Question about Omega Excalibur 2-Way Alarm Keyless Entry Multi-Car System AL1510EDP
How to remove the valet setting on my keyless remote alarm
The alarm would not come on while in valet mode
    Sergeant:
  • 396 Answers
Posted on Jul 23, 2013
Battery went dead so replaced the battery but now alarm system doesn't work. Keyless entery remote works to open and lock doors but no alarm. How do I reset the alarm on Ford explorer 1999?
It sounds like the system is in valet mode. Depending on the brand and model that is installed, the procedure to turn off valet mode can vary. The most typical way is to turn on the ignition key and press and release the valet button, or if it is a switch, to flip the switch
Jan 25, 2011 | Ford Vehicle Parts & Accessories
WHY WONT MY ALARM BEEP
your alarm may be in valet mode causing the system to act as a keyless entry system. you can verify this by checking your alarms LED light on the dash, If the light is on solid the system is valet mode
Jun 11, 2010 | C3RS727LCD 4Channel Alarm with Remote Car...
So I have a viper alarm system in my car and awhile ago the remote got wet, so in order to be able to start my car i had to disable the alarm by turning the ignition on and pressing that eraser like...
You have to turn off your ignition and immediately press that 'eraser like button'(valet switch) for a second and release it. Alarm will then come out of valet mode and your remote should work, if it's good.
Jun 01, 2010 | DEI Valet Keyless Entry System
I have a 561r that was professionally installed and working fine for about a year. Now all of sudden my van will not fire or start the engine. The theft light continues to blink. I cant start the van with...
Try disconnecting the alarm putting in a valet mode and start the vehicle with the car key. If you don’t know how to put in a valet mode, check your alarm manual. After if the car start them the problem is the car alarm, make sure all the doors, trunk, hood are close if still not working check if the hood, trunk switch are working properly.
Jan 01, 2010 | Directed Dei Valet 561r Remote...
When i bought the car it was disarmed maybe cause it was towed?
Do you have the alarm's remote fobs? If not do you know where the valet button lives? It's a little black button hid somewhere under the dash. Anyway put your key in ignition turn key to "run" position and within 5 seconds push the valet button and that should stop the alarm and allow you to start the vehicle. OK after you get the vehicle started turn it off and hit the valet button again. The blinking LED should be solid not blinking and that's telling you your in valet mode which means the alarm is off, the conviencince features like keyless entry and remote start will still work but the alarm is standing down.
Aug 11, 2009 | 990 And 950 Responder SST Remote - 7701P
How do I disarm a audiovox prestige car alarm?
Locate the valet/override switch (button), (if you can't locate it, try tracing the wires under the dash from the main unit, usually a black and gray or black and red set of wires). Turn key to "RUN" position then press the button, the alarm's LED should light up solid at this time indicating valet mode as been set.
Jun 14, 2009 | APS20B Prestige Keyless Remote Alarm
Stuck in valet mode
To exit valet mode turn the ignition on and press the overide /program button for 4 to 5 seconds until the dash LED turns off and you hear the system chirp two times. That should get you out of valet mode. Please don't forget to rate. Thanks.
Apr 08, 2009 | On-Guard Alarm with Wireless Siren, Remote...
Uniden vs1100xr car alarm will not arm or disarm,have found valet mode button which sets & resets ok but remote just flashes led no chirps or lights flashing
I had the same problem with my vs1100xr. The remotes for these (and other) unidens have a rolling code. Seems to me that either the remote runs out of new codes and cycles back to the beginning, or the alarm base unit somehow loses track of the codes. Either way, the alarm base unit stops accepting the codes of your remote, and so needs to be purged of its code tracking memory - reset, if you like. This is essentially the procedure for training the alarm base unit to recognise new remote (and forgetting old remotes).
This procedure is:-
1) Disarm alarm, or if in valet mode, take it out of valet mode (push valet button 3 times)
2) Turn the ignition on and off 2 times within 15 seconds.
3) Put the alarm into valet mode (push valet button 3 times) within 15 seconds of completing step 2. Alarm should beep, and remote training has started.
4) Within 15 seconds of completing step 3, push the button (#1) of the first remote you wish to use for the alarm. Alarm should beep, indicating acceptance of remote. Repeat for other remotes you wish to use - up to 4 in total. (Once the first remote has been accepted, you have all the time in the world to make the alarm learn other remotes)
5) Turn ignition on and off to end remote learning mode. Alarm should beep 2 times. New remotes have now been learned and previous remotes forgotten.
Some of these details may vary from country to country - who knows. If this doesn't work, I suggest that you contact Uniden in your country to obtain the procedure. Took me a few tries to get the timing right, what with the valet button hard to get at and having only 15 seconds between steps.
Sep 28, 2008 | Car Audio & Video
Wont go into program mode
yes there is actually if you have a valet switch there is a code you set in that gives you control over setting the keyless remote code i dont have the specs and you would probably have to take to dealership so they could show you how to set up valet switch for keyless entry since i do not have a book for that spec also theres this link that they can help set up over the keyless entry remote by there techs call the number give them alarm model and info on truck
http://www.remotesunlimited.com/?OVRAW=car%20alarm%20remote&OVKEY=car%20alarm%20remote&OVMTC=standard&OVADID=2211521522&OVKWID=21052597022
heres the link call the tech they sale to all dealers and have techs on hand during service hours to help
May 22, 2008 | 2003 Ford F150 Regular Cab
Omega Excalibur 2-Way Alarm Keyless Entry Multi-Car System AL1510EDP Logo
125 people viewed this question
Top Omega Computers & Internet Experts
David Payne
David Payne
Are you an Omega Computer and Internet Expert? Answer questions, earn points and help others
