Frigidaire fal103k1a1 air conditioner
How many btu
SOURCE: heat strip installation
It was quite simple, just installing the heat strip and my model only required removing the grill cover and mounting the element. The other optional installations didn't apply to my model.
thanks,
Don
Posted on May 27, 2008
bobotfel
  • 236 Answers
SOURCE: Need to know the watts on a Fridaire Air Conditioner 6000 btu
check your name plate voltage and current rating, multiply it and the result is the wattage of the unit.
Posted on Jun 10, 2008
  • 230 Answers
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Posted on Jun 30, 2008
skrbin
  • 121 Answers
SOURCE: what startup surge Watts required for 5000btu Air Conditioner
1.5kW
Posted on Feb 17, 2009
SOURCE: Error code A5 on Frigidaire
I have a Frigidaire model FAK104R1V window air conditioner that did the same AS error code. The problem is going to be one of the 2 temperature sensors in the unit. Mine happened to be the ambient temperature sensor located at the front of the unit. They are fairly easy to replace and you can buy a new sensor for about $15 online.
Posted on Jun 05, 2009
What is BTU's of this model
Hello Friend, that's a great question!
I show that your post is listed under Frigidaire air conditioner (FAS1084M2A). I show that your air conditioner has a cooling capacity of 18,000 BTU's. If this is not your model number, please provide me the correct number. You can typically locate the serial tag (which lists your model number) behind the front grill by the air outlet or on the side of the cabinet. Other possible locations are on the front edge of the chassis base or behind the dial plate of the control panel. If you need further assistance, please feel free to reconnect.
Jul 11, 2014 | Frigidaire FAS184M2A Air Conditioner
Manual Available? BTU rating
Good Morning Friend,
I understand you are looking for the manual to your Frigidaire air conditioner, model# FAC084N7A. I also see you want to know the BTU rating. Your air conditioner is rated 800-BTU. I have attached the manual below. Hope this is helpful.
-Best Regards-
WP
Frigidaire Manual Search Results
Jul 09, 2014 | Frigidaire FAC084N7A Air Conditioner
How many btu is this air conditioner model #FAA067P7A
Good Afternoon Friend, this is Z. That's a great question!
I show that your Frigidaire air conditioner FAA067P7A has a cooling capacity of 6,000 BTU's. I hope this information helps to some degree. If you need further assistance, please feel free to reconnect.
May 25, 2014 | Frigidaire Compact Air Conditioner
How to Replace broken fan on frigidaire air conditioner FAL125M1A1
Most of these AC units that are small in BTU size, under 15k, can't be repaired because most manufacturers don't have replacement parts available. Contact Frigidaire first.
Jul 30, 2012 | Frigidaire FAL125K1 Air Conditioner
My window is only 18-19" wide. I need to know the
You can find the information you're looking for, as well as the Owner's Manual and Installation Guide at the following link.
http://www.frigidaire.com/products/air-conditioners-dehumidifiers/window-air-conditioners/fra052xt7
Hope this helped you.
Jul 14, 2011 | Frigidaire FAX052P7 Compact Room Air...
We installed a 12,000 btu Frigidaire unit last night and it doesn't seem to blow 'cold' air. And it doesn't cool our tiny 12x12 bedroom...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 26, 2010 | Frigidaire FAC126P1 wall/window Air...
Do you need brackets for outside wall installation for the frigidaire 15000 btu air conditioner.
No you do not. Not a bad option, but if wall sleeve nstalled properly this unit will not need brackets.
May 11, 2010 | Frigidaire FAH085N1T Air Conditioner
Frigidaire FAZ12HR2A Air Conditioner I need a spec sheet for voltage choices and btu ratings, amps, watts
give this site a try all you have to do is sign up and its free
http://homeappliance.manualsonline.com
Sep 14, 2009 | Frigidaire FAH086R1T Thru-Wall/Window Air...
Jun 10, 2008 | Frigidaire FAC126P1 wall/window Air...
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
