Question about Garden
Balboa gl2000 hi, would you know what does OHH mean when it shows up on the control panel?
Ian  Hot Tub
  • 77 Answers
SOURCE: I have a catalina spa with BALBOA CONTROL PANEL
Where are you from?
If you live in the UK give me a call/email as I have worked on lots of Catalina Spas over the years.
http://hottub.synthasite.com
Regards,
Ian.
Posted on Apr 01, 2010
ZJLimited
  • 17970 Answers
SOURCE: error code "OHH" displayed when
OHH code means "Overheat" condition
The spa has shut down -one of the sensors has detected 118 ° at the heater. Check it and replace it if go to bad.
Hope helps.
Posted on May 25, 2011
SOURCE: hi have problem with canadian spa
OHS, OH, or SPA TEMP LMT Message There is an "Over Heated Spa" (OHS or OH) Water Condition.
One of the Water Temp Sensors has detected 110°F (43.3°C) Incoming Water Temp and Spa Functions are Disabled. System will Auto Reset when Water Temp is below 108°F (42.2°C). Check for Extended Pump Operation or High Ambient Temp, or contact your Dealer or Service Organization.
Spa Water Cool Down
• In order for the Spa Water Overheat Error Message to Automatically Reset and Clear, the Spa Water Must Cool to below 108°F (42.2°C).
• Check the Topside Panel Display to see if the "OHS", "OH", or "SPA TEMP LMT" Spa Water Overheat Error Message has Cleared. If the Error Message has Not Cleared, the Spa Water is still too Hot to Continue Testing.
• Either Wait for the Spa Water to Cool Below 108°F (42.2°C), or Exit Now and Retest at a Later time.
You can find answers to COMMON SPA MESSAGES at the following website:
COMMON SPA PANEL MESSAGES
Hope this helps.
Posted on Sep 09, 2011
  • 111 Answers
SOURCE: Balboa Hot Tub (topside) control panel.
Hold temperature UP & DOWN together for 6 seconds.
or
Balboa 7 button controls, both buttons to the left of the display screen & down temperature.
Posted on Jun 17, 2012
  • 111 Answers
SOURCE: how to fix balboa EL2001 spa
OHH would be the Hi Limit sensor. OHH is an overheat event...
Check the followng:
1. Low GPM.
2. Low Water Level.
3. Blocked Suction Fitting.
4. Blocked Skimmer.
5. Dirty Filter.
6. Too Many Closed Jets.
7. Closed Slice Valve.
8. Heat Related Pump Not Running.
9. Heat Related Pump Not Primed.
10. Malfunctioning Impeller.
11. Incorrect Heat Related Pump.
12. Circ System Misconfigured.
13. Sensor Malfunction.
As you have already changed the sensor it is likely to be one of the others points. Hope that helps.
Posted on Oct 31, 2012
I have a electric wall oven model cwe9000 and it is showing a fault code f1. What is that and how do I fix it?
F1 usually indicated a defect in either the keypad or the electronic control. If the error shows when the keypad is disconnected from control, the problem is usually in the control. If the error ceases with the keypad disconnected, the keypad is usually the cause.
Apr 13, 2008 | Kitchen Ranges
Tip
Fix you car by your self
hi,
before you see any mechanic try these very simple things,check all oil levels,check all panel fuses inside you car and under you car hood,check battery,check air filter ,and gas filter,check gas ohh yeap some people need to know cars run on gas no ofense!!!most of the problems are fuse related or battery die,anyway hope these few things make you day more happy.
good luck
smile you are not alone in this world.
on Sep 15, 2009 | 1999 Dodge Durango
I would like the lyrics to Certainly Lord By Bishop Leonard Scott.
I want to know do have good religion
Like the Bible says Certainly Lord
I want to know do you love everybody
I want to know is your name on the roll
Like the Bible says certainly Lord
I want to know if you've been baptized
(Verse)
Each sign shall follow
Them that believe
And if you trust in the Lord
You shall receive
Goodness and mercy shall follow you
If you just keep the faith
He'll see yout through
Yes, Yes, Certainly Lord
(Repeat)
(Verse)
(Repeat)
Ohh, Ohh, Ohh Ohh Ohh Ohh
(Repeat)
Certainly Lord
Certainly Lord
Certainly Lord
Certainly Lord
Certainly Lord
Timothy Wright lyrics
Apr 26, 2017 | The Computers & Internet
My spa is showing an OHH message. What is causing this message?
Make and model would help. How about my best guess?
OHH means OverHeated Heater caused by an error
One of the Water Temp Sensors has detected 118°F (47.8°C) In the Heater and Spa Functions are Disabled. You Must Press Any Button to Reset when Water is below 108°F (42.2°C). Check for Water Level, Flow Restrictions, Closed Valves, Air Bubbles, and Pump Prime, or Continue for a Detailed Test Procedure.
WARNING:
A Heater Overheat Error Message may indicate Excessively High Heater Temperatures which can Scald or Burn!
If the Heater is Not Cool Enough to Safely Service, allow the Heater to Cool before Continuing Testing.
A Heater Overheat Condition that generates an "OHH" Error Message is Most Likely the result of a Low Flow Condition. Therefore, "OHH" is considered to be a Flow Related Error.
Check for All of the following Conditions:
1.Low Water Level.
2.Blocked Suction Fitting.
3.Blocked Skimmer.
4.Dirty Filter.
5.Too Many Closed Jets.
6.Closed Slice Valve.
7.Heat Related Pump Not Running.
8.Heat Related Pump Not Primed.
9.Contact your Dealer or Service Organization.
DO NOT remove the protective covers from any electrical enclosure, or attempt to service any related electrical device, unless you are a qualified electrician or service professional.
As a responsible adult, always check the topside control panel display for errors and verify safe water temperature before using a spa, and before allowing children to use a spa. Safety should ALWAYS be your first consideration
Nov 15, 2015 | Pool & Spa
I have a Jacuzzi spa with a Balboa R576 (522205) control box. The control panel constantly shows "OH" (overheating) even when the water temp is 50-100 degrees F. When I reset the system by flipping the...
There are some things to check.
Make sure the vents on your cabinet are not obstructed.
Make sure your filter cycle is not too long
Make sure you are not running high speed for more then 30 mins.
Have you looked through the Balboa error message site. I have attached a link follow your error through and you may find your answer. Diagnostic Messages
Mar 02, 2015 | Balboa BB58048 Jacuzzi R574 R576, 4.0KW,...
I am getting an "E6" on my motor when I turn it on. Do not know what that means and I do not hear the motor running.
Hi Nancie
have a good day to you
can you please tell me what kind of control model ? any way E6 coming with control model ( SC-1 / SC-380 / SC-2 ) it means:
-Check the control panel cord for
disconnection. (Check whether
the panel cord comes in contact
with the V belt.)
-Check whether the control panel
connectorhas loosened, (Check
whether the control panel connector
has been securely connected
to the machine.)
best regards
ASHRAF ABOZID
CAIRO - EGYPT
aabozid@hotmail.com
Jan 18, 2015 | Juki DDL-8700
Balboa VL700S control panel jets 1 not working
Your problem is going to be in the circuit board in the spa control box under the skirt.
You have a bad relay.
Rod
US Parts Center
Jun 25, 2013 | Pool & Spa
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
