Question about Sunpentown International SD65E Dehumidifier
P2 error SUNPENTOWN SD65E 65 PINT DEHUMIDIFIER
Kul dehumidifier error code as unplug and plug back in still has the error code.
"For the above error codes, Power the unit off, and then unplug the unit for 15 minutes. Plug in and power on. If the issue persists, please contact customer service."
https://edgestar.zendesk.com/hc/en-us/articles/201000315-My-dehumidifier-is-displaying-an-error-code-What-does-it-mean-
Apr 28, 2013 | KUL 65 Pint Dehumidifier
Spt 65 pint error code p1
According to the manual, this code, P1, means that it is in a defrost cycle. I now have the problem that my unit is in the P1 mode as often as it is in the dehumidification mode.
May 15, 2012 | Sunpentown 65 Pint Dehumidifier with...
I would like to know the average monthly cost of using a 65 pint dehumidifier if it runs continuously for 24 hours for about 300 days a year
To find the Annual Energy Cost, look in the Owner's Manual or other paper work that came with the unit. The Energy Star rating paper work will have that information. However, that cost does not include routine maintenance cost or any repairs that may arise from running the unit constantly for 360 days. Sounds like you'll be running it in a damp basement.
Hope this helped you and thanks for choosing FixYa.
Aug 06, 2011 | Haier 65-Pint Dehumidifier
I have a Haier 65 pint dehumidifier. When I press the control button to lower the humidity setting, the word On comes up and I do not see numbers lowering.
Let's start from the beginning. Turn the Master ON/OFF Switch to OFF. Unplug the unit for 5 minutes. Then plug the unit back end, and turn the Master ON/OFF Switch to ON. Now, lower the the humidity extraction level to 40%, by using the Arrow Down Button. You will need to lower it by pushing the button for each % setting. DO NOT push and hold the Arrow Down Button.
Doing the above should solve the problem.
Jul 12, 2011 | Haier HDN655E 65 Pint Dehumidifier...
Haier 65 pt dehumidifier the lo light is on and the bucket is not fu;; and the filter is clean. ????
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Jun 07, 2011 | Haier 65-Pint Dehumidifier
Frigidaire 70-pint dehumidifier won't work after winter
No reset button on the compressor... but this tip may give you some clues as to what is or is not happening..
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 04, 2010 | Frigidaire FDL60P1 Dehumidifier
Tyies to Start
It could be a bad compressor, circuit board, or maybe even a sensor or dehumidistat...
Here is a tip about dehumidifiers2_bing.gif that run but do not extract water from the air..
heatman101
May 02, 2010 | Haier 65-Pint Dehumidifier
Burning smell from dehumidifer
Well is your filter clean!!!! is it over working it 30 pint 400sqft 50 pint 1000sqft 65 pint 1300 sqft. hope this helps.
Jul 19, 2009 | Whirlpool AD25BSR Dehumidifier
Sunpentown International SD65E Dehumidifier Logo
78 people viewed this question
Top Sunpentown Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Sunpentown Dehumidifier Expert? Answer questions, earn points and help others
