back, they are dirty or not working and need replacing.
Posted on Jan 12, 2010
jyackle5
  • 8197 Answers
SOURCE: Display shows error code "F1"
F1 Failed Thermistor Control Replace Electronic Range Control (ERC)
Good Luck and Please Rate Fixya!
Posted on Jan 07, 2009
SOURCE: "F1" error code on Magic Chef gas range Model 3488XRA
I'm not sure how to fix this, but my mom's magic chef has been doing this for close to 10 years. She's managed it by plugging a power strip into the wall outlet and plugging the stove into the power strip. Then she can just turn on the strip when she needs to use the oven. It only requires moving the unit once, and is easy for the technological/ home repair novice.
Posted on Aug 11, 2009
SOURCE: GE Profile Electric Stove, no heat, looks like it needs a reset
my oven doesent work and my key pad is locked
Posted on Sep 05, 2009
SOURCE: My stove has started to beep random--why
WE used the broil button last night and our stove started beeping nonstop.It also say F1 three hrs of beeping we unpluged it for the night.When we turned it back on today same thing happened with the beeping and F1.hOW CAN WE FIX THIS?
Posted on Nov 18, 2009
Getting a PF7 code with beeping on my stove. Reset breaker, didn't fix it. Any help would be appreciated.
GE oven error code "F7" and how to fix it ' AskGene.com
www.askgene.com/.../oven...codes/ge-oven-error-code-f7-and-how-to-fi...
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Why is my GE Range model number JBP80SM2SS making ...
www.shopyourway.com > Manage My Life > Questions
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
Jan 08, 2016 | GE Profile 30" Self-Cleaning Slide-In...
Hi. Stupid question for you, but I just can't find my manual! The model # of my GE self cleaning range is GRCR3630ZWW-2 if this helps. I need to clean my range today and how exactly do I do that using...
Hi, check this web page, which is a PDF file of GE oven manuals. It appears that you have to close a latch on the door to start the self cleaning.
http://www.abt.com/images/products/BDP%20images/ge_jbp24_man.pdf
Hope this helps!
Apr 25, 2010 | GE JBP68 CleanDesign Electric Kitchen...
Code fpf flashes on clock on ge elec stove model jbp26gs1ad
I am sorry, but there is no such error code mentioned among the GE Fault codes.Or this could possibly be because of a faulty display.The display can be replaced on a call.
Else the possible error code similar to this one is "PF" which refers to power failure but generally not related to kitchen range.
Please do check if there is a display change of the error code and post your valuable comments. would be glad to help.Good luck.
Jan 16, 2009 | GE JSP26 Electric Kitchen Range
Error message FSEO appear on display of whirlpool stove
Door and switches
do not agree
1. Unplug range or disconnect power.
2. Check wires and connectors from control to door switch, then from door switch to control.
3. If no damage to wires or connectors, replace door switch.
4. Replace all parts and panels before operating.
5. Plug in range or reconnect power.
6. Press Cancel/OFF key. Program and start the CLEAN mode, and observe for 1 minute to ensure that
operation is normal.
7. Go to step 1 and complete checks.
Jan 11, 2009 | Whirlpool RF364 Electric Kitchen Range
Nov 05, 2008 | Kitchen Ranges
F1-1 error on Jenn-Air Range
if it is the stove that is in the picture the fault codes are in the door under the oven door.
Jun 01, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
Kitchen Ranges Logo
198 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
