Not printing message comes up with it says I am using an out of date printer driver. for most up to date to contact you It is a Dymo330 Turbo
3 Suggested Answers
  • 92 Answers
SOURCE: no up to date print drivers for hp laser jet 3330 for mac os 10.5
Its a huge posibility that the drivers you are currently using is not compatible with the device. There are many reasons for the same:
  • The drivers installed is not compatible with the windows installed on the computer.
  • Incorrect drivers installed.
To avoid this problem, visit the following link and download the drivers for your printer and I am sure you will face no problem.
Note: Make sure you download the drivers based on the operating system installed on your computer (like Windows XP, Vista, etc)
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=66367&prodSeriesId=66359&prodTypeId=18972&taskId=135&swLang=8
Posted on Apr 30, 2009
nileshsingh2
  • 246 Answers
SOURCE: hp2840 PRINTER. Unable to transfer pictures from
Try to change the usb cable and check again, if it works. If it has same problem, then i recommed you to install the printer driver again. Uninstall the older one and run your printer driver. Print test page, also check you memory card, if it has protect switch on ON mode. I hope these will help you a bit, if not certisfied, please contact your nearest HP outlet for more assistance. Thanks
Posted on May 18, 2010
My dymo 450 turbo prints only 1 label even i order to print 10 labels. I use mac(10.11.5) and dymo label(8.5.3). updated last version.
Double check that your using correct printer driver.
Completely remove restart computer with printer discontente,then reinstall the printer.
Jun 29, 2016 | Dymo LabelWriter 400 Turbo Thermal Printer
DYMO LabelWriter 400 Turbo Installed but gives error message when sending prints
First of all, on Dymos you need to use original Dymo roll,.
Dymo rolls have a tag at the back, non original ones does not have it.
Before reinstalling driver you also need to run the dymo uninstaller utility that you find at Dymo website.
I will post the links for download.
Oct 03, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Won't print from another mac as can't find printer
You can try going to System Preferences and pressing Resume to make sure the printers are not off line. Otherwise, please contact us (see dymo.com for numbers).
^CM
Dec 26, 2013 | Dymo LabelWriter 1752266 450 Twin Turbo...
Hp2840 PRINTER. Unable to transfer pictures from camera Memory Card from the printer to PC. Message "not connected" appears. HP Health Check indicates all drivers etc up to date. Am able to Print Images...
May 18, 2010 | Office Equipment & Supplies
Dymo prints blotchy labels and feeds out many labels after print
Sounds like you have a couple of issues going on...your labels are incompatible or you have an incorrect template selected in the Dymo Software.
Check that the label model matches the template and you are using quality Dymo Labels. Such as the Dymo name brand or the LabelValue brand Dymo labels.
Apr 30, 2010 | Dymo LabelWriter 400 Turbo Thermal Printer
OUR DYMO LABELWRITER TWIN TURBO JUST STOPPED PRINTING--
OK! The first time you tried to print ON THE LEFT SIDE, without anymore labels there, there was a "pending" error message in the print queue. This typically cuts off all furtther printing, as all subsequent requests are "behind" it in order or priority.
To fix this, open the Dymo Labelwriter "Printer" dialog box (double-click it on the tray or go to "start / control panel / printer and faxes" - then double-click on "DYMO LabelWriter Twin Turbo". Once open, you'll see a list of "failed" print requests. Somewhere in there you'll find the one with the "laserwriter output" out of paper message. Select that and cancel or delete it.
If this was the problem, all your attempts will now print (make sure you have enough postage paper in, and you'll have extras you can use, I'm sure!
Hope this helps.
Jun 17, 2009 | Dymo LabelWriter Thermal Printer
LaserJet 4350n Error 49.C02
49.XXXX PRINTER ERROR To continue turn the printer off then on Description The printing operation has been aborted. The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications. Action
  1. Press Cancel Job to clear the print job from the printer memory.
  2. Turn the printer off and then on to clear the error message.
  3. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
  4. If the above action does not solve the issue, contact HP or authorized service provider.
Dec 05, 2008 | HP LaserJet 4350 Printer
Oki 320 turbo
Are you using the parallel or serial port ? .And what driver are you using ? if correct driver is being used maybe delete and re-install the driver.
Hope this helps.
Dezzi
Oct 08, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Printer won't print labels
What driver are you using ? the default driver should be IBM Proprinter.
Hope this helps
Dezzi
Jan 24, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
12 people viewed this question
jasbo
jasbo
