Question about Pool & Spa
Pool pump cycles on/off
Just bought new house with existing above ground pool, trying to open it. Everything hooked up correctly, but when starting the pump it will only run for 15 to 30 seconds and shuts off, then starts again after about 45 seconds and repeats this cycle. I own a similar system in my main residence an have never experienced this. Oddly before I hooked the lines to the pump I tested it and it ran fine. ???Thanks !
    Problem Solver:
  • 21 Answers
What is it? do you have a pic?
Posted on Jul 28, 2013
  • 93 Answers
SOURCE: hayward filter problem
YOUR HANDLE IS NOT SEATING IN THE RIGHT POSITION THERE IS A SPROCKET UNDER HANDLE THAT MAY BE DAMAGED TRYSETTING HANDLE TO DIFFERENT POSITIONS SEVERAL TIMES IT MAY HAVE DEBRIS UNDER IT MAKE SURE PUMP IS OFF.TAKE HANDLE ASSEMBLY OFF AND CHECK SPOCKET
Posted on Aug 06, 2009
  • 351 Answers
SOURCE: hook up power from two 110 volts pumps from pool
I would run a feeder from the main breaker panel to a small breaker box near the pool pumps, so you have a disconnect near their location. Look at the drawing and see if you have any questions .. What is the amperage reading on the name plate label of each pump motor??
Posted on May 12, 2010
  • 8404 Answers
SOURCE: My Hayward Super II Pool Pump isn't priming. The
I think your impeller may be stuck OR your start capacitor has failed. Your pump is going off on over load because it cannot turn or cannot start.
Thanks for your interest in FixYa.com
Posted on May 16, 2010
  • 8404 Answers
SOURCE: Pump Cycles on and off. Runs for 10 to 15 seconds
Is this motor thermally protected? Are you running it on 240 VAC and the pump is set up for 240 VAC? (120 VAC- and 120 VAC?). Pump is on its own circuit, or one adequate to supply the proper volts, amps and watts? No extension cords involved?????????
The motor does this because it is over heating for some reason ... improper voltage comes to mind.
You say it starts but will not run ... a faulty run winding comes to mind (start circuit is evidently ok)
Overheating can als be caused by an obstruction in the suction or discharge ...
Posted on May 31, 2010
  • 297 Answers
SOURCE: pool pump shutting off/tripping the circuit breaker
What kind of pump are you using?
Sounds like the Intex is restricting water flow there by heating up your pump and shutting it down..
You may need to re plumb everything to handle the flow.
Intex hoses and fittings are different than the industry standards just so the can make you buy from them
Do what ever it takes to get good flow
Posted on Jul 01, 2010
Ive got power, hot and cold to my existing pump and shower, but the pump doesn't start, just makes a whirring noise.
Above Ground Pool Pump Won't Start or is Humming & How ...
? 6:16
https://www.youtube.com/watch?v=RH78q36liks
Apr 15, 2014 - Uploaded by Above Ground Pros
Above Ground Pool Pump Won't Start or is Humming & How to Fix It ... Pool Motor - Humming-Loud Noise ...
How to fix your pool pump from humming - YouTube
? 2:43
https://www.youtube.com/watch?v=3v2v6aDDq9A
Mar 25, 2013 - Uploaded by James Hayward
Do you have a pool pump not priming (pumping water) andmaking a humming noise ... not only give a ...
pool pump makes humming noise and does not pump - Trouble F
Dec 08, 2015 | Home
Brand new system... Code 90... Checked for air in hoses & loose hoses, changed pump filter, everything installed correctly... Help????
Make sure your flow sensor moves freely. Soak the unit in vinegar if it looks dirty
I would also try bleeding the system run your pump with the bleeder screw on top of the filter cartridge open a few turns Just enough to allow the water and air to flow do this for a minute or so and then tighten the screw
Jun 04, 2010 | Intex Automatic Salt Water System for ...
I just bought and Intex Saltwater system and it says low flow. It is all new equipment and I know it is all hooked up correctly.
make sure its not installed backwards, the flow tube that is. if that doesnt fix the problem make sure that there is no air in the tubes.
May 21, 2010 | Intex Automatic Salt Water System for ...
Hook up power from two 110 volts pumps from pool
May 09, 2010 | Intex Automatic Salt Water System for ...
I bought an Intex 15' x 42" above ground pool at a garage sale. No instruction or DVD were included. How is the skimmer set up?
Plug the inlet & suction openings with provided plugs
Hook up the hoses.
Release vent screw from the top of the filter housing.
Remove hose plugs.
Start pump
when water comes out filter housing vent - close it.
check for proper flow.
Thanks for using FixYa - a good rating is appreciated for answering your FREE question.
Jul 08, 2009 | Intex 15' X 42" Easy Set Pool Complete...
Priming a hayward super pump
IF IT DOES NOT FILL CONSTANT FROM POOL IF IT IS AN INGROUND YOU WILL HAVE TO HELP IT BY PUTING A GARDEN HOSE WATER ON IN SKIMMER PUT A RAG AROUND HOSE FILL CUP TURN OFF RETURNS OPEN BLEEDER VALVE ON FILTER LET WATER FILL START PUMP AND OPEN RETURN VALVE SLOWLY YOU MAY HAVE TO DO THIS SEVERAL TIMES MAKE SURE AFTER YOU GET WATER FROM BLEEDER YOU CLOSE MAKE SURE ALL CONNECTIONS ARE TIGHT INCLUDING CLEAR CAP ON PUMP THESE ARE AIR BLOCKS IF ABOVE GROUND CHECK ALL HOSES AND CAP
Jun 30, 2009 | Hayward SAND FILTER, PRO SERIES
Brand new 2009 model 8111 can't get filer to run
There is an air lock, so it seems. Leave filter off, on top of filter is a valve to let air escape. Keep this open until you get a stady stream of water from oulet, then close. Start pump. Not being a smart ****, besure that the water flow is correct. Skimmer to inlet side, return to pool.
Jun 09, 2009 | Intex Automatic Salt Water System for ...
Pool & Spa Logo
62 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
