Question about M&S Systems DMC1CD 6-Disc CD Changer
How do I install a new CD changer?
Received a new CD changer to install in the system and need instructions as to where to connect a tiny wire.
Clarion cd changer manual
My suggestion would be to check out your local ICE specialist or find the local Saturday night car gathering and see who they recommend.
Sep 05, 2014 | Clarion Infiniti I35 Nissan Maxima Cv737...
How to remove cd from blocked cd changer
To remove a CD from a changer that does not respond to the eject button: Look to see if there is a tiny round hole near the eject button. It will be as small or smaller than the diameter of a paperclip. If you see it then that is the CD release. You will need to find a piece of very stiff wire that fits comfortably in that hole. After you insert the wire you will feel it land against something hard in maybe about 1/2 inch. Gently press the wire and hope that there is compression of the switch which will open the CD Changer.
Jun 22, 2014 | 2003 Mercedes-Benz E-Class
Ford focus , how i install cd changer?
You must have the same type that will mate with the set in your dash . If so connect the changer with the multicore cord, connect the power and mate this with the main set and use the power from the car system. If you are going to use a universal changer with an Fm transmission then connect the changer and power the set to the accessories outlet. Tune your car audio to the freq. of the changer and there you are. Helpful? Good day
Jul 06, 2010 | Car Audio & Video
Alpine CHM-S620 6 Disc CD Changer Components
sounds like the changer was plugged into the antenna jack of the radio. this means that you can run it through any radio simply by sending a signal to a preset station on the radio and listening to it through tuner. the control unit ran the changer itself. you may be able to obtain replacement cables from pacparts.com
Apr 01, 2010 | Alpine CHM-S630 6-Disc CD Changer
Installing a new stereo. I am trying to install a ''JVC KD-R210'' in my wifes 1985 BMW 535i, replacing a Sony CDX-R79 and in the trunk is a Pioneer 12 disc cd changer that was hooked up to the system. This...
There is a line level converter that would need to be purchased to that you can get the front speakers to work with the amplifier. The stereo already has rca jacks for the rear speakers. You can connect these straight to the amplifier for it to work. Bes sure that you use the blue wire to connect to the remote turn on for the amplifiers. Once you get the line level converter you will connect the wires and connect the converter using the RCA jacks. The question would be how was the 12 disc changer connected to the system. Would need more information on the changer in order to help with that component.
Mar 13, 2010 | JVC KD-S550 CD Player
No installation instruction for pioneer cdx-fm128
the manual is really same with cdx fm-1277. Just look at the 1277 masual it will help you.
May 16, 2009 | Pioneer CDX-FM1287 12-Disc CD Changer
20 people viewed this question
Top M&S Systems Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
woodzowl307
Are you a M&S Systems Audio Player and Recorder Expert? Answer questions, earn points and help others
