Question about VXI Corporation Blueparrott B250-XT Bluetooth Headset
Reset blue parrot
Will not connect to phone, what do I do?
Iphone volume
Have you tried to remove the device from your iphones blue tooth list, and reset the connection?
Mar 15, 2012 | Parrot SA Parrot Evolution Bluetooth Car...
Parrot MKi9200 car phone and IPOD problem. 18 months old and worked fine until moved from bmw to golf mark 5. IPOD now not recognised (any IPOD) have done a restore factory settings without success. ...
A replacement blue box is nearly the same as a new kit. I would do a software update on the Parrot and make sure you do a reset on the ipod, back up the ipod first. I would contact a parrot certified installer if this does not cure it. Parrot web site will have a list of installers. If the kit powers up the blue box is not faulty.
Feb 21, 2011 | Parrot Mk6000 Bluetooth Hands Free Kit
Blue parrot b250xt when making a call cant hear it ring on parrot . When reciving a call you have to divert to hands free.
Seems like you have an issue that is very common. I had the same issue and phoned tech support (1 800 742 8588). The solution is to reset the headset. It is not printed in the manual 1 switch phone on and pair with headset. 2 when paired (blue light flashing) put the charger on the headset for exactly 10 seconds. 3 remove the charger. 4 the lights should be starting to alternating between red and blue. this means it is resetting. 5 as soon as the light quits to alternate, the headset is reset, and the problem should be solved.
This also fixes the Windows 6.1 audio problem.
Jun 20, 2010 | Parrot CAR PAICK3300 GPS Receiver
How to reset parrot
press and hold red and green button until it says clear memory.
Dan
Dec 07, 2009 | Parrot 3000 Evolution Advanced Bluetooth...
My Nokio E52 'sees' the CK3000 Evol parrot, but will not connect.
Switched on the E52 the blue tooth option External SIM Modus to On and kept on trying. And then finally the phone asked for accepting the arrot connection. Entered 1234 and it worked.
Oct 12, 2009 | Parrot Par Ck3000 Evolution Ck3000...
Turning off Blue-Tooth and using phone
there is no another way to off your BT so you have to turn off your Bluetooth and go when u come back then turn on again its automatic connect with your car
May 15, 2017 | Parrot Cell Phones
Parrot evolution
There is a tiny reset on the back of the parrot. Use a paperclip to depress and reset the device. This should remove any pairings.
Jun 20, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Problem connecting Nokia to Parrot CK3100
take the Parrott CK3100 back to the store you bought it from and have them assist you with it.
Feb 28, 2008 | Nokia N95 Cellular Phone
VXI Corporation Blueparrott B250-XT Bluetooth Headset Logo
43 people viewed this question
Top VXI Corporation Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a VXI Corporation Radio Communication Expert? Answer questions, earn points and help others
