Question about Ricoh Aficio Mp161 Copier Photocopier Copy Machine System Mp 161 Ricoh
Richo 2015 error code no.sc391
Please give a solution of this problem
drichards
  • 87 Answers
SOURCE: Ricoh CL7100 Error code SC391-4
Reseat the cyan PCU .
Posted on Feb 23, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Ricoh Aficio 2015
Pressure roller warm up error. Usually means that the fuser roller isn't at the right temperature when you turn the copier on.
Try turning the copier completely off. Wait 30 seconds. Turn it back on again and see if it goes away.
If not a technician should look at the fuser section to see what the problem is.
Posted on Jul 17, 2008
  • 24 Answers
SOURCE: light copies and printing. Richo
Hi
replace the toner supply unit,
Posted on Oct 05, 2008
SOURCE: Error code sc 500
check the developer gear...txt me at 09275514418
Posted on Oct 27, 2008
Bubbabear64
  • 2794 Answers
SOURCE: RICHO 2015
Make sure there are no firewalls turned on your computer. All firewalls should be controlled on a router.
Are you using the web interface from the copier to download them?
Posted on Mar 10, 2009
My copier machine comes up with functional error code sc672. can anyone help
That error code appears to indicate 'Op panel to controller problem' see here http://multifunctionalcopier.blogspot.co.uk/2012/06/ricoh-error-code-list.html
Sep 05, 2015 | Ricoh Richo KR-5 with 35-70mm f3.5-4.5...
After replacing the main motor of my richo afico 2018 the copy result reduces is the cause of mismatch main motor?
Yes, If you have installed a main motor from Aficio 1015 the machine will work and there will be no SC Code displayed, but the machine will print a reduced image.
The part number for the main motor for Aficio 2015 is :
" AX06 0270 Brushless Motor 24V/20W "
Oct 05, 2013 | Ricoh Aficio 2015 Copier
Won't always transmit the fax.
what is the error code? the solution is to find the error code and what it means in the manual.
Oct 22, 2009 | Ricoh FAX3900L Plain Paper Laser
RICHO 2015
Mar 09, 2009 | Ricoh Aficio 2015 Copier
Richo Aficio 2015 I have a richo 2015 machine which has a reading of 1,08,700(number of print out taken)but lately the paper gets folded inside just above the drum. The matter does get printed on the paper...
The pressure roller is inside the fuser section of the copier. If there is a flat spot on the roller, you will get those results. It's better to rebuild the whole fuser unit including the bearings and heat roller. That will stop that jamming from happening.
Jan 26, 2009 | Ricoh Aficio 2015 Copier
Richo 2232c
Make sure all the covers are closed on the copier. Check for any broken magnets, door switches, or sensors.
If that doesn't work you should contact a Ricoh representative in your area to do further troubleshooting tests on your equipment.
Jan 13, 2009 | Ricoh Aficio 2015 Copier
Error code sc 500
Main motor lock error
Failed to detect main motor lock signal for 7 checks in succession (total of 700ms) after main motor started to rotate, or after last lock signal was detected.
Main motor defective
Too much load on the drive mechanism
Motor driver damaged
Oct 19, 2008 | Ricoh Aficio 2015 Copier
Solve my problum
I have a richo 2018d all in one copier machine it can be a error code SC541.
what is its solution ....
Sep 16, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
Ricoh Aficio Mp161 Copier Photocopier Copy Machine System Mp 161 Ricoh Logo
16 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
