Question about Amana Heating & Cooling
Charging port location - Amana Heating & Cooling
I love
Posted on Jul 20, 2013
I am trying to locate the correct port to use to recharge my air conditioning system?
The port in the larger of the 2 AC lines from the compressor is the port you charge at.
May 27, 2014 | 2005 Suzuki Reno
I am trying to locate the low pressure port on my 2000 Saturn LS. there is no cap on the only visible and accessible port I see. It is located in the front of the engine compartment (passenger side) but...
The high pressure port is much larger than the low pressure port. It is impossible to hook a charging hose to the wrong port. If the charging hose is leaking, it is either because it is not clicked all the way on the port or the charging hose connector is defective.
The high pressure port is located on the discharge hose just to the rear (driver's side) of the A/C compressor.
Jul 10, 2011 | 2000 Saturn SL
Cant findwhere to charge ac
if it is a window unit you are trying to charge - chances are - there are no charging ports. Hardly any window units (that I know of) have charging ports when manufactured. The only time you'd find charging ports on one is if it had been 'charged' at some time in it's past history. Most window units run years and years without needing to be re-charged. Therefore - if you cannot find charging ports it means it's never been charged since being manufactured. Always 'be sure' a unit needs charging before opening the system.
Through the wall units (like in motels) sometimes - comes with charging ports - although not all the time.
Central units all have charging ports and they are located on the condenser (outside unit). Just follow your copper lines (one big one -usually insulated and a smaller one) - into the unit and the charging ports are not easy to miss.
hope this helps.
Jun 18, 2011 | Heating & Cooling
1108notcharging
Hi, when a phone does not charge, Usually is either from the charger or the charging port of the phone that is bad.
Use the charger on another nokia phone to see if it will charge. If it does charge on another phone, that means the charger is working,but the charging port is not.The charging port is located below the phone where the charger is been inserted.
It"s very easy to replace.when you unscrew the phone,remove the phone board,the charging port is removable,just buy another charging port,and replace and you are done.
Take care.
Oct 05, 2010 | Nokia 1100
My freon needs charged buy I cannot find the right port to charge it up. Where is the port located?
Low pressure port is located close to the A/C compressor on the inlet tubing. You need to access it from underneath the front bumper/engine area.
Check the below picture..
Aug 10, 2010 | 1997 Oldsmobile Achieva
I need to locate the low side ac port. air conditioner needs charge and i cannot locate the right port.
The easiest way to locate the low side charge port on any vehicle is to locate the A/C compressor, follow the "larger" of the two lines all the way back to the firewall. Some where along that line you will find the low side charge port.
Good luck.
Regards,
Aug 06, 2010 | 2001 Pontiac Grand Am SE
Dvd player wont charge wether it's from home or from a car charger
There seem to be a problem with either the battery or the charging port.
unscrew the player, locate the battery and replace it with a new one, then try to charge.
but if it does the same, then the problem is from the charging port.
replace the charging port ant it will be okay.
take care
Jun 15, 2010 | Sony DVP-FX810 Portable DVD Player
Where is low pressure port located on 1999 acura
look for the large ac line/hose and follow it untill u come to the small service port this is wher u charge the small ac line/hose has the large port this is the high side
Jun 29, 2009 | 1999 Acura 3.5RL
I need help finding the low side connector for a/c recahrge can you tell me location
2.4L engine AC low side charge port is located near the right shock tower. 3.4-3.1 engines AC low side charge port.remove right tire on driver side.remove splash shield.
Jun 25, 2009 | 1999 Oldsmobile Alero
Location of low side A/C port on 2001 Lincoln LS V8
2002 is what I have. should be similar
Service Gauge Port Valves
The high-pressure service gauge port valve is located on the A/C receiver drier manifold and tube assembly.
The low pressure service gauge port valve is located on the manifold of the A/C compressor manifold and tube assembly at the A/C compressor.
23d30e7.gif Item Part Number Description 1 19860 A/C evaporator core 2 19849 Thermostatic expansion valve 3 19A834 Manifold and tube assembly—thermostatic expansion valve 4 19D850 Manifold and tube assembly—A/C compressor 5 19E762 A/C charge port valve (low side) 6 19E762 A/C pressure relief valve 7 19703 A/C compressor 8 19D594 A/C pressure transducer 9 19712 A/C condenser core 10 19D701 A/C charge port valve (high side) 11 19N585 Manifold and tube assembly—receiver drier 12 19959 Receiver drier 13 19C734 Sensor—evaporator air discharge temperature
Jun 11, 2009 | 2001 Lincoln LS
Heating & Cooling Logo
16 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
