PGB36C0902E do these units take freon
Amana AC not working blower will come on but compressor will not any ideas?
compressor may be leaking. and you are losing Freon, Have a HVAC tech come and check compressor for leaks.That is probably why the compressor is not working. Also make sure the filter is not dirty and plugged up, that would overheat the compressor, shutting it down.
Sep 03, 2014 | Heating & Cooling
How do i recharge freon for me Friedrich KM18J30A-3 window unit?
only a certified HVAC technician has the license to carry and use the freon used in home A/C units. it's not like the car units we can do ourselves.
Jul 14, 2012 | Friedrich QuietMaster KM18L30 Wall/Window...
Will the a\c compresser work if no freon
The answer is no. The unit is protected by a switch to prevent it from not starting with no or low Freon. Freon contains lubricating oil. So --- No freon , no lubrication, compressor will seize up.
Kind of a good thing. Saves the compressor if the unit runs out of Freon.
Wayne
Jun 08, 2011 | 1993 Buick Regal
Suncutter A/C needs freon. I have added freon to my vehicle system myself. Are home units set up the same way as automobile systems?
To a point yes they are. But home units require a different type of freon, the oils are different and you can cause major damage using the wrong freon or using the same gauges that where used to fill a car, also the residential or commercial units use a very specific amount of freon and if you are to high or to low you can cause damage. You should not be low on freon and it is recommended that you get a qualified service technician out to look at your unit and run dye through it to find the leak. If this is a newer system you are running very high PSI throughout your system and without the proper equipment you can cause damage to yourself or the unit. I hope that this kind of answers your question
May 29, 2011 | Heating & Cooling
How many PSI freon dos this unit take to fill? S3QA-30KA 2.5 TON
unit's are usually charged in pounds not psi...units require a certain pound amount of freon to work properly....... it depends on the outside air temp, the inside air temp.... what type freon ?? need more details on unit and what type freon does it use??
May 10, 2011 | Heating & Cooling
Can freon be added to an under the counter unit?
Freon can be added to any unit, but you e going to have to take the unit out to exposed the back where the component are located. Why do you think that you need freon. Unless the line was punctured. it unlikely that you would need to add freon, Is it not getting/keeping cold. Problem might lie elsewhere like in the thermostat. Hope this helps.
Feb 09, 2011 | U-Line 15R Compact Refrigerator
My Amanda wall unit keeps freezing up. Cleaned filter and coils, please advise. Thanks, Gilbert
If a AC unit starts to freeze up, then that is a sure sign that it is low on freon. A wall unit is harder to add freon to since those units generally do not have Shrader valves to purge or add freon. It is sort of like your refridgerator in that the freon is sealed in the factory and to add , a technician has to cut the evaporator tube and add a valve, then add freon, pinch the tube off and seal it once the correct pressure is adjusted.
I would say that somehow your unit has developed a leak, and will get worse.
see:http://real-estate-agents.com/tips/hvac/maintain-air-conditioner/
Jan 23, 2011 | Amana PTC123B35AE Air Conditioner
How do i get the freeon in the ac its not getting cold
Air Conditioners don't 'Use' freon per se. A common fallacy is the thinking that if "It's not getting cold, then it needs freon." If your unit lost freon, it has a leak and adding freon will only be a very short term fix.
If you're certain that you need freon, you'll have to take the unit to a certified HVAC technician. EPA regulations make it nearly impossible for the average handyman to service A/C units, since the freon must be handled in a very specific way with equipment not generally available to the average owner, was well as R-12 freon gas which can be bought only by licensed HVAC technicians.
However, there are many other problems that are far more likely to be the cause of no cooling than loss of freon. It could be something as simple as dirty condenser coils (you'd be surprised how common it is that a simple cleaning of these coils will 'fix' a non-working window A/C), to a defective thermostat switch, to other defective switches/controls.
Unless it's a very obvious leak, I always suspect a loss of freon LAST on my list of possible cause of non-cooling in these units.
Jun 28, 2009 | Goldstar R5050 Air Conditioner
I have a Tane 2 ton condenser unit that has high head pressure(290) and high suction pressure(150). The unit is properly sized but no cooling. Unit has been installed probably 4-5 years and has not been...
Has anyone added some freon? The unit has way too much freon inside it. You need someone to reclaim the freon and weigh in the right amount of freon. If you run the unit the way it is will cause some very serious damage. Let me know ken
Apr 29, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
