Question about Juicers
Need to buy grater and filter unit - Juicers
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
Will any grater and filter unit serve, or do you have something more specific in mind?
Posted on Jul 20, 2013
How do I remove the grater/filter from juice collector to clean it? Also the juice collector from the drive shaft? Thanks
You have to lift off the juice collector (the black part around the grater)-you have to use a little force-then you'll be able to take out the grater.
Jan 10, 2011 | Maximatic EJX9700 Juicer
HOw do i clean it?
flip down the lever to pull it all apart.
rinse out the lid, food pusher and base(that the mesh filter sits in).
scrub out the mesh filter with a dish brush or the included brush if you have it. be carefull the grater-like parts at the base are very sharp. make sure it's clean by holding it up to the light. if there are any particles left clinging to the mesh it will seriously interfere with the effectiveness of your juicing.
you can line the pulp collecting jug with a plastic bag so that you dont have to clean that out as well.
it's best to clean everything immediately. if for some reason you can't, at least rinse the plastic parts and leave the mesh basket to soak until you can get back to it.
if you have any dried food or staining on any of the parts then a soak in water with lemon juice in it (maybe the juice of 3 or 4 lemons) should help soften up particles and strip away stains.
hope this helps....
Jan 09, 2010 | Breville JE900 Juicer
How do you take the grater off the juiceman2 the part that the fruits and vegetables get grated. Thank you
how do you take the grater off the juiceman2 the part that the fruits and vegetables get grated.
Dec 12, 2009 | Salton JM411 Juiceman II Elite Juicer
Broken plastic screw from motor shaft
According to Jack Lallanes Support you need to buy a new motor! No replacement part for that specific part!
I have the same problem and also do not want to buy a new motor! Scam!
Dennis
Nov 21, 2009 | Jack Lalanne Power Juicer 250 Watts
The plastic screw, which the grater is screwed onto (looks like part of the motor) is broken.
I had the juicer for exactly two weeks and the same piece broke. The little plastic part in which the blade screws onto. Called the company and they were actually no help at all. Please don't waste your money!
Nov 14, 2009 | Jack Lalanne Power Juicer 250 Watts
How do you disassemble the jack lalane juicer?
You use your Orange cresent tool with the 2 metal thingies on the bottom of it. Take off the top of the juicer. Then get the tool and then stick the tool where you see the two holes. Hold down the spinning like grater, and use the tool to turn counter clock wise. Once you do that the Middle part will come off.
Oct 09, 2009 | Jack Lalanne Power Juicer 250 Watts
Breville je2 (anthony worrell juicer) lost the blade!! slicer!!! thing
Am currently looking for a spare part for mine. If I fail to find it, u can have my grater bit!!
May 02, 2008 | Breville JE3 Juicer
Cleaning my juicer
Generally you will have good luck with this item - however after using it for a while here is the problem people are stating in other reviews. You cannot get the basket our for cleaning. Unfortunately there are no instructions or troubleshooting or anything on the manufacturer's website for fixing this..
Here's the problem...There are 3 little captured balls on the basket that engage into holes into the juicer to hold it into place when you load it. The problem is that over time - the balls get juice in them. Then you store the thing with the basket locked into the juicer. Then from sitting in your cupboard - the juice dries and the balls are stuck. When they get very sticky they do not float in their cavity they are stuck. Then after you juice the next time - you cannot get basket off. basket is stuck and you will destroy the juicer if you try to pry it out with excessive force.
If you have this problem and you are lucky enough to be reading this - I have figured out the fix on my own...
You need to fill up a large tupperware, rubbermaid, whatever - bowl about 3 inches deep with hot water. Then take the juicer with the clear cover off and flip it upside down and into the hot water. Make sure the water is covering the entire basket area, but not so deep it goes into the motor area. I let it soak for about 3 hours, but I don't think you will need to do it for that long. When I took it out of the water I was able to pry the basket out with very little force. This is when I discovered this flawed design with the balls. Now I rinse the little ball bearings really good after using and dont store it connected. Then before connecting the basket to the juicer rinse the little bearings and push them in to make sure they are freed up before each use.
I used it probably for a year or so about 40 or 50 times without this issue, but let it sit for about 4 months - which is why I believe it caused these balls with juice in them to get so frozen I couldn't remove it.
Good luck. It worked for me.. this should work for you!
Tom
Mar 23, 2008 | Juicers
Juicers Logo
42 people viewed this question
Top Juicers Experts
eyecam
David Payne
David Payne
Are you a Juicer Expert? Answer questions, earn points and help others
