Avent 5421 Hi, I've just installed a Kingston 2gig ram in my machine, but nothing other than I hear the DVD spin then it shuts off. There is nothing coming up on the screen at all. I have re-installed my old 1gig and "voila" it works fine.............. but slow as usual. Any ideas would be useful Thanks
antiochpc
  • 1314 Answers
SOURCE: What RAM for Acer Aspire 5613AWLMI 533 or 677Mhz?
http://www.crucial.com/store/listparts.aspx?model=Aspire%205610
That being said, I'll make the following comments that will hopefully answer your questions.
The maximum memory for your computer is 4 GB. However, if you are using a 32-bit operating system only 3.7 will be available for the system to use minus however much else you are sharing for the video.
Using 667 memory won't make your processor run any faster; the 533 MHz FSB is set in the processor and using 667 memory won't make the memory run any faster either; it will only run at 533. If you do get just 1 2 GB chip to make 2.5 GB total, make sure it is the same speed as the other chip. Usually it's not an issue but sometimes it can be.
Thanks and please take a moment to rate as fixya.
Posted on Mar 12, 2009
  • 34 Answers
SOURCE: Take out the ram and put it back on Fujitsu S series LBS6130
Try reinsert the RAM in another slot. If there are two RAM chips then try reinserting one by one. Make sure that it sits on the slot properly
Posted on Jun 22, 2009
  • 130 Answers
SOURCE: comes on only for 3 seconds
Try taking out the DVD RW drive and see what results you get then?
Posted on Jul 13, 2009
Dubem16
  • 45 Answers
SOURCE: Having upgraded to 2gb ram on advent 5421 laptop,
Just make sure it is an original ram and it must also be the right one. Of course it should boot with 2GB. Also insert the ram properply.
Posted on Mar 11, 2010
jcameo7270
  • 675 Answers
SOURCE: installed 1gig memory total 2gig i cant get bios
Are you sure the 2 sticks are exactly the same ...eg: same manuf, type,speed...etc....some systems will not work at all unless you install 2 sticks that are exactly the same
Posted on Jan 25, 2011
Where can i buy a 2gig or higher ram for my panasonic cf-w5aw1axs
Very good resource:
SD Cards SSDs Memory Modules and USB Flash Drives Kingston
From there, you can figure out exactly which memory to purchase. Also useful for same purpose:
http://www.crucial.com/ Where to buy once you know which memory to order? I tend to shop at Amazon or Newegg. Both have numerous customer reviews and reasonable prices.
Apr 09, 2014 | Computers & Internet
My Radeon X800GTO is not giving a output signal it's getting power the fan works but no picture no obvious signs of ware latest drivers is it dead
Possible bad connection re- put it back in and check your cables!!!
Could also be monitor or windows bad install.
Feb 08, 2013 | ATI RADEON 9550 Graphic Card
Hi, what RAM can I or can't I add on my GA-8I945PM ?
No, *********** board only supports DDR2 Ram thus the PC2 in your current RAM. Also the maximum capacity of your motherboard is 4gb. So if I were you I would recommend going to 4 1gb PC2-4200 modules. This would reduce latency as opposed to 2 2gb sticks. Also I recommend the 4200 rather than the 6400 or anything else as that is the optimal speed for your motherboard. Kingston is a good company to buy from, I am currently using 8 Kingston FB 2gb DDR3 sticks in my MAC Pro.
Mar 29, 2012 | Computers & Internet
I have installed extra RAM im my vgc-m1. But it does not boot up, just keeps going to boot up normally with windows. I have checked bios setup and it recognises the extra ram, I have also got latest bios...
Hi crobinsona
The extraRam is not compatible with your system or the manufacturer's product isn't neither . Check in the Bios to see what exact type of Ram is supported . Download and install Sandra from http://download.cnet.com/SiSoftware-Sandra/3000-2086_4-10556571.html . It will give you detailed description of the existing RAM and allow you to compare with the stuff you' ve purchased .
Here are a few reliable manufacturers : Crucial , Corsair , Kingston .
Here is a reliable address for purchasing on the net : www.upgradecomputermemory.com
Similar products vary in quality from one source to another and it often happends that low price products simply don't run in different machines .
Best regards ,
fanaudi .
Jul 30, 2011 | Sony VAIO M1 (VGCM1) PC Desktop
Hi i have the asus m51ta-x2 laptop, when i try to turn it on it, the on light flips on and you can hear the hardrive or dvd drive flip on for a min but nothing else, i tried to plug it into a external...
Hi, I've had a similar problem with this notebook. I've managed to bring it back to life by resetting it's BIOS. To do that you'll need to completely disassemble it and remove the CMOS battery from it for about a minute or so and then put it back. CMOS battery is located at the bottom of the motherboard, below the touchpad.
Apr 10, 2011 | ASUS M51 Series M51TA-X2 NoteBook AMD...
I have a HP Compaq 610 NX540EA It came with 2GIG 800Mhz RAM: SPS538436-001 from HP. I now try to add yeat another 800Mhz RAM and the computer wont work. I tried with booth Kingston and Corsair 2GIG...
It may be one of those cases where you have to use HP brand memory. Occasionally,manufacturers pull little tricks like this to make themselves more money.
Mar 25, 2011 | Computers & Internet
Having upgraded to 2gb ram on advent 5421 laptop, machine will not boot up with 2gb or re-installed 1gb.
Mar 09, 2010 | Computers & Internet
Windows XP Professional x64 Will not start up with more than 2gb.
Move your ram into different slots, put different ram in slot 2 or 3, sounds like bad ram, 32 bit apps access ram VERY diferently that 64 bit apps.
Mar 25, 2009 | Microsoft Windows XP Professional x64...
Upgrading ram
You can only run 2gig max IE: 2- 1gig or 1-2gig you cant run 2-2gig the bios will not accept it
Mar 13, 2009 | Toshiba Satellite P205-S6337 Notebook
Computers & Internet Logo
David Payne
David Payne
