Question about Little Giant Pump 566108 Pond Pump Filter Box Mechanical
How do you attach this filter box to a Little Giant Pump?
There are no instructions with this filter as to how to attach it to a Little Giant Submersible Pond Pump [LG Model PE-1F-PW] (recommended for this filter). How is that attachment done?
    Sergeant:
  • 337 Answers
Frank the pump goes inside the box with the foam around it.
Posted on Jul 22, 2013
How to disassemble Little giant pump model#psm006?
thats why i like the little giant pumps they are put together with phillips screws not glued like them other guys , i do suggest that if you dissasemble pump and water has gotten inside , replace it not just seal it up and go , wont last long as that means the pump shaft seal has leaked , ther e has been a few folks that add dietary mineral oil to the inside , for use in very deep ponds (over 3 feet) they believe that helps keep the water out
Jun 11, 2014 | Little Giant Submersible Fountain Pump
My little giant pumps intermittently and its the second one i had do this!
water being pumped have high solids content ? , get sample in clear glass let set overnight look at bottom closely , Lots of stuff settle down there ? if so your gonna need a filter of sorts to remove solids before pump gets a hold of it
Oct 17, 2012 | Little Giant 5-MSP Water Wizard...
: I have a Little Giant water pump that I want to assemble. I think I lost the manual. Can you help me?
Here is a link to a website with many Little Giant waterpump manuals. They are all in PDF formatand organized by model. Your modelnumber can be found on the bottom of your pump or on the box your pump came in. http://store.waterpumpsupply.com/aquariumpumps1.html
May 13, 2012 | Fish
My new Little Giant 8-CBA Pump is hooked up underwater and plugged in. Not a sound. Electricity is working. And it's the same pump we have had for the last 7 years.
You say it's new? On some pumps they will secure the float switch when shipping. Be sure you followed directions and removed anything that may interfere with the switch.
Apr 21, 2011 | Little Giant 8 Cba, 4/10 Hp, 45 Gpm...
Hi, my little giant 506158 isn't functioning. When I took of the switch cover and manually depressed the switch the pump came on. Do I need to replace the switch, how exactly does that switch turn on...
For this pump to turn on, it must be under 7" to 10" of water. The water gets into the switch housing (which has an opening in it) and water pressure pushes on the rubber diaphragm (much the same as you did when you removed the cover). Once the pump turns on and lowers the water level to between 1" and 4", the pressure of the water will not be enough to keep the switch closed and the pump stops automatically.
Gary
Dec 11, 2010 | Little Giant Submersible Sump Pump 2760...
Little Giant Pump - dialectic oil to use
ck your local yellow pages for an electric motor repair shop they should be able to get silicone oil to add , but in a pinch ive used full synthhic auto transmission oil that works too
Jul 29, 2009 | Little Giant Submersible Sump Pump, 1/4 Hp
Little giant pump stopped working
Hi Tom (and Lindsay?),
Ok lets get a little more info,
  1. Plugged in? (Have to ask)
  2. Does it run and not pump?
  3. Does not run?
  4. Tried moving the float switch?
  5. Pull the pump and see if the intakes are clogged
Please comment back with your findings
Mike
Apr 18, 2009 | Franklin ELECTRIC/LITTLE GIANT PUMP 1/4HP...
Little giant rs-5 remote switch for submersible pumps wont work. When I attach the rs-5 to the plug motor nothing works. when I plug in the pump without the rs-5 the pump will work.
there is a breather tube that has to be above the water level, you can check the diaphragm by plugging in the switch and pump the **** on the tube, if the pump doesn't come on, the diaphragm is busted or maybe there is something in the tube
Apr 11, 2009 | Little Giant Rs-5 Remote Switch
Little Giant Pump 566108 Pond Pump Filter Box Mechanical Logo
144 people viewed this question
Top Little Giant Pump Plumbing Experts
JohnPaul Robertson
ray gallant
L Pfaff
L Pfaff
Are you a Little Giant Pump Plumbing Expert? Answer questions, earn points and help others
