Question about Danby DCR34 Compact Refrigerator
I HAVE A PROPANE DANBY FREDGE THE ICE BOX WORKS FINE BUT THE REST OF THE FREDGE IS NOT COOLING THE FREDGE IS 8 YEARS OLD WHAT CAN THE PROBLEM BE
SOURCE: Our Danby propane refrigerator has
Having a simular problem; try changing your regulator on your propane tank. I'm try to find a new thermostat myself. Good Luck!
Posted on Aug 03, 2008
SOURCE: I HAVE DABY ICE MAKER DIM1524 AND THE FAN TO COOL
I REPLACED THE FAN AND THE ICE MAKER IS WORKING JUST FINE.
Posted on Jun 11, 2009
  • 4 Answers
SOURCE: danby kegerator not cooling
I just had the same problem. Mine was outside on the patio and the key pad on the front was the problem. cost me $2.27 plus shipping and it took me 5 minutes to fix call Danby back and wait on the phone for their parts and tell them you need the keypad sticker. Good Luck
Posted on Aug 07, 2009
  • 906 Answers
SOURCE: Danby Propane Refrig-- Low Cooling Output
good day,
hope this link below will solve your problem.
ref
Posted on Aug 03, 2010
heatman101
  • 43501 Answers
SOURCE: my danby beverage centre does not cool anymore 3
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101 ,.,
Posted on Oct 08, 2010
Danby DPR2262W propane refrigerator stopped cooling
OK-to make this short-you either have a boiler tube blockage or Hydrogen diffusion.If your cooling unit quit suddenly,you more than likely have a boiler tube blockage due to precipitation of Sodium Chromate.If your cooling unit gradually quit working it's Hydrogen diffusion.This process is not easy to understand,and I won't bother you with the details as to why.By the way,burping is a myth,it dosen't work.If there is a blockage in your cooling unit turning your refrigerator upside down won't dislodge it.Danby dosen't make stand alone Propane refrigerators anymore,and since the cooling unit is foamed into the box,it's a throw away refrigerator.You will have to get a Servel RGE 400 made by Dometic.It's the same size as the Danby and I have those for a very good price.Go to: www.marvinspropanerefrigerators.com
Aug 20, 2012 | Danby DPR2262 Top Freezer Refrigerator
The compressor on my Danby dehumidifier turns on for a few seconds, very weakly, and quickly cuts out. The fan and control panel are all working properly. The humidity is high enough for it to turn on...
Sounds like you've lost a lot of freon. Find the pump on your unit. Be careful, but after running it a while, touch the tube somewhere between the pump and cooling coils. If it is not hot then you have lost fluid. What happens is under normal working conditions the compressor would compress the freon making it hot, which then gets cooled by the radiator coils. In your case, there isn't enough fluid to compress to make it hot. Unfortunately, you need to have it refilled by a repair shop. Try your local A/C or HVAC shop. Don't be surprised if they can't refill with freon as it's bad for the ozone and being phased out.
May 04, 2011 | Danby DDR586R Dehumidifier
I have a Whirlpook refrigerator, about 6 - 8 years
Try a quick fix by useing a blow dryer to thaw around the water tube and ice maker. Also for good measure>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 13, 2010 | Freezers
Water does not shut off in ice-maker immediately
maybe but check the icemaker to see if the fill switch is working and the timer might be off. In an old unit it is sometimes better to replace it than put a bunch of time and money into it they are not bad priced these days
Aug 23, 2009 | Refrigerators
good day,
ref
Aug 12, 2009 | Danby DPR2262 Top Freezer Refrigerator
Jun 10, 2009 | Danby D9604 Refrigerator With Ice Box
Refrigerator cooling fan freez so not cooling.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
gf
Dec 27, 2008 | Nokia 3230 Cellular Phone
I have a fridge freezer bosch kgn39v00g3.The fredge compartiment doesn't cool as it should.The freezer works fine and it doesn't have ice build up at the back.What is the problem?
Peace Friend,
ngafm At your service!
Ready?
If the freezer is cold and not the fridge, you need to make sure the freezer is not filled to the top and covering the cold air vents and passages usually found in the rear or bottom rear of the freezer!
If they are blocked or covered with packages the unit will not be able to transfer cold air to and from the fridge!
Yes, they share the air in most refrigerators!
What type fridge,model and age?
If not only a trained tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Sep 04, 2008 | Heating & Cooling
Our Danby propane refrigerator has given us sterling service for about five years, but it has suddenly stopped cooling in the refrigerator box-the freezer still works. Any clues?
Apr 17, 2008 | Danby Refrigerators
Fridge does not cool
lo1972
Sounds like ice built up on the evaporator coils inside the freezer. thus hindering air flow to the refridgerator section. Is there ice build up in the freezer? This is assuming the temperature control didn't get changed inadverttily.
Hope this helps
handiman518
Jan 16, 2008 | Zanussi ZEBF250W Bottom Freezer...
Danby DCR34 Compact Refrigerator Logo
14 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
