Question about Garden
Adjust drive control husqavarna 917.375820 - Garden
Husqavarna ugh1542xp how to belt from the pto.
Download manuals The link provides the manual which shows how to route the mower drive belt. Hope this helps...
Jun 08, 2014 | Garden
Husqvarna 266xp issues.
As the saw runs out of fuel the revs increase due to lean fuel mix, so would guess the saw is not hitting its 12500rpm at full revs, this is either a blocked air filter or the carb adjustment, the revs should be checked with a suitable tacho before leaning off the H screw on the carb, increasing the revs beyond 12500 could result in a cylinder seizure.
Jul 15, 2012 | Husqvarna Garden
Husqavarna 2000 manual
contact husqavarna customer service
Mar 11, 2012 | Sewing Machines
Just bought a used Husqavarna 394XP. It does not gey enough oil into the chain. Does this model have Plates on both sides of the bar to direct the oil. My other saws have plates on either side of the...
The 394XP does not have weel side plates, just a single steel protection plate for the bar pad, the oil pump is adjustable , there is a screw on the bottom of the pump, and an acsess hole up through the bottom of the crankcase.
Aug 28, 2011 | Garden
Have a 137e husqavarna saw put new carb on and just fires and dies. Any help would be appreciated
Try when idle to adjust the carb settings.There has to be 2 screws to adjust the low and high.The low is for when the saw is in low at speed or when is not in use for cut.When you pull the handle to start cut then the adjust the high one at max speed.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 19, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
On a husqavarna 362 xp special 71cc chainsaw very little oil is coming out to the chain i have removed the chain and bar and cleaned and still very little oil is making it to the chain what should i do ??
Check to see if there is an oil-volume adjustment screw located near the lower part of the chain where it goes into the cover, but mounted in the main case. It might be underneath the case in about the same location. Turn it CCW somewhat, if found, and check for oiling by holding the bar tip running at speed near some cardboard. If properly oiled, it will throw off a thin line of oil after several moments. If there is no adjustment, then you will have to investigate the oil pump, lines, and filter/valve in the oil tank. Make sure to clean the small oil passages in the drive end of the bar. Hope this helps!
Jun 25, 2010 | Husqvarna Chain Saw 20" Bar
Husqavarna rancher 55 repairs
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston.
• I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it).
• Make certain the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  1. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 01, 2010 | Husqvarna Chain Saw 20" Bar
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
