Question about Kitchen Ranges
Ge range drawer
Ge part 229c4991 my drawer will not smmothly go in and out on rails. i have these 2 parts but i dont know where they go!!JBP80W0H2WW ge range
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
See if this parts image helps you.
Posted on Jul 22, 2013
2 Suggested Answers
SOURCE: I need the part that is called the support drawer
it looks to me like that part is not available, and they have substituted part # WB48T10030 which mounts on the back of the drawer but performs the same function
Posted on Feb 14, 2011
Cannot get the broiler drawer completely of my kenmore gas range #790.70603013 so I can replace the ignitor
There is a way..... If you pull the drawer out as far as it goes, you may find small plastic levers sticking out of the rails. Press 1 side up, and 1 side down, and you can pull the drawer out the rest of the way. In others, you can pop the drawer up and off the rails, so you can get into the brolier drawer.
Apr 26, 2015 | Kenmore Kitchen Ranges
Bottom drawer of kenmore range rests on the floor when opened
At the back of your drawer, there should be 2 guide or glides. These glides have a slit in them.... Now pull out your drawer and look inside the frame of the range where the drawer goes. You will see a horizontal bar or or rail that goes from the front of the drawer area to the back, on both sides of the range. Those glides on the back of your drawer are supposed to "hug" that rail. Or to put it another way, that rail must go in the slot of the glides. Of course, if you are missing 1 or both of the glides, or if they are broken, then that is why the drawer falls to the floor when you open it.
Sep 11, 2014 | Kenmore Kitchen Ranges
I want to reinstall a oven storage drawer on a electric LG oven
I don't think you need to remove a slide rail. They should slide out by hand and then set drawer back into it. usually have to tile drawer up some to start.
Nov 06, 2013 | Kitchen Ranges
Stuck slide drawer on ge spectra
Check to see if the glide rail has been bent of if something is actually pinned under the stove it self sometime tile or and rug will get caugh in the drawer. after that's all clear the only other issue I can see is if cleaners of some sort have drained down unto the drawer slide, or the drawer slide is bent or off track some how.
Jun 09, 2013 | GE Profile Spectra JGBP90 Gas Kitchen...
I need the part that is called the support drawer for an older model ge spectra electric range jbp80b0f2bb. I think the part number is 229c4991
Sep 19, 2010 | GE Kitchen Ranges
The storage drawer on my range won't slide properly.
Enter your model # at www.appliancehelponline.com for diagrams and illustrations. The plastic pieces are under the body parts diagram on the left hand side.
May 03, 2010 | GE Kitchen Ranges
Whirlpool range
Hello dolphin 1 mom
Welcome tofixya.
You said, accidentally removed the door to my range and now it won't go back on. The door won't go back into the slots on the range.
Send me your e-mail address and I'll e-mail the diagram with the door instructions for removal and replacement.
It will not fit in here with the diagrams.
Waiting for you.
Huuum
Please do not forget to enter a rating when we are done
These are the installation instructions, but with no diagrams
To Remove:
1. Open the oven door. Insert door removal pins, included with
your range, into both hinge hangers. Do not remove the pins
while the door is removed from the range.
2. Slowly close the door until it rests against the door removal
pins.
3. Grasp the door on the sides with your fingers on the front of
the door and your thumbs on the inside surface.
4. Pull door straight up, then toward you. Hinge hangers will
slide out of front frame hinge slot. Do not remove door
removal pins until the door is replaced on the range.
To Replace:
1. Grasp the door on the sides with your fingers on the front of
the door and your thumbs on its inside surface.
2. Hold oven door so that the top edge of each hinge hanger is
horizontal. Insert hinge hangers into the front frame hinge
slots.
3. Tilt top of door toward range. Slide hinge hangers down onto
front frame support pins. Make sure the hinge hangers are
fully seated and engaged on the support pins.
4. Insert the door stop clip with its angular surface at the top of
the frame hinge slot, then push in the bottom of the clip until
its flanges are flush with the front frame.
5. Open the door completely and remove the door removal pins.
Save door removal pins for future use.
6. Close the door.
StorageDrawer
The storage drawer can be removed. Before removing, make sure
drawer is cool and empty.
To Remove:
1. Pull the storage drawer straight back past the drawer stop
notch and the end of the side rails.
2. Lift up the back of the drawer and pull the drawer out.
To Replace:
1. Lift up the back of the drawer and place it inside the range in
its fully forward position.
2. Lift up the front of the drawer to a level position.
3. Slowly push the drawer into the range until the drawer side
rails engage with the gap in the drawer glides.
4. Once the drawer is fully engaged on both sides, slide the
drawer back into the closed position.
NOTE: When removing and replacing the storage drawer, a slight
push may be needed to move the drawer stop notch past the
drawer glides.
A. Removal pins
B. Hinge hanger
A. Hinge hanger
B. Door frame hinge
C. Support pins
A
B
A
B
C
A. Drawer stop notch
B. End of side rail
A. Engage drawer glide
A B
A
Sep 09, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Jammed storage drawer
svineyardWelcome to fixya.
I'm Huuum and happy to assist you,
You said, Y inherited a GE Spectra XL44 in the home I recently bought so you don't know much about it. There is a pan stuck in the storage drawer and You can only open the drawer about an inch and a half before it jams.
You need two people.
One strong person to slide the range forward, so he can tilt the range far enough back, that you can access the drawer from the bottom and the pan will fall back inside the drawer as you pull the drawer forward and out enough for you to reach the pan and turn it around or what ever you need to do to get it out!
Bravo, I want to hear that you succeed!
Be careful not to hurt your self.
Bless You Huuum.
Please do not forget to leave a rating when you are done.!!!!!!!!
Aug 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven fire
wrong call ge@ 100-851-6200 and they will help you have the model number handy before you call
Apr 21, 2008 | GE Profile 30" Free-Standing 5 Burner Self...
Kitchen Ranges Logo
159 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
