Question about Mitsubishi WS-55859 55" Rear Projection Television
Mitsubishi tv I have a mitsubishi tv #ws65613 it has always taken up to 90 sec. to turn on now it acts like it is going to turn on the green light blinks then shuts itself down, I have pushed the reset button and it still wont work any help would be great the help line at mitsubishi was a joke thanks! Matt
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 140 Answers
Check 5A micro fuses F9A04 and F9A05 and if one or both are open replace both convergence IC's part# STK394-250
Posted on Aug 30, 2007
SOURCE:
Tv lights up green and act like it going to come on but goes right back off
Do any lights on the front of the TV light up or blink when the set shuts off?
Mar 10, 2013 | Mitsubishi WD-52525 52" Rear Projection...
Green status light FAST blinking and does not shut-off.
SORRY, NO ANSWER.>>> AFTER TURNING MINE OFF FOR THE NIGHT THEN BACK ON IN THE AM, STUCK ON THE WELCOME BLUE SCREEN W/BLINKING GREEN LIGHT BESIDE THE POWER BUTTON. TRIED HOLDING DOWN THE POWER BUTTON FOR 10 SEC., BUT ALL IT DOES IS SHUT OFF. I CAN NOT GET IT TO PERFORM SYSTEM RESET. PLEASE HELP, IF YOU FOUND A FIX FOR YOURS. THANKS! please EMAIL ME AT [email protected]
Nov 17, 2010 | Mitsubishi WD-82837 82 in. HDTV DLP TV
Mitsubishi Projection TV Model #VS-50603 will not turn on.
The TV is going into a "protect mode", the micro-processor has sensed a circuitry problem and has shut the set down so that no furhter damage can happen, you will need to have the TV serviced by a Mitsubishi tech. Good luck !
Jan 07, 2010 | Mitsubishi VS-50607 50" Rear Projection...
Model ws65613 green power lite keeps blinking tv does not turn on
oh yea don't try to look for a lamp in your tv set that has three crt's!
if you can solder and unsolder , then replace the four(4) 1000uf capacitors on the dm board , and make sure the new caps are 25v or 35v , also check fuses for the two STK 394-250 convergence IC's (ic8c01 , ic8c02 )( on the big heat sink ) , if they are blown then replace the convergence IC's also
here is the service manual that will help in dissasembly and locations of dm board and convergence IC's
http://www.techlore.com/download/24849/Mitsubishi-WS-xxx13-Service-Manual/
Mar 02, 2009 | Mitsubishi VS-55601 55" Rear Projection...
Green light doesnot turn off on Mitsubish WS-65315
Just go to menu... then ..setup... then... timer ..and turn it off...... the blinking light goes away
Aug 29, 2008 | Mitsubishi WS-65315 65" Rear Projection...
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Mitsubishi WS-65313 - Will not turn on
The most common failure are the two convergence integrated circuits part # 267P173010. The two pico fuses may be open as well, which come from the power supply and provide +24 volts and -24 volts.
Feb 15, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Constant green blinking light Mitsubishi tv
First wait 90 sec. after power is applied before turning on. If still blinking forever "this is a common problem with the mitsubishi V23 chassis, There are four 1000 UF capacitors in the DM module that go bad. Location #'s c9b01,c9b02,c9b10 and c9b11. The DM module is the large steel card cage on the left side when looking inside with the back off. Once you get the cage out, remove the board. The caps are the larger ones on the top of the board. They will more then likely be bulged out on top or exploded. Replace with 1000 UF @16V or better. This should get you going again. I've done about 15 of these repairs in the last year. Note: try not to mangle the copper grounding fingers. Good Luck.
Jan 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Flashing green button, won't reset or turn on
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
Dec 18, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
57 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
