Question about Air Tools & Compressors
Ingersoll rand p101 lost seperator oil
My p101 compressor lost oil from seperator, it starts but when i ask for air it drags engine down and cuts out
SOURCE: ingersoll Rand SSR compressor shuts down loaded or
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Posted on Sep 25, 2009
ollie reece
  • 1167 Answers
SOURCE: I have a ingersoll rand air compressor rand 4000
you dont torque it you can torque it ya self if you wont but wont make a change do it to 40-50nm ahd try this if no good replace the gasket they do wear out at times also when you take the head off thereshouldnt be oil in there only on the cyclinder not the head ??
Posted on Oct 08, 2009
  • 54 Answers
SOURCE: I have a Ingersoll Rand P185 WJD air compressor
Do not use 30 wt oil. It will wreak the oil/air seperator filter. Use Ingersoll Rand Pro-Tec fluid. It will hold approx 3 gallons.
Posted on Nov 19, 2009
  • 243 Answers
SOURCE: my tow behind air compressor ingersoll rand 185
press load button or toggle switch
Posted on Feb 08, 2010
compman66
  • 169 Answers
SOURCE: The compressor starts and stops after a short
More than likely it is a problem with the inlet control, commonly I have found wear in the throttle linkage can cause this or a faulty sump pressure sensor that is out of calibration.
Posted on Mar 07, 2010
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
WHY DOES A SM75 INGERSOLL RAND COMPRESSOR CUT OUT ON LOW PRESSURE OIL
Low oil pressure. Are you adding a lot of oil. Have you check the oil level. Switch could also be bad.
Dec 08, 2014 | Ingersoll Rand Air Tools & Compressors
175 ingersol rand compressor putting a lot of oil out with air
check the oil air seperator if it has oil inside it, if so replace it
Nov 09, 2012 | Ingersoll Rand Portable 175 Air Compressor
Ingersol rand single phase t-30 compressor with twin cyl slow/ dragging
Quincy QT-5, with an 80 gallon tank. I was very patient and found this on CL. If you are flush with cash, do as you wish. If you are looking for the best bang for the buck, CL will produce!
X2 on the CL find....
Picked up a basically new Ingersoll Rand, T30 220v/2 stage for $500
Increase Engine Horse Power.
Jun 04, 2012 | Ingersoll Rand - Rand Type - 30...
What does alarm start fault mean on the control panel on a ingersoll rand ssr ep-30 air compressor
I use to start up a 25 HP Ingersol screw type compressor. The only alarms I got were from power spikes which just needed the reset button to be pushed, then the on button - and the low oil sensor would shut it down and give an alarm when the tank was about half way down. They will blow up with no oil so there is a saftey margin on oil level.
Mar 28, 2011 | Ingersoll Rand Stationary Air Cooled...
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
I have a Ingersoll Rand P185 WJD air compressor and I need to know the type and quantity of oil to use.
Nov 03, 2009 | Ingersoll Rand Air Compressor Maintenance...
When shutting down the compressor, oil comes out intake filter
hi there,
well,if your air compressor was shut off this due to pressure switch w/c auto switch off your compressor,the pressure switch acquired already the cut off pressure.if the pressure goes down the cut in set up reached it will start your compressor
to run.
regarding oil spillage when shutting down check the oil level on the sight glass of crankcase
a red line indicate oil should not exceed on that level line,if the oil exceed try to drain oil.,on the side bottom of engine there is a drain plug.until on limit level .,besure that machine is shut off/breaker is off.have a nice day don't forget to rate me,thank's
Apr 28, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
1989 Ingersoll-Rand 185 cfm air compressor will not build up air
ITS A POSSIBILITY AND YOU BETTER HOPE ITS NOT SPINNING BECAUSE THE SCREW COMPRESSOR IS LOCKED UP. CHECK THE OIL LEVEL IN THE SUMP AND SEE IF THE ROTOR WILL TURN WHEN NOT RUNNING. TYPICALLY THE DIESEL ENGINE WILL TURN HIGHER RPMS WHEN IT HAS NO DRAG ( NO COMPRESSOR HOOKED UP ). YOU CAN GET THE PARTS FROM INGERSOL RAND OR ANY RENTAL YARD - UNITED, PENSKE, SUNBELT, ETC. THEIR MECHANIC SHOPS ARE USUALLY FOR HIRE AND CAN EVEN INSTALL IT FOR A CHARGE. ALSO MAKE SURE NOTHING BUILT A NEST IN THERE. IF YOU REMOVE THE SCREW, MAKE SURE AND WATCH FOR SHIMS. THOSE SHAFTS NEED TO LINED UP PERFECT TO REDUCE VIBRATION. GOOD LUCK
Apr 06, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
35 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
