Replacind power input board 28667-G01 in e-z-go battery charger what to do with black wire going to dc coed.
On board it has a red wire going to heatsink and a black wire but it dont have a wire in dc cord to hook the black wire to so where do i put the black wire.
hotkanni
  • 13 Answers
SOURCE: hp dv 2000 power switch wires 3
To know exact locations of the notebook inner parts, you can try the below manuals of DV2000. Hope this will resolve the issue.
http://h10032.www1.hp.com/ctg/Manual/c00729555.pdf
It is Service Manuals of your notebook model.
Posted on Sep 09, 2008
  • 1122 Answers
SOURCE: hooking up the four prong cord to the dryer
this is the rule of thumb,white always goes on the middle terminal ,the 2 outside terminal wires it does not matter which side they are on,if you can see the red and black wire on the terminal block then match them up,the green wire gets mounted to the cabinet,you should already have a green wire to the cabinet so remove the screw and put both wires there and your done,let me know how you do-mike
Posted on Oct 15, 2008
SOURCE: hp power supply failiure
Ive worked on a friends G7000 series laptop, since it had the same symptoms you have with yours.
I tested it on my own(identical) working charger/PSU and still no charging.
After taking the motherboard out, i traced the fault to a short circuit FET (field effect transistor) with the PCB reference of PQ1, located right next to the connector for the DC power jack loom.(short from gate to source) The FET is made by Fairchild Semiconductors and its part number is FDS6675BZ. Being in the UK, i ordered the part from www.farnell.co.uk at a cost of 56pence. After changing this FET(which is there to control power) the laptop is working.
If you are not good with very intricate surface mount soldering, then i suggest you buy the component, take the motherboard out of the laptop(not too hard) and take them both down your local TV repair shop for them to check and change it(tell them the board reference PQ1).. shouldnt cost more than £20 or so been as they dont have to fault find.
Martin
martinkwashere at hotmail dot com
Posted on Mar 03, 2009
SOURCE: My fs840/w will not power up.
no agara la senal
Posted on Mar 22, 2009
damien729
  • 221 Answers
SOURCE: Battery won't charge. Replaced battery, charger and DC Input board
Please check this article at apple support:
http://www.apple.com/support/macbook_macbookpro/batteryupdate/
Thanks Damien
Posted on May 29, 2009
How can I Troubleshoot wfco 8955 power converter on my 2006 Rockwood travel trailer?
If you have input voltage 110 volts. On the white and black wires. No output voltage at the red and white wires. It's garbage there's nothing serviceable on the unit.
Oct 16, 2015 | RVs
When I turn the key on, panel LED is not on and there is no movement in battery meter. I hear the honk only if the charger is connected. Charger shows green. I replaced the batteries, still same.
hi , it appears that the power is not getting to the main board,,, you need to be very careful here as it easily to make matters worse... look for a thick red and black cable from the look coming up to the tiller ,,, this will hold the voltage that supplies the tiller board...
Take a picture of the overall board and i'll be able to tell you what to test ,,i recommend that you disconnect one battery so you don't short on the board in question
Regards
Rob
www.gewizrepairs.co.uk
Jul 18, 2015 | ActiveCare Medical ActiveCare Spitfire...
Wiring diagram battery pack aspire 5580
Are you asking for the wiring diagram inside the main Battery?
If so, due to very possible injury, or death to you, there will be No solution.
Now, if you are talking about what is the polarity for the plug of the AC adapter, (Charger), that plugs into the DC Power Jack on the laptop, (DC _IN), then I'm on board.
The Center Hole in the plug end is the Positive ( + ) connection.
This is where the Positive (Red) probe lead of the multimeter goes.
The cylindrical outside metal shell is the Negative connection.
The Negative (Black) probe lead of the multimeter touches here.
Voltage is 19 Volts DC.
Wiring diagram for the inside of the AC adapter itself?
No gottom.
Regards,
joecoolvette
Oct 22, 2012 | Acer Aspire 5580 Notebook
I have a advent 7201.it will not come on on its own and it will not come on when the charger is plugged in.the green light is on on the charger but no power on the laptop.could it be the battery or th
Use a multimeter.
An economical unit can be purchased for as little as $8 to $12.
Available in a multitude of stores. An auto parts store is but one example.
Analog or digital is fine.
The Red probe lead is the Positive lead. Plug it into the hole with the red circle, on the multimeter.
The Black probe lead is the Negative lead. Plug it into the hole circled with a black ring., on the multimeter.
The center knob is the Function knob.
Set it to DC Voltage.
If just a symbol is shown, set it to the dotted line over a solid line symbol.
If there is more than one DC Voltage scale, set it to the 0 - 50 Volt scale.
The plug of the AC adapter (Charger) that plugs into the laptop, has a center hole, and an outside cylindrical metal shell.
The center hole is Positive.
The outer cylindrical metal shell is Negative.
Positive probe lead to the center hole, then touch the Negative probe leads to the cylindrical metal shell.
You should be reading 19 Volts, or VERY close to it.
Also have an assistant gently wiggle this cable, while you are testing.
Have them wiggle the power cable TO AC adapter, also.
An intermittent reading indicates a broken wire, or wires. Discard AC adapter, obtain a good one.
http://www.thelaptoppowersupplyshop.co.uk/advent-7021
The port on the laptop that the AC adapter (Charger) plugs into, is the DC Power Jack.
AC adapter checks out it's on to the DC Power Jack.
Post in a Comment if you wish to go on with the diagnosis.
Regards,
joecoolvette
Apr 19, 2012 | Advent Computers & Internet
Charger broke
common problem, go here
http://mrclm.blogspot.com/2009/09/black-decker-18v-firestorm-drill.html
May 14, 2010 | Black & Decker 18V Cordless Drill/Driver
Generac 10 k battery charger installation at the generator, where does the ac input wires connect
Your electrician should have run a set of wires out to the generator from the transfer switch. The unit actually comes with a fuse holder, fuse, terminal connector, and jumper wire for installing these wires to the t1 or t2 terminals in the transfer switch. The dc wires will be the ones coming out of the battery charger, 1 of them will have a red marker around it, that is your dc positive. The 2 wires coming out of the opposite side of the battery charger is actuall your ac connection.
hope this helps let me know.
Nov 01, 2009 | Guardian Electrical Supplies
865 MOTHER BOARD VOLT OUT PU PIN
Hi Dear, well, you can get 1v dc or 1.5v dc from any pc motherboard but I'll never recommend you to do that. You can use Black and Red wire combination to get 5v dc or Black and Yellow wire combination to get 12v dc from motherboard's power supply. 3 LEDs in series can b use for 5v dc input.
Mar 31, 2009 | Intel D865GBF Motherboard
Ez Go 28115-G01 battery charger does not work.
I have an EZGO powerwise 36V charger, model 28115-GO3 that was installed onboard a cart. I want to use this charger for another cart, but the charger has 3 wires out. Why 3 wires? One is +, the other -. what do I do with the third wire? The wires are red, black and yellow; two odf the wires are 10-12 gauge, the other is around 16 gauge.
Mar 26, 2009 | Electronics - Others
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
