Question about Garden
How do you remove the shroud from a excell pressure washer model #xr2600 type 1
  • 1388 Answers
SOURCE: type of oil to use
I worked at a tool rental center while attending college and learned all about a variety of tools. We used hydraulic oil with anti-wear and rust inhibitor additives in our pressure pumps. Check at you local auto parts for this type of oil.
Posted on Dec 27, 2008
budgie140
  • 502 Answers
SOURCE: I have an Excell model XR2600 pressure washer that
most hondas have a fuel tap near the carbie.hondas need full choke,before theyll start.connect the water to the pump[so you dont damage the pump trying to start it],then release the trigger,releasing the pressure,full choke,full throttle,fresh fuel,should go.you dont need a carb kit,most of the seals are rubber o rings,take bowl off,reove main jet,and take out emulsifier tube,clean small holes with fine wire,etc,and reassemble.good luck
Posted on Jul 09, 2010
SOURCE: xr2600 excell pressure washer I was using it and
I have the same problem and it seems the piston in the back has a ring and the ring is broken i half i'm talking it to get fixed tomorrow i will keep you informed.
Posted on Oct 11, 2010
  • 26 Answers
SOURCE: Hello- what is the oil
oil capacity is 20 oz. 10w-30
Posted on Jul 26, 2011
  • 1388 Answers
SOURCE: I have a Honda XR2600 pressure washer. When the
Your engine produces max horsepower at 3600 rpm. The engine throttle should be set to max before you pull trigger. Pressure washes generally do not have automatic throttle. You do not have to use max power, but enough power to keep the engine running when trigger is pulled. You washer will actually last longer if you only use about 75% of rated capacity. Good luck
Posted on Oct 18, 2011
My honda xr2600 pressure washer stops running when i pull the trigger
check for a blocked main jet in the carby
the principle is that when the trigger is released there is no pressure in the pump so the engine is idling
when the trigger is pulled the pressure control valve closes the bypass back to the pump and so the motor is loaded up if there is a problem in the carby ,then the motor will stall
Sep 08, 2015 | Honda Garden
I have anexcell 2600 waher and pressure stopped mudstream water input OK
I'd love to offer my help, but need the full model #.
look on the base frame for the model # sticker.
it maybe something like XR2600
May 24, 2014 | Karcher 2500 PSI Pressure Washer
Excell pressure washer
What is your model #
http://www.ppe-pressure-washer-parts.com/excell-devilbiss-pressure-washer-replacement-pump-parts
Nov 03, 2013 | Homelite For Excell - Pressure Washer Pump...
How do I remove the shroud on my Excell XC2600 pressure washer so that I can replace the pulse hose?
I am having the same issue. I need to remove the shroud so I can replace the pulse hose. Did you ever figure out how to do this?
Jun 08, 2012 | Garden
XR2600 unloader valve problem, I believe. Can't
It's the brass piece that sticks through a cutout in the bottom of the undercarriage, the one on the right side from the back with no hose attatched.
Jun 29, 2011 | Honda Garden
I need a manual for the xr2600 serial #244129311
http://servicenet.dewalt.com/Products/Detail?isId=true&productNumber=XR2600&selectedType=13543
Above is the link you will need to download your manual. There is a product recall on your pressure washer, and you might want to contact Black and Decker in regards to it. As you did not post a Type Number, I chose the unit without one. The picture below will show you where to click.
Dec 05, 2010 | Honda Garden
I have an old briggs stratton 2001 power washer its hard to read model number it looks like EXYRB2321 or EXVRB2321 its 6 hp when i put in ether number at B&S sit they say no results i need a...
Excell pressure washers used a series of numbers such as yours. I believe that that number will be for pump or pressure washer as a whole unit. Check Excell web site for a match. If you are looking for the engine model number check the fan shroud or valve cover or tag on engine itself. Good luck
Sep 06, 2010 | Briggs & Stratton 020324 3700 PSI Pro...
Xr2600 excell pressure washer I was using it and it lost water pressure does not have any pressure. the engine runs fine just don't know what the problem is.
Aug 16, 2010 | Honda Garden
I have an Excell model XR2600 pressure washer that will not start. I have had it stored for 3 years. I drained the gas tank and carb and put in fresh gas. Is there a fuel shutoff on this model ? It has a...
If it's been sitting for 3 years most likely the carb is gummed up. If it's getting spark, you could try a small shot of starting fluid into the carb. If it runs on this you know it's a fuel problem. Best bet would get all the MOTOR data, and buy a carb kit from you local lawn and garden equipment parts supplier. . Remove carburator and clean and install kit. Use sta-bil when you put it away next time, but even that only works about a year or so.
Jul 05, 2010 | Karcher 2500 PSI Pressure Washer
Garden Logo
64 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
