Panasonic h43 na-168vg4 - Washing Machines
2 Suggested Answers
  • 30 Answers
SOURCE: I have a panasonic NA-168VX2 washing machine which
Thank you for using FixYa. The error code H43 refers to an internal water leak. The leak is obviously only a small one or you would have noticed. A small amount of water on a sensor will bring up the error code. A simple solution is- remove the back of the machine after first un plugging it from the electricity and dry up any water then try again.
I hope this has been of some use and would appreciate your "helpfull post" if it has
Thank you
Posted on Mar 05, 2011
Where is the H43 error sensor located in my panasonic na14av1 machine
H43 Leak detected to base of the washing machine
  • Check for source of the leak
Aug 15, 2016 | Washing Machines
Panasonic model Na-f70b2 error. U12 and stop motor
Try this: it should give answers to the "self-diagnostics".
http://panasonic.ae/en/manuals/NA-F70B2-65B2.pdf
May 05, 2015 | Washing Machines
My panasonic waching machine model is NA F80B2 Error is U 11 U 14
See http://www.manualslib.com/manual/783539/Panasonic-Na-F78b2.html?page=13#manual
Feb 06, 2015 | Washing Machines
Panasonic na-168vg3 h51 code flashing
Hi Rick, What does H 51 mean on the display of my Panasonic NA 140vg3. However, after that code has flashed a circle symbol will appear, then it will disappear. The door won't open. I would appreciate your help. Cheers
Jan 16, 2013 | Washing Machines
I have panasonic eco drive washing machine model NA-FS14x1 have error code H57 how to repair
Unscrew the back of the machine to look and see if there is any water in the base of the machine.
How old is your machine? If it's new I'd exchange it for another one like the LP or even Mag tag-
It's not easy to fix these machines and finding the real problem is sometimes a night mare.
The Panasonic error codes are difficult to find, but 'H' faults are generally faults which may or may not be repairable. Like the sump pump -or motor.
The other codes are like this: U11 indicates machine unable to drain. Blockage between drum and drain pump?? Blockage of drain hose??
U13 indicates unbalanced load. Many modern machines suffer from this, but may be related to problem causing U11 fault.
H43 indicates an internal water leak reaching its detector in the machine base.
Like any washing machine, they are great until they go wrong. The problems are usually related to the after sales service.
I hope something helps here-just my 2 cents worth!
Dec 23, 2012 | Dryers
I have a Panasonic NA-148VG3 with a Coin stuck in drain pipe before filter
Just found a coin stuck in the filter! Thanks for your advice John C :)
Oct 19, 2012 | Washing Machines
Error code H43
Is this Panasonic?
If so, H43 code refers to an internal leak. A small amount of water on a sensor will bring up this error code.
Try to remove the back of the machine after unplugging it from the electricity and dry up any water, then try again.
If this doesn't work, contact Panasonic about this issue. They're aware of it because many users encounter this error. Tell them about the problem, they should send you an engineer to fix this.
Thanks for using FixYa - a 4-thumbs up rating is greatly appreciated for answering your free question.
Jun 06, 2011 | Washing Machines
I have a panasonic NA-168VX2 washing machine which i had put in yesterday and today it is flashing up with error code H43 what should i do?
Thank you
Mar 05, 2011 | Panasonic Kitchen Appliances - Others
I get h43 on my washing machine
Unfortunately it does not show the make and model of your washer but if it is a Panasonic I think that means internal leak.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 24, 2011 | Washing Machines
Panasonic M3500 VHS Video Camera
to go to the last preset white balance after turning of and on the cam , you should just click (but not hold ) on the whit balance switch but you have to select manual first , and if you want to set white balance then you should hold on the white balance switch for more than 4 seconds regards
Jan 20, 2007 | Panasonic NV-M3500EN Camcorder
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
