SOURCE: fuel supply
sounds like there is no power to the fuel pump while cranking. check the oil pressure sender this helps the fuel pump run under cranking
SOURCE: gas is flooding thru throttle body when trying to start
eather o-ring is bad or throttle body injecter is cracked
SOURCE: 1988 nissan pickup engine rotates but does'nt start.
it sounds like the injectors are not opening up man.. replace the injectores and this should fix your problem..good luck keith....
SOURCE: 99 gmc suburban will not start unless pour gas into the throttle body"
IF YOU HAVE CHECKED THE FUEL PUMP FUSE AND RELAY AND THEY ARE BOTH GOOD THEN THERE IS A GOOD POSSIBILITY THAT THE FUEL PUMP HAS GONE BAD. YOU MAY BE ABLE TO GET IT TO PUMP ONE MORE TIME IF YOU BANG ON THE BOTTOM OF THE FUEL TANK WHILE SOMEONE ELSE TRIES TO CRANK THE ENGINE. IT MAY TAKE A FEW TRIES TO GET IT TO START, BUT THIS HAS WORKED NUMEROUS TIMES FOR ME. IF THE PUMP DOES TURN IT MAY NEVER RUN AFTER THIS, SO FIGURE OUT WHERE YOU WANT TO TAKE IT TO GET IT REPAIRED. THE TANK MUST BE DROPPED TO REMOVE THE PUMP. HOPE THIS HELPS. GOOD LUCK. THANK YOU IN ADVANCE FOR AN HONEST RATING AND FOR USING FIX-YA
SOURCE: only starts when pouring gas in throttle body
Tried changing the fuel filter? If that's not it it could be a bad pump
